| Nacra 5.8 Demasted #234928 07/17/11 06:54 PM 07/17/11 06:54 PM |
Joined: Aug 2010 Posts: 50 Bay Area, California, US Nacra5.8NA1386 OP
Posts: 50 Bay Area, California, US | Took the 5.8 out today, and a couple of minutes off of the beach, the mast came down, luckily nobody was hurt, we got in safely. Upon inspection, we found that the twist (screw) shackle holding the bridal foil on had come out. We probably should have checked it before sailing, but we thought that just switching both of those to clevis pins and rings, as the rest of the standing rigging is, would be easier, and safer. Is there any reason that switching them over wouldn't work? I'm also wondering how exactly to switch my tiller crossbar hinge/connectors to the tiller extension universals. Thanks.
Nacra 5.8NA "Royal Flush" | | | Re: Nacra 5.8 Demasted
[Re: bvining]
#234935 07/18/11 11:50 AM 07/18/11 11:50 AM |
Posts: 50 Bay Area, California, US | Yeah, early in the day, I had taped every other pin on the standing rigging. Forgot about those. I also heard that screw shackles are better for side loading, maybe that's why they're used?
[Re: bvining]
#234936 07/18/11 12:18 PM 07/18/11 12:18 PM |
Posts: 50 Bay Area, California, US | Yeah, earlier in the day, I had taped every other pin on the standing rigging. Forgot about those. I also heard that screw shackles are better for side loading, maybe that's why they're used?
[Re: Nacra5.8NA1386]
#234940 07/18/11 07:17 PM 07/18/11 07:17 PM |
Posts: 1,203 uk | Screw pin shackles are forged [round cross section] Clevis pin shackles are bent bits of flat steel and will distort easily.
[Re: catman]
#234942 07/18/11 10:53 PM 07/18/11 10:53 PM |
Posts: 50 Bay Area, California, US | TEAMVMG- I meant just replacing the screw shackle with a clevis pin and ring, just like the shrouds and forestay are attached to the adjusters.
I guess I'll just replace the shackle I lost and tighten it more. Thanks guys.
22
guests, and 81
Mod | | Forums26 Topics22,397 Posts267,040 Members8,119 | Most Online1,650 Sep 10th, 2019 | | |
