Prindle 18 help #236469
08/18/11 03:42 PM
08/18/11 03:42 PM
catman Offline OP
catman  Offline OP
Anyone know what the front beam inside bolt is screwed into? Plate or nut. I'm guessing plate.
Re: Prindle 18 help [Re: catman] #236500
08/18/11 11:57 PM
08/18/11 11:57 PM
Q
Quarath Offline
Quarath  Offline
Q
Pretty sure it goes to a long bar under the hull deck lip on the inner lip of the hull but I can't be certain without a a visual inspection.
Re: Prindle 18 help [Re: Quarath] #236503
08/19/11 04:29 AM
08/19/11 04:29 AM
cyberspeed Offline
cyberspeed  Offline
That is correct. Solid piece of stainless steel bar that is drilled and threaded.
craig van eaton
Supercat 20
TEAM CYBERSPEED
www.TeamCyberspeed.com
Endurance Series
www.SailSeries.com
Re: Prindle 18 help [Re: cyberspeed] #236504
08/19/11 06:20 AM
08/19/11 06:20 AM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
He asked about the inside bolt, which is through bolted with a nylon locking nut and washer on the inside of the hull. You have to go through the inspection port to access. You will need a fairly long wrench to reach the nut. There is probably reinforcement glassed in the area.
Re: Prindle 18 help [Re: cyberspeed] #236505
08/19/11 06:21 AM
08/19/11 06:21 AM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
Re: Prindle 18 help [Re: Hullflyer1] #236531
08/19/11 12:27 PM
08/19/11 12:27 PM
catman Offline OP
catman  Offline OP
Thanks, I couldn't see in there because there is a home made cooler in each hull that blocks view/access.
Re: Prindle 18 help [Re: catman] #236544
08/19/11 03:59 PM
08/19/11 03:59 PM
V
Ventucky Red Offline
V
There should be a hole on the inside of each hull.... right under the beam that has a plug in it. Take the plug out and that will give you access to the nut.
And don't lose that plug, they aren't being made anymore as are a lot of Prindle parts...
Re: Prindle 18 help [Re: Ventucky Red] #236545
08/19/11 04:16 PM
08/19/11 04:16 PM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
They are still in the rear for the rear crossbar, but not in the area of the front cross bar unless the boat is from the mid 70's
Re: Prindle 18 help [Re: Ventucky Red] #236546
08/19/11 04:16 PM
08/19/11 04:16 PM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
Re: Prindle 18 help [Re: Ventucky Red] #236557
08/20/11 06:35 AM
08/20/11 06:35 AM
catman Offline OP
catman  Offline OP
This boat does not have plugs forward. Issue resolved. Thanks.
Re: Prindle 18 help [Re: Ventucky Red] #236573
08/20/11 11:35 PM
08/20/11 11:35 PM
Q
Quarath Offline
Quarath  Offline
Q
That's only on the rear beam not the front. Also Murrays has plastic caps to fill the holes of you lose the plugs but they are a very tight fit and might need some sanding around the holes to get them in. Also the plug is not there to keep water from filling your hulls. The small section the hole goes into is only access for the recessed screw in the rear beam track. it can only hold about a cup or so of water so even without the plugs it is not big deal.
Re: Prindle 18 help [Re: Hullflyer1] #236574
08/20/11 11:38 PM
08/20/11 11:38 PM
Q
Quarath Offline
Quarath  Offline
Q
Which inside bolt on the front. I thought there is only one on each side of each hull and each one goes to SS threaded bar under the deck lip.
Re: Prindle 18 help [Re: catman] #236575
08/20/11 11:39 PM
08/20/11 11:39 PM
Q
Quarath Offline
Quarath  Offline
Q
Ok that is awesome. How good of a job did they do please post pictures. I'd love to see how it looks.
0 registered members (), 321 guests, and 55 spiders.
