| Re: Mainsheet Tie to Rear Beam
[Re: Dlennard]
#232457 05/16/11 07:51 AM 05/16/11 07:51 AM |
Posts: 5,525 | http://www.animatedknots.com/double...og.jpg&Website=www.animatedknots.comI had been using a figure 8 with an extra turn on the standing end, but have changed to the double overhand. The text explains the reasoning.
Pete Pollard Blade 702
[Re: David Ingram]
#232459 05/16/11 09:09 AM 05/16/11 09:09 AM |
Joined: Feb 2005 Posts: 4,118 Northfield Mn Karl_Brogger
Posts: 4,118 Northfield Mn | its called a skiff knot, because its so simple even a skiff sailor can do it I've always heard that knot called an Australian bowline. Do you two think it's wise to F!@# with Aussie skiff sailors? BAAAWAAAAA! Their in Aussie land anyhow.
[Re: macca]
#232630 05/19/11 12:56 PM 05/19/11 12:56 PM |
Joined: Dec 2008 Posts: 329 Chicago, Illinois USA TEH OP
Posts: 329 Chicago, Illinois USA | By the way, if anyone is interested in doing their own soft shackle, this is a good site to visit. You input the size and it tells you how much line you need, where to make your marks, etc. Making Soft Shackles
Blade F16 USA 725
[Re: TEH]
#232632 05/19/11 01:27 PM 05/19/11 01:27 PM |
Posts: 5,525 | Nice! Anyone have a similar site for splicing? I've gathered a small number of reference sites, maybe we should all compare notes someday? This is my favorite: http://www.animatedknots.com/indexb...og.jpg&Website=www.animatedknots.comI think I got it from JW.
[Re: TEH]
#232634 05/19/11 04:48 PM 05/19/11 04:48 PM |
Posts: 5,525 | Thanks. There was a long thread some time back about splicing and fids.
Do you happen to remember what the final verdict was? Is it necessary to buy an expensive set of fids or is there a more inexpensive alternative?
[Re: pgp]
#232636 05/19/11 05:04 PM 05/19/11 05:04 PM |
Posts: 329 Chicago, Illinois USA | I don't remember that thread. I'd like to know because I'm going to be splicing some lines.
Blade F16 USA 725
[Re: TEH]
#232637 05/19/11 05:12 PM 05/19/11 05:12 PM |
Posts: 5,525 | The jist was that fids can be expensive and not all sets work as well as others. So, you could be out $100 and still not have the correct tool.
[Re: PTP]
#232639 05/19/11 06:35 PM 05/19/11 06:35 PM |
Posts: 5,525 | There's an idea! You've actually done this?
[Re: pepin]
#232649 05/20/11 07:19 AM 05/20/11 07:19 AM |
Posts: 5,525 | Thanks. What lines do you splice?
[Re: pgp]
#232653 05/20/11 09:41 AM 05/20/11 09:41 AM |
Posts: 976 France | My weapon of choice is 3mm Dyna One HS from Gleistein. It is perfect for any lines you don't have to handle while sailing. I bought a 50 meter spindle for a very very good price and used it to replace lines on the trampoline, trapeze, pole, first stage of the main downhaul, spi downhaul and various soft shackles all around. There is not one knot on any of those lines, everything is spliced. Most of the control lines are 4mm Excel Racing from Marlow tapered where needed and with splices or integrated soft shackes at the end as dictated by the place it is used (downhaul, spi halyard, main halyard, mast rotation, outhaul). My tapered main sheet is Salsa from New England joined with some 4mm single braid dyneema of unknown origin (Marlow?). I used 5mm Gleistein Discover for the line holding my trapeze dogbone, with a splice on both side and that was a mistake, I need to change it. This line is too slippy for that usage and my stopper keep sliding at the most inopportune moment. I need to replace that with something with more grip. And I'm currently evaluating what to get to replace my spi sheets. I'm leaning toward a single braid dyneema/polyester blend like the Discover, in 6 or even 7mm with a tail to connect to the spi clew. I haven't decided what to get yet, suggestions welcome. | | | Re: Mainsheet Tie to Rear Beam
[Re: pepin]
#232654 05/20/11 10:31 AM 05/20/11 10:31 AM |
Posts: 5,525 | That's a lot of splicing.
[Re: PTP]
#232713 05/23/11 02:49 PM 05/23/11 02:49 PM |
Posts: 5,525 | Ok, what's the easiest place to start?
[Re: pgp]
#232714 05/23/11 03:20 PM 05/23/11 03:20 PM |
Posts: 4,118 Northfield Mn | making eye's in 12 strand dyneema
[Re: Karl_Brogger]
#232716 05/23/11 03:34 PM 05/23/11 03:34 PM |
Posts: 5,525 | It's on the "to do" list.
659
guests, and 155
