Also the string method is much easier/cheaper to rig up, just drill a couple small holes in the luff track and tie the string through a turning block, you are good to go, vs. buying and then trying to mount a bracket on the mast. And if you ever want to remove it or move it up or down, that's much easier with the string too.
