| Ronstan Clearstart #233033 05/31/11 01:02 PM 05/31/11 01:02 PM | MarkMT
| MarkMT
Unregistered | I'm looking at the prices of Clearstart timers and notice that the big round one that you can strap to the boom (RF4030) is a whole lot more expensive that the wristwatch (RF4031) - e.g. $100 vs $65 at West Marine. Is this just the extra cost of the bigger LCDs or is there some functional difference? Anyone know? | | | Re: Ronstan Clearstart
[Re: ]
#233043 05/31/11 02:59 PM 05/31/11 02:59 PM |
Posts: 1,152 tampa, fl | The Clear Start is great. What I like most about it is that the display is so big and I can see it clearly mounted on the boom. When I wore a watch on my wrist I could not check the time, watch were I was going, and look out for traffic all at the same time. Defintately worth the price!!!!!!
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Ronstan Clearstart
[Re: ksurfer2]
#233044 05/31/11 03:04 PM 05/31/11 03:04 PM |
Posts: 1,246 Orlando, FL | Defintately worth the price!!!!!! Until you lose it (at Tradewinds) ... don't ask me how I know.
USA 777
[Re: arbo06]
#233075 06/01/11 01:21 AM 06/01/11 01:21 AM | MarkMT
| MarkMT
Unregistered | Just to be clear, both models are Clearstart - just different form factors. I'm presume that what most of you are recommending is the RF4030. Thanks. | | | Re: Ronstan Clearstart
[Re: ]
#233082 06/01/11 04:05 AM 06/01/11 04:05 AM | MarkMT
| MarkMT
Unregistered | BTW, they look so similar, you have to suspect they're made in the same factory. | | | Re: Ronstan Clearstart
[Re: ]
#233091 06/01/11 07:14 AM 06/01/11 07:14 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Couple of tips for the Clearstart. 1. Since we usually start on starboard tack, I wear the wrist watch on my right arm (sheeting hand), which is always right in front of my face. Easy to see and watch where that hold may open up for you. 2. I program it for 1 minute, and if a 3 minute sequence, press it 3 times; 5 minutes, 5 times. 3. Best feature is the Sync.., if you miss the initial flag, you can hit sync on the next one and it will get you right back on time https://store.catsailor.com/pc/viewPrd.asp?idproduct=13178&idcategory=124 | | | Re: Ronstan Clearstart
[Re: ]
#233124 06/01/11 05:39 PM 06/01/11 05:39 PM |
Joined: Dec 2008 Posts: 329 Chicago, Illinois USA TEH
Posts: 329 Chicago, Illinois USA | Mark,
I have the small one. That's what I used at Ripley (and helped us acheive such killer starts). It works fine.
If you start it late, you can hit sync and it advances to the next minute. There is also an audible beep each minute and then more beeps during the last minute and a beep a second during the last 10 seconds, so you don't necessarily have to see it but I can see where you would want to see how much time was left. I wish it was louder.
I went with the smaller one due to cost and I use it for more than just sailing.
Blade F16 USA 725
[Re: TEH]
#233125 06/01/11 06:30 PM 06/01/11 06:30 PM |
Posts: 3,224 Roanoke Island ,N.C. | I've used the small one for awhile. Killed one and they gave me a new one under warranty. I do have a problem with the sync button getting pressed by my hand or glove if I bend my wrist( making you start a minute early). I solved that problem by grinding the button off.You can still sync but you have to press the little metal post instead of the whole button.I also blew the pins out of the first one, breaking the case, and had to drill holes and tie it to the wrist band. If I had it to do over I'd just get the big one and be done with it.
[Re: maritimesailor]
#233158 06/02/11 11:21 AM 06/02/11 11:21 AM |
Posts: 5,590 Naples, FL | the best part is in light air starts when all the boats are bunched up at the line and everyone's start watch is beeping. It's like you're stuck in a cage with 30 finches...
[Re: Miracle804]
#233197 06/03/11 10:42 AM 06/03/11 10:42 AM | MarkMT
| MarkMT
Unregistered | Thanks Wally. Is that Mr Schuette? | | |
490
guests, and 44
