| Re: F20na Box Rule Set Posted
[Re: Mlcreek]
#235083 07/22/11 01:28 PM 07/22/11 01:28 PM |
Posts: 5,590 Naples, FL | Jay, You fixing to by another boat?
Forrest Short answer: yes. Long answer: (1) place to put it (problem) (2) reasonable price (check) (3) permission from momma (pending)
[Re: Goclaw]
#235202 07/25/11 07:35 PM 07/25/11 07:35 PM |
Posts: 72 | Well there was some good work done this week as far as sail measurements go. Kevin Rajida and hunter from schurr sails get all the credit for this. Kevin and hunter have been working on getting all the data they can over the last few days.
Open20NA 1337 FOR THE WIN!!!
[Re: BadLatitude1337]
#235222 07/26/11 09:12 AM 07/26/11 09:12 AM |
Posts: 887 Crofton, MD | Should we have a sail measuring party here at our club? Was thinking of doing this anyways, since one of our members will be contacting a local sail maker this week for a new sail...
The unraveling has begun...
#235224 07/26/11 09:24 AM 07/26/11 09:24 AM |
Posts: 12,310 South Carolina | How are you guys measuring the sails? There are a lot of different ways to skin that cat. The F18 rule is pretty detailed but works well to control the "creativity" some people seem to find with sail measurement systems. Be glad to help with some insight.
Jake Kohl | | | Re: F20na Box Rule Set Posted
#235225 07/26/11 09:27 AM 07/26/11 09:27 AM |
Posts: 3,224 Roanoke Island ,N.C. | Are you going to post the measurements somewhere for all to see and use or is this just a Schurr thing?
#235227 07/26/11 09:41 AM 07/26/11 09:41 AM |
Posts: 3,116 Annapolis, MD | The F18 rule is pretty detailed but works well to control the "creativity" some people seem to find with sail measurement systems. They seem to want a lot of development. 320 lb boat weight and a max sail area of xxx for the sail plan. I would think any standard method used by sail makers would work. I would love to hear how the sailmakers will manage the super stiff telephone pole that is the N20 carbon stick. Can you get the range needed without pulling the sail apart in a year. Perhaps one of the load path sail cloths could let you bend the mast enough. If you guys get any measurements on the bend of the sticks... it would be interesting to compare with the alu N20 stick and the F18HT riba sticks or the Tornado carbon stick. Always looking to learn something.
crac.sailregattas.com
[Re: Team_Cat_Fever]
#235229 07/26/11 10:58 AM 07/26/11 10:58 AM |
Posts: 5,525 | Nice! Couldn't you guys just borrow someone elses system and plug in your own numbers?
Pete Pollard Blade 702
#235238 07/26/11 02:38 PM 07/26/11 02:38 PM |
Posts: 127 Rock Hill,SC | Are you going to post the measurements somewhere for all to see and use or is this just a Schurr thing? We (Hunter Riddle and I) have been using the F16 documents to measure the sails. This was what Hunter used when he and Mark Smith started developing new sails. As we get the rules for the new class firmed up we will post the measurement system. The idea is not to have to measure every sail but to give sailmakers the ability to measure and mark sails with the size. I will also publish what we find measuring existing EP sails as well as the one's Hunter has built. I have measurements for the Europe sails that Charlie Trinque has as well as several sets from the 1000 series (Alter Cup boats from 2006). Hope to get hold of an older one that Charlie Harp has soon (USA496) just for comparison.
Kevin Rejda Rock Hill, SC
[Re: KevinRejda]
#235239 07/26/11 02:43 PM 07/26/11 02:43 PM |
Posts: 3,906 Clermont, FL, USA | Kevin, do not forget to include the mast in the sail area measurements. Since Charlie has the wing mast and everyone else has the carbon stick it makes a significant difference.
Dave
[Re: David Ingram]
#235241 07/26/11 02:47 PM 07/26/11 02:47 PM |
Posts: 127 Rock Hill,SC | Kevin, do not forget to include the mast in the sail area measurements. Since Charlie has the wing mast and everyone else has the carbon stick it makes a significant difference.
Dave Knew that, going by his house this afternoon if it isn't raining to measure the stick. Gonna stop at PYC to measure a carbon one that is on a trailer next day or 2. Kevin
[Re: orphan]
#235710 08/03/11 06:57 PM 08/03/11 06:57 PM |
Posts: 3,224 Roanoke Island ,N.C. | I see one small problem. The only boat that fits is the N20. Would you race an older design (Nacra 6.0, mystere 6.0 etc)even up with an N20? You set the rules so the N20 is the scratch boat. Open up the beam width to 10' so all the 20s can play. But then you will no longer be the scratch boat. That's called B class(as in A,B,C,D) Tornado dominated it into non-existence. No reason to re-invent the wheel.
[Re: orphan]
#235711 08/03/11 06:59 PM 08/03/11 06:59 PM |
Joined: Dec 2003 Posts: 1,066 Wellington, FL-Singer Island, ... cyberspeed
Posts: 1,066 Wellington, FL-Singer Island, ... | I see one small problem. The only boat that fits is the N20. Would you race an older design (Nacra 6.0, mystere 6.0 etc)even up with an N20? You set the rules so the N20 is the scratch boat. Open up the beam width to 10' so all the 20s can play. But then you will no longer be the scratch boat. I also find it interesting that the name was changed to OPEN when it eliminates the recent boats in the higher performance range. If you are going to create another F18 class that is two feet longer, you should leave it as F20. There is already an open class. If indeed you are trying to set a more open class at least set the width to the Nacra F20 Carbon. I am sure Nacra did a lot of research and found the 10'6" beam to be the best choice for a 20' boat. | | |
16,262
guests, and 1,190
