Fuling the spin? #234567
07/08/11 10:23 AM
07/08/11 10:23 AM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Randy made me a monster kite for the HT. It looks good and flys great, but its so f*ing big that it doesnt go into the snuffer without a ton of effort. Plus the corners are reinforced with Dacron and the luff is double taped, so its a pretty well made sail, but it doesnt snuff well.
Would it be easier to furl and hoist it furled? Will this work? Thoughts?
Bill
Re: Fuling the spin? [Re: bvining] #234571
07/08/11 01:46 PM
07/08/11 01:46 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
If it is not cut very flat...furling will not work...there will be a large bag/bubble in the mid section that will just flop around in the wind.
What kind of snuffer are you running? I found big differences in making changes to my setup when I had trouble with a Guck snuffer on the tornado. One of the major concerns was where along the pole the snuff is located...too far aft and the sail just sort of bunches up hugely before trying to enter the hoop. After thinking thorough the distances between the sail patches, where the points all come together..I could then make an adjustment on where to place the snuffer along the pole so that sail would start entering before full bunch up.
There are other tricks as well like introducing stopper balls on the retrieval line at the right places between patches to keep the sail more spread out when dousing.
Ultimately, I changed from the Guck snuffer to simple an Alu ring with a Dacron tapered bag...and snuffing has be fantastic ever since.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Fuling the spin? [Re: Tornado] #234584
07/08/11 06:40 PM
07/08/11 06:40 PM
Atlanta
bvining Offline OP
bvining  Offline OP
Atlanta
Thanks Mike
I am running a Guck sniffer. I will look at moving/changing it.
Re: Fuling the spin? [Re: bvining] #234591
07/09/11 02:17 AM
07/09/11 02:17 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
The stiff parts of the sail will soften up
Re: Fuling the spin? [Re: TEAMVMG] #234603
07/09/11 09:07 PM
07/09/11 09:07 PM
Eastern NC, USA
tshan Offline
tshan  Offline
Eastern NC, USA
unfortunately, they always do ...
Re: Fuling the spin? [Re: tshan] #234628
07/10/11 05:50 PM
07/10/11 05:50 PM
France
pepin Offline
pepin  Offline
France
play with some rings and little lines to move the location of the rings away fron the sail. Doing this means that the sail doesn't bunch as it is more spread out. Unless you only do it on the middle patch you should plan for a longer bag however, by as much as the longer line you put in.
Re: Fuling the spin? [Re: bvining] #234632
07/10/11 08:41 PM
07/10/11 08:41 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
Originally Posted by bvining
Randy made me a monster kite for the HT... ...its a pretty well made sail, but it doesnt snuff well.
Facnor has an interesting furling system for asymetrics here.
The concept seems to work, I've seen a video of it but can't find it now.
Luiz
0 registered members (), 2,496 guests, and 620 spiders.
Yesterday at 10:10 AM
