Re: Mainsheet Tie to Rear Beam [Re: Dlennard] #232457
05/16/11 07:51 AM
05/16/11 07:51 AM
pgp Offline
pgp  Offline
http://www.animatedknots.com/double...og.jpg&Website=www.animatedknots.com
I had been using a figure 8 with an extra turn on the standing end, but have changed to the double overhand. The text explains the reasoning.
Pete Pollard
Blade 702
Re: Mainsheet Tie to Rear Beam [Re: David Ingram] #232459
05/16/11 09:09 AM
05/16/11 09:09 AM
Originally Posted by David Ingram
Originally Posted by Matt M
Originally Posted by macca
its called a skiff knot, because its so simple even a skiff sailor can do it smile
I've always heard that knot called an Australian bowline. wink
Do you two think it's wise to F!@# with Aussie skiff sailors?
BAAAWAAAAA!
Their in Aussie land anyhow.
Re: Mainsheet Tie to Rear Beam [Re: macca] #232630
05/19/11 12:56 PM
05/19/11 12:56 PM
Chicago, Illinois USA
TEH Offline OP
TEH  Offline OP
By the way, if anyone is interested in doing their own soft shackle, this is a good site to visit. You input the size and it tells you how much line you need, where to make your marks, etc.
Making Soft Shackles
Blade F16 USA 725
Re: Mainsheet Tie to Rear Beam [Re: TEH] #232632
05/19/11 01:27 PM
05/19/11 01:27 PM
pgp Offline
pgp  Offline
Nice!
Anyone have a similar site for splicing?
I've gathered a small number of reference sites, maybe we should all compare notes someday?
This is my favorite: http://www.animatedknots.com/indexb...og.jpg&Website=www.animatedknots.com
I think I got it from JW.
Pete Pollard
Blade 702
Re: Mainsheet Tie to Rear Beam [Re: pgp] #232633
05/19/11 04:03 PM
05/19/11 04:03 PM
TEH Offline OP
TEH  Offline OP
Here is the new england ropes splicing guide:
New England Ropes
Blade F16 USA 725
Re: Mainsheet Tie to Rear Beam [Re: TEH] #232634
05/19/11 04:48 PM
05/19/11 04:48 PM
pgp Offline
pgp  Offline
Thanks. There was a long thread some time back about splicing and fids.
Do you happen to remember what the final verdict was? Is it necessary to buy an expensive set of fids or is there a more inexpensive alternative?
Pete Pollard
Blade 702
Re: Mainsheet Tie to Rear Beam [Re: pgp] #232636
05/19/11 05:04 PM
05/19/11 05:04 PM
TEH Offline OP
TEH  Offline OP
I don't remember that thread. I'd like to know because I'm going to be splicing some lines.
Blade F16 USA 725
Re: Mainsheet Tie to Rear Beam [Re: TEH] #232637
05/19/11 05:12 PM
05/19/11 05:12 PM
pgp Offline
pgp  Offline
The jist was that fids can be expensive and not all sets work as well as others. So, you could be out $100 and still not have the correct tool.
Pete Pollard
Blade 702
Re: Mainsheet Tie to Rear Beam [Re: pgp] #232638
05/19/11 06:29 PM
05/19/11 06:29 PM
get several sets of knitting needles from walmart. cut them shorter. BOOOOOOOMMMM!!!! fids... cheap too
Re: Mainsheet Tie to Rear Beam [Re: PTP] #232639
05/19/11 06:35 PM
05/19/11 06:35 PM
pgp Offline
pgp  Offline
There's an idea! You've actually done this?
Pete Pollard
Blade 702
Re: Mainsheet Tie to Rear Beam [Re: pgp] #232640
05/19/11 06:48 PM
05/19/11 06:48 PM
yep. key issue is cutting them and then filing down the rough spots. they are hollow aluminum. Work great... but I am so unorganized I keep losing them.
Re: Mainsheet Tie to Rear Beam [Re: PTP] #232645
05/19/11 10:00 PM
05/19/11 10:00 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
I've used solid, small dia knitting needles for splicing 1/8" vectran 12 strand, taping the line to the needle. I remember Brian Toss Rigging having the quality fids. Search that and see what you get.
Re: Mainsheet Tie to Rear Beam [Re: pgp] #232648
05/20/11 05:13 AM
05/20/11 05:13 AM
France
pepin Offline
pepin  Offline
France
Don't bother buying a fid: For the size of lines we work with you probably have all the needed parts in your toolbox already.
Pick a length of thin wire (60cms or 2 foot), bend it in two in the middle, twist the ends together, cover the twist with tape and slide a plastic ball to cover the tape. If you want to be really fancy use stainless steel wire and bind the two ends with a nicropress sleeve instead of just twisting.
That's all you need to do all the splices you will ever need to do on your cat.
Re: Mainsheet Tie to Rear Beam [Re: pepin] #232649
05/20/11 07:19 AM
05/20/11 07:19 AM
pgp Offline
pgp  Offline
Thanks. What lines do you splice?
Pete Pollard
Blade 702
Re: Mainsheet Tie to Rear Beam [Re: pgp] #232653
05/20/11 09:41 AM
05/20/11 09:41 AM
France
pepin Offline
pepin  Offline
France
My weapon of choice is 3mm Dyna One HS from Gleistein. It is perfect for any lines you don't have to handle while sailing. I bought a 50 meter spindle for a very very good price and used it to replace lines on the trampoline, trapeze, pole, first stage of the main downhaul, spi downhaul and various soft shackles all around. There is not one knot on any of those lines, everything is spliced.
Most of the control lines are 4mm Excel Racing from Marlow tapered where needed and with splices or integrated soft shackes at the end as dictated by the place it is used (downhaul, spi halyard, main halyard, mast rotation, outhaul).
My tapered main sheet is Salsa from New England joined with some 4mm single braid dyneema of unknown origin (Marlow?).
I used 5mm Gleistein Discover for the line holding my trapeze dogbone, with a splice on both side and that was a mistake, I need to change it. This line is too slippy for that usage and my stopper keep sliding at the most inopportune moment. I need to replace that with something with more grip.
And I'm currently evaluating what to get to replace my spi sheets. I'm leaning toward a single braid dyneema/polyester blend like the Discover, in 6 or even 7mm with a tail to connect to the spi clew. I haven't decided what to get yet, suggestions welcome.
Re: Mainsheet Tie to Rear Beam [Re: pepin] #232654
05/20/11 10:31 AM
05/20/11 10:31 AM
pgp Offline
pgp  Offline
That's a lot of splicing.
Pete Pollard
Blade 702
Re: Mainsheet Tie to Rear Beam [Re: pgp] #232672
05/21/11 07:27 PM
05/21/11 07:27 PM
once you start splicing and realize how easy (and cheap) it is to do you will find yourself doing what he did- everything gets spliced. If I lived next to my boat, everything would be 7/64 amsteel spliced
Re: Mainsheet Tie to Rear Beam [Re: PTP] #232713
05/23/11 02:49 PM
05/23/11 02:49 PM
pgp Offline
pgp  Offline
Ok, what's the easiest place to start?
Pete Pollard
Blade 702
Re: Mainsheet Tie to Rear Beam [Re: pgp] #232714
05/23/11 03:20 PM
05/23/11 03:20 PM
making eye's in 12 strand dyneema
Re: Mainsheet Tie to Rear Beam [Re: Karl_Brogger] #232716
05/23/11 03:34 PM
05/23/11 03:34 PM
pgp Offline
pgp  Offline
It's on the "to do" list.
Pete Pollard
Blade 702
Most Online22,490
Yesterday at 08:14 AM
