| Nacra not righted #236360 08/15/11 02:59 PM 08/15/11 02:59 PM |
Posts: 431 Netherlands | Hi all, last wednesday I went out to test my new GPS (which is just a fancy name for my brother's old phone) and I was having a blast on my old Nacra 5.2. Hit over 30 Km/h as I blew past lots of monohulls, waving politely of course, exactly the kind of speed I had in mind.
After a while I sailed on looking for bigger winds and more speed when the bigger winds found me and put the boat on its side in a second. This happened even though I had released the main (which I had been hand holding) but before I got the jib down.
Luckily my exit was graceful and I never even got my feet wet. Not like the last time I tipped and ended up hanging upside down from my ankle (turtling the boat)...
Anyway, so far so good, I thought and started to loosen the jib sheet and pay out the tangled up mainsheet. I got my rigting line, tossed it over and walked out to the tip of the bow. It was then that I noticed that I could not get the boat angled into the wind, the best I could do was get the hulls pointing straight into the wind. This meant that I could almost get the boat righted three times. Almost that is, with the mast way up in the air I was already already looking for a spot to grab the dolphin striker bar when the wind and waves blew the mast downwind and she sank back in, trowing me off balance and really p1ssing me off in the process. Luckily for me I was in a safe area drifting toward a nice gravel bank where I knew I could beach without any damage that would worry me.
I shoved the dagger boards in and decided to pull up the rudders to protect them while beaching. That's when I found out that a Nacra 5.2 can do a backward summersault while on its side. It was actually a pretty cool move, even if it came as some surprise! Again I managed to stay dry, just don't ask me how, it all went so fast. That put the mast to windward but by now I had drifted to the shore and the number of people around made righting the boat there too dangerous. Normally I can right this boat solo at the first attempt as I weigh in at 200# or slightly over.
Does anyone have any idea what could have prevented the boat from turning further into the wind like I wanted? (jib and main were both 100% loose and not snagged or anything) I had considered swimming the mast into the wind but the waves made me reconsider. Should I re-fit the righting pole I used to have or make me a righting bag after all? I have capsized and turtled a number of times, but never had any trouble righting this boat. What gives? Any ideas? Thanks, Dennis | | | Re: Nacra not righted
[Re: DennisMe]
#236364 08/15/11 04:00 PM 08/15/11 04:00 PM |
Posts: 12,310 South Carolina | If the wind and waves are too big, you may have trouble getting it to turn all the way into the wind. I've sometimes had some luck trying to get the boat to spin the other direction (I know, it's weird) by sinking the stern instead of the bow or by first submerging the bow until the bows are into the wind and then moving quickly to sink the sterns to complete the spin.
Last option; carry a small drag chute to tie to the bridle and drop in the water with a 10 foot line. This should hold the bow into the wind. You can right the boat with only the bows pointing into the wind if you can keep them there and let the sail fly like a wing. I've never tried this but we've talked about the option on here for a while.
Jake Kohl | | | Re: Nacra not righted
[Re: DennisMe]
#236372 08/16/11 06:39 AM 08/16/11 06:39 AM |
Posts: 571 Hamburg | Downhaul doesn't matter in this case: If you are able to get the boat partially up, the water runs of the sail anyway. I guess it was 25kts plus. The wind pushes so strong under the sail, that it is out of the water (more or less) and the bows turn into the wind. On my boat the mast is than in a horizontal position and doesn't touche the water any more. It is easy to get the boat half up, but than it bears away, the wind catches the tramp and this stops the righting (my boat starts sailing in this condition with me on the wrong side). Once I tried it three or four times without any success, finally I just jumped backward once the boat was half up and that did it. Here is it on video. Wind up 2:00min to see the capsize and attempts to get it up. It took me actually over 7mins to get it up. Or as Jake said, go backward to turn the boat. Normally it should work if the mast and bows are are pointing 45deg to the wind. Once the boat starts to right move forward quickly. Cheers, Klaus | | | Re: Nacra not righted
[Re: davefarmer]
#236373 08/16/11 07:04 AM 08/16/11 07:04 AM |
Posts: 606 Maryland | I like the drag chute idea. Are there sources for them, or is it something to construct or farm out to my sailmaker? Dimensions?
Bass Pro Shops carry an assortment. Just search drift anchor or drift sock.
Kris Hathaway | | | Re: Nacra not righted
[Re: DennisMe]
#236376 08/16/11 07:28 AM 08/16/11 07:28 AM |
Posts: 12,310 South Carolina | Ok, so the downhaul was maxed out. The traveller and mainsheet were really loose though with the clew hanging down almost vertically into the water. I'll be sure to undo the downhaul next time though!
I also forgot to mention I not only released the jib sheets but also roller-furled the jib. Thinking about it last night I figured that was probably a dumb thing to do in this case. After all, a jib sausage filled with water is probably quite heavy.
I'm gonna try Jakes approach next time, especially with the added cartwheel effect if I go out on the stern too far. If I can do that consistently it means I can always get the mast to windward easily by spinning the whole boat around at once. I'm not too keen on bringing aboard more hardware. With the drift as it is and the lake not overly wide I normally only get a couple of tries in before getting blown onto shore.
Dennis I keep thinking about adding this system ... and now that I think about it and have my trampoline in my truck ready to drop off to my fix-it guy, I may have him sew a tight pocket with flap under the trampoline for a future chute. All it takes is a piece of 1/8" vectran, the chute (which is very compact), and a carabiner to clip onto the bridle. I would tie the end of the 1/8" line to the dolphin striker post where it would live. If needed, open the pocket, extract the chute, toss it into the water and clip the biner to the bridle. As a bonus, with it tied to the dolphin striker, you can quickly just gather it up and pull the chute up to the biner to deal with it later if you have other issues to tend to (like a lost crewmember). We're still planning on doing some distance racing and it would be nice to have this as a backup plan. Also keep in mind that the chute will slow the boat through the water and (hopefully) prevent it from accelerating once righted...These spin boats like to turn and accelerate when initially righted which can create a safety issue.
[Re: Kris Hathaway]
#236379 08/16/11 08:20 AM 08/16/11 08:20 AM |
Posts: 12,310 South Carolina | I like the drag chute idea. Are there sources for them, or is it something to construct or farm out to my sailmaker? Dimensions?
Bass Pro Shops carry an assortment. Just search drift anchor or drift sock. Cabelas.com would also be a decent source.
[Re: waynemarlow]
#236381 08/16/11 08:40 AM 08/16/11 08:40 AM |
Posts: 5,525 | Dennis:
Sorry for all your trouble but now I don't feel quite so alone.
I never have difficulty righting the boat, at 230, but getting back aboard is a problem. I'm thinking of a way to use a bucket system from the down hull. Deploy the bucket, have a seat or stand on the down hull and haul away. When the boat rights I'd already be aboard. A BIG bucket would overcome all the problems you're having and act as a drogue as well.
Cheers!
http://store.catsailor.com/pc/showsearchresults.asp?pageStyle=H&resultCnt=10&keyword=righting+bag&submit=Go+%3E%3E
Pete Pollard Blade 702
[Re: davefarmer]
#236396 08/16/11 07:41 PM 08/16/11 07:41 PM |
Posts: 12,310 South Carolina | Here's Bass Pro Shops' offerings(thanks Kris!)
http://www.basspro.com/Bass-Pro-Shops®-Drift-Anchor/product/90906/-1340050
Anyone want to suggest sizing for the 18HT and the ARC 22? Thanks!
Dave here's another one. make sure it has weights and floats in it to make it pop open quickly and easily (it looks like the one Dave linked has them in the photo). Cabelas Drift Sock I have no idea on size - but these are big! As tight as they wrap up, I don't think it hurts going a little bigger...I was thinking about the Large one with a 38" mouth and the collapsing strap. I've got our trampoline guy sewing in a 12" pouch on the bottom of the trampoline with a heavy duty velcro flap for one of these. I'll give it a try next time we're out in any breeze.=
#236400 08/16/11 10:12 PM 08/16/11 10:12 PM |
Posts: 3,224 Roanoke Island ,N.C. | Here's Bass Pro Shops' offerings(thanks Kris!)
Dave here's another one. make sure it has weights and floats in it to make it pop open quickly and easily (it looks like the one Dave linked has them in the photo). Cabelas Drift Sock I have no idea on size - but these are big! As tight as they wrap up, I don't think it hurts going a little bigger...I was thinking about the Large one with a 38" mouth and the collapsing strap. I've got our trampoline guy sewing in a 12" pouch on the bottom of the trampoline with a heavy duty velcro flap for one of these. I'll give it a try next time we're out in any breeze.= It'll be interesting to see that thing drop out ,by mistake, on a mark rounding.
[Re: Team_Cat_Fever]
#236405 08/17/11 07:22 AM 08/17/11 07:22 AM |
Dave here's another one. make sure it has weights and floats in it to make it pop open quickly and easily (it looks like the one Dave linked has them in the photo). Cabelas Drift Sock I have no idea on size - but these are big! As tight as they wrap up, I don't think it hurts going a little bigger...I was thinking about the Large one with a 38" mouth and the collapsing strap. I've got our trampoline guy sewing in a 12" pouch on the bottom of the trampoline with a heavy duty velcro flap for one of these. I'll give it a try next time we're out in any breeze.= It'll be interesting to see that thing drop out ,by mistake, on a mark rounding. Yeah, thought of that. I kept asking my sail/fabric guy for plastic buckles but he insisted on velcro with a pull tab. BUT, I'm not going to carry that around the cans. That will be a distance racing only setup where we might not be able to depend on anyone but ourselves. And now that I think about it a little, I don't think I'll hook the line up to anything. it will have two carabiners - one for the dolphin striker post and one for the forestay bridle..that way, Todd doesn't get to see me put on the brakes.
[Re: waynemarlow]
#236434 08/18/11 06:42 AM 08/18/11 06:42 AM |
Posts: 246 Kiel, Germany | As an experiment try facing your boat directly into wind on the beach without any main sheet on, now tighten the downhaul and see what happens, you maybe surprised. Mine becomes like a cat on a hot roof, bouncing around all over the place.
Any idea why this is the case? Pulling the downhaul should flatten the sail, reducing the camber.
F18: C2 / A-Cat: Minelli
20,023
guests, and 1,305
