| Re: Prindle 18 help
[Re: Ventucky Red]
#236573 08/20/11 11:35 PM 08/20/11 11:35 PM |
Posts: 57 | There should be a hole on the inside of each hull.... right under the beam that has a plug in it. Take the plug out and that will give you access to the nut.
And don't lose that plug, they aren't being made anymore as are a lot of Prindle parts... That's only on the rear beam not the front. Also Murrays has plastic caps to fill the holes of you lose the plugs but they are a very tight fit and might need some sanding around the holes to get them in. Also the plug is not there to keep water from filling your hulls. The small section the hole goes into is only access for the recessed screw in the rear beam track. it can only hold about a cup or so of water so even without the plugs it is not big deal. | | | Re: Prindle 18 help
[Re: Hullflyer1]
#236574 08/20/11 11:38 PM 08/20/11 11:38 PM |
Posts: 57 | He asked about the inside bolt, which is through bolted with a nylon locking nut and washer on the inside of the hull. You have to go through the inspection port to access. You will need a fairly long wrench to reach the nut. There is probably reinforcement glassed in the area. Which inside bolt on the front. I thought there is only one on each side of each hull and each one goes to SS threaded bar under the deck lip. | | | Re: Prindle 18 help
[Re: catman]
#236575 08/20/11 11:39 PM 08/20/11 11:39 PM |
Posts: 57 | Thanks, I couldn't see in there because there is a home made cooler in each hull that blocks view/access. Ok that is awesome. How good of a job did they do please post pictures. I'd love to see how it looks. | | |
3,459
guests, and 106
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online3,694 2 hours ago | | |
