Nacra 5.8 Demasted #234928
07/17/11 06:54 PM
07/17/11 06:54 PM
Bay Area, California, US
Nacra5.8NA1386 Offline OP
Took the 5.8 out today, and a couple of minutes off of the beach, the mast came down, luckily nobody was hurt, we got in safely. Upon inspection, we found that the twist (screw) shackle holding the bridal foil on had come out. We probably should have checked it before sailing, but we thought that just switching both of those to clevis pins and rings, as the rest of the standing rigging is, would be easier, and safer. Is there any reason that switching them over wouldn't work?
I'm also wondering how exactly to switch my tiller crossbar hinge/connectors to the tiller extension universals. Thanks.
Nacra 5.8NA "Royal Flush"
Re: Nacra 5.8 Demasted [Re: Nacra5.8NA1386] #234933
07/18/11 10:19 AM
07/18/11 10:19 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
whatever you do, you should tape it to make sure it stays together.
Re: Nacra 5.8 Demasted [Re: bvining] #234935
07/18/11 11:50 AM
07/18/11 11:50 AM
Yeah, early in the day, I had taped every other pin on the standing rigging. Forgot about those. I also heard that screw shackles are better for side loading, maybe that's why they're used?
Re: Nacra 5.8 Demasted [Re: bvining] #234936
07/18/11 12:18 PM
07/18/11 12:18 PM
Yeah, earlier in the day, I had taped every other pin on the standing rigging. Forgot about those. I also heard that screw shackles are better for side loading, maybe that's why they're used?
Re: Nacra 5.8 Demasted [Re: Nacra5.8NA1386] #234940
07/18/11 07:17 PM
07/18/11 07:17 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Screw pin shackles are forged [round cross section] Clevis pin shackles are bent bits of flat steel and will distort easily.
Re: Nacra 5.8 Demasted [Re: Nacra5.8NA1386] #234941
07/18/11 08:04 PM
07/18/11 08:04 PM
catman Offline
catman  Offline
You should a tool to tighten the shackle. They won't come undone.
Re: Nacra 5.8 Demasted [Re: catman] #234942
07/18/11 10:53 PM
07/18/11 10:53 PM
TEAMVMG- I meant just replacing the screw shackle with a clevis pin and ring, just like the shrouds and forestay are attached to the adjusters.
I guess I'll just replace the shackle I lost and tighten it more. Thanks guys.
0 registered members (), 528 guests, and 36 spiders.
