Nacra MKII #238574
10/04/11 08:05 AM
10/04/11 08:05 AM
Wilmington,NC
Dlennard Offline OP
Dlennard  Offline OP
Wilmington,NC
I am putting together a new MKII and like some new features, but am disappointed about others. What do other owners think?
Like
The new rubber nonskid on the decks
The new boards and rudders finish looks great and the carbon trailing edges
The boom has a thicker wall and cam cleat for the outhaul
The boat finish looks better (hopefully no cracks will show up)
Daggerboard wells look better and have nice shims on the bottom (hopefully they won't fall off like the F20c)
New material snuffer bag
The carbon tiller is awesome
Dislike
It would be nice if Nacra actually had a manual for the current boat you were putting together
Nacra footstraps would be nice
A jib downhaul led back to the tramp
A internal spin tack line
Get rid of the forstay chain plate with a turnbuckle (at least send one without the tab)
A loop with a knot instead of a pice of velcro for the jib attachment to forstay
A up what ever for the boards
Updated spreaders
Blocks and line to run the jib and downhaul out to the sides of the boat
16:1 downhaul
Plastic washers at the dolphin striker post and diamond tension bolt to help with corrosion
Heat shrink tubing around the swages on the rigging
Better line for the jib halyard ( the one they send breaks after a couple of uses)
Over all I like the new boat but for the extra money over the older version that we had you really don't get much extra just the rubber nonskid, newer boards/rudders, newer cut sails. What are others opinions ?
Re: Nacra MKII [Re: Dlennard] #238575
10/04/11 08:30 AM
10/04/11 08:30 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
I have been on the fence about a new boat vs the daggerboard conversion to my 08 Infusion. If you had to do it again, would you get a new boat, or do the conversion? BTW....the 08 (your old boat), is in immaculate condition with new Glaser sails.
Re: Nacra MKII [Re: ksurfer2] #238578
10/04/11 09:34 AM
10/04/11 09:34 AM
and the ta-ta spinnaker is the shiznit. Can you get sail-tape that looks like pasties?
But back to important things besides ta-tas, is there any significant hull shape or other design change from the MKI-MKII?
Re: Nacra MKII [Re: Dlennard] #238586
10/04/11 10:37 AM
10/04/11 10:37 AM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
Dave some of the things you mention are upgrades that can be purchased with the boat such as footstraps and 16:1 downhaul
The forestay chain plate, I am surprised you got one with the tab..most have been shipping without afaik.
The upfracker for the boards you can put in yourself but would be nice if they just did it.
What do you mean by updated spreaders?
The jib downhaul on the F20c I have found to be more of a PITA because it seems to always become uncleated.
Re: Nacra MKII [Re: pitchpoledave] #238588
10/04/11 10:51 AM
10/04/11 10:51 AM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
I agree on the jib downhaul. When was the last time you actually adjusted this on the water and it made a noticeable performance improvement? I don't think we ever touched it on the N20, and ours was rigged for on-the fly adjustment. I'm curious to hear other peoples opinions on this; I find the adjustment more useful on slower boats where you might want wrinkles in lighter air and less in heavier air. In the F16/F18/N20/F20 the speeds are usually high enough that you want things tighter.
Scorpion F18
Re: Nacra MKII [Re: samc99us] #238589
10/04/11 11:25 AM
10/04/11 11:25 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
I regularly adjust my jib downhaul between races.
Its absolutely essential (IMO) to change it between wind speeds.
Re: Nacra MKII [Re: ThunderMuffin] #238590
10/04/11 11:36 AM
10/04/11 11:36 AM
samc99us Offline
samc99us  Offline
I've only ever used 2 settings: tight (<10 kts breeze), and tighter (>10 kts breeze).
Scorpion F18
Re: Nacra MKII [Re: samc99us] #238591
10/04/11 11:47 AM
10/04/11 11:47 AM
Frequent adjustment on every F18 I've ever sailed - even on the Tiger and Infusion, when the skipper sent me out on the bow between races in big waves. LOVE the adjustment on the front beam.
Re: Nacra MKII [Re: John Williams] #238593
10/04/11 12:12 PM
10/04/11 12:12 PM
I think the operative phrase here was "between races". It's not like you'd be tweaking that thing as you round A or C marks, right?
Might be good on a straight-line distance thing in varying conditions, but I agree that it might clutter up the deck for something that's not used regularly
Re: Nacra MKII [Re: Dlennard] #238602
10/04/11 12:30 PM
10/04/11 12:30 PM
tburd Offline
tburd  Offline
I'll weigh in here, we've thrashed our Mk2 pretty good this season and worked all the bugs out.
Like:
Everything that you do, much improved fit and finish compared to previous boats. Small things like a new boom universal, velcro jib ties, and chafe protectors on the hull make a big difference. Deck foam is awesome. All rivets in the beams and spars have plastic washers for insulation.
A lot of your dislikes are options in the race package. Nacra footstraps, 16:1 downhaul, vulcanization tape, etc. The jib downhaul setup is really slick, a twin sheave thing leading to recessed cleats on either side of the front beam.
We opted not to get the race package (save a little money and build as we like). Things like the spin pole and board uphaul we build differently than some other boats. We'll put some detail photos up on microwindracing. Only a few complaints from us:
A boat set-up manual would be nice, basic stuff the tuning guides don't cover.
Stern plugs as an added option, not a necessary fitting.
Don't drill and rivet the jib block to the pole, easy to break.
Spreaders are clunky for sure (some boats are running awesome carbon ones!)
It's still basically an Infusion, but with a bunch of small tweaks to make for a better product. I don't think building a Mk1 today would result in a much cheaper boat. If you look at the big three builders, all the new designs are getting more expensive, I guess it's more of a market thing.
Re: Nacra MKII [Re: pitchpoledave] #238605
10/04/11 12:59 PM
10/04/11 12:59 PM
Wilmington,NC
Dlennard Offline OP
Dlennard  Offline OP
Wilmington,NC
We did get the race package and all the options and did not get the 16:1 or footstraps. They did put the cleats on the mast for the 16:1 though. Our jib downhaul is a 12"pice of line and a cleat on the jib. I did see the jib downhaul system you were talking about on the F20C manual even though Mike's F20c does not have it as well as a lot of other stuff.
I also could do without the boat plugs .
Re: Nacra MKII [Re: tburd] #238609
10/04/11 01:28 PM
10/04/11 01:28 PM
Wilmington,NC
Dlennard Offline OP
Dlennard  Offline OP
Wilmington,NC
Originally Posted by tburd
Like:
We did get the race package and no 16:1, jib downhaul lead to front beam or foot straps.
What does the new boom universal look like (mine looks the same as before)?
What chafe protectors on the hull?(the ones in the dagger board trunks?
Re: Nacra MKII [Re: ksurfer2] #238624
10/04/11 03:13 PM
10/04/11 03:13 PM
Wilmington,NC
Dlennard Offline OP
Dlennard  Offline OP
Wilmington,NC
We usually get a new boat every couple of years instead of just getting new sails and to help put more boats in the class. Since you have new sails the only thing you would be gaining is the boards and new nonskid and a few other little things. I don't know what the board conversion cost, but you would just have to do the math to see if it is good for you. We have not had the boat in the water and it is not even put together all the way yet so others will have to comment on the sailing abilities.
Re: Nacra MKII [Re: Dlennard] #238694
10/06/11 10:04 AM
10/06/11 10:04 AM
rexdenton Offline
rexdenton  Offline
After purchase and installation, new MKII daggerboards run about $3000.
Nacra F18 #856
Re: Nacra MKII [Re: rexdenton] #238696
10/06/11 10:14 AM
10/06/11 10:14 AM
What kind of $ do you have figured for installation?
Re: Nacra MKII [Re: Jake] #238700
10/06/11 10:47 AM
10/06/11 10:47 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
I have looked into the kit, it's kind of a no-brainer to install. Jake, you'll have no issues at all with it. Shoot me a PM with your e-mail address and I'll send you the install instructions.
Re: Nacra MKII [Re: ksurfer2] #238707
10/06/11 01:11 PM
10/06/11 01:11 PM
I didn't know they had a kit. Sounds good.
Re: Nacra MKII [Re: Jake] #238719
10/06/11 07:20 PM
10/06/11 07:20 PM
Toronto, Ontario
Toronto, Ontario
Re: Nacra MKII [Re: pitchpoledave] #238741
10/07/11 08:39 AM
10/07/11 08:39 AM
seeing how high those boards sit when you're not running them full-down, your crew will be needing a "hemmit and dem shoulda-ma-pads" on a fast reach in chop...
Re: Nacra MKII [Re: pitchpoledave] #238767
10/07/11 12:13 PM
10/07/11 12:13 PM
catman Offline
catman  Offline
Originally Posted by pitchpoledave
your boat is faster now!
LOL, is that guaranteed?
1 registered members (WorrellGal50), 427 guests, and 91 spiders.
Posts267,056
