Re: NACRA I20 [Re: Timbo] #238910
10/11/11 12:01 PM
10/11/11 12:01 PM
Originally Posted by Timbo
What's the Official Nacra gelcoat color for The Flesh Rocket?
I'm not sure that appears in any catalog. It was chosen / mixed specifically to match the front door of a sponsor's house.
Re: NACRA I20 [Re: Jake] #238913
10/11/11 01:54 PM
10/11/11 01:54 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
I just did a gelcoat job on ole Undecided (removed some old ugly rusted out footstrap bolts) and I used the stock West Marine gelcoat. It came out a bit more brown/yellow once it fully cured than the white of the rest of the boat.
So get the color matching kit for like $40 and do thorough testing before you actually lay down the final coats.
If all else fails, then contact Sher-fab and ask them if they have records of the white that performance cat/Nacra used.
Re: NACRA I20 [Re: Jake] #238916
10/11/11 07:28 PM
10/11/11 07:28 PM
TeamChums Offline
TeamChums  Offline
Chuck told me that one sponsor wanted the boat to be the color of a "Georgia Peach", so he told Jack they wanted a Peach colored boat. Jack saw the color that was listed as peach and asked Chuck if he was sure he wanted that color. Without looking at it (over the phone) ...the rest is history.
Lee
Re: NACRA I20 [Re: TeamChums] #238919
10/11/11 09:10 PM
10/11/11 09:10 PM
Key Largo, Fl
chipshort Offline
chipshort  Offline
Key Largo, Fl
Peach my butt, that boat was pink.
Re: NACRA I20 [Re: chipshort] #238921
10/11/11 10:19 PM
10/11/11 10:19 PM
"pink" or "disturbingly flesh colored" as JW dubbed it?
Re: NACRA I20 [Re: chipshort] #238928
10/12/11 09:30 AM
10/12/11 09:30 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
A very UN-ripe peach.
Isak Dinesen
E. B. White
Re: NACRA I20 [Re: Team_Cat_Fever] #238934
10/12/11 11:59 AM
10/12/11 11:59 AM
Will_R Offline
Will_R  Offline
Something that nobody else has mentioned it easing the main downwind.
If you've got the spinnaker up, no brainer, tight main sheet.
If you're in survival mode (30 isn't survival mode) with the spinnaker down, easing the main all the way is detrimental. If you keep the traveler closer to center and sheeted tighter, you won't be presenting as much direct surface area to the wind and therefore will have less force trying to pitchpole the boat.
And "Peaches" as the boat was called when it was first unveiled (how many years ago?).... Yeah, we all called it something else that started with a P when we saw it. Really should have faded the gel coat to a darker color at the front wink
Re: NACRA I20 [Re: Will_R] #238969
10/12/11 07:38 PM
10/12/11 07:38 PM
Portland, Maine
Portland, Maine
Guys the boat's name is Flesh Rocket.
Call it anything else and you'll hurt Bryan's feelings.
Re: NACRA I20 [Re: Will_R] #238973
10/12/11 11:10 PM
10/12/11 11:10 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Yeah, that's my operating principle as well, although the harder it blows, the deeper you have to drive to stay depowered, and eventually you're very close to dead down wind, and a possible accidental jibe. Which is very hard to recover from quickly enough, if at all. At which point you're probably better off taking the main down, difficult as that is. Particularly if you have to round up to head into the wind.
Dave
Re: NACRA I20 [Re: davefarmer] #238982
10/13/11 06:25 AM
10/13/11 06:25 AM
I
I20RI Offline
I20RI  Offline
I
how you gonna get the main down with a halyard lock going ddw?
Re: NACRA I20 [Re: davefarmer] #238984
10/13/11 07:07 AM
10/13/11 07:07 AM
Dave
I've spun out like that before too where the main caught air in a puff/shift and overpowered the rudders. The N20 pin head rudders don't have a whole lot of margin in that regard. If it surprise gybes on you when you have the sheet/traveler more centered, it will most definitely spin out and capsize.
Re: NACRA I20 [Re: Jake] #238986
10/13/11 08:19 AM
10/13/11 08:19 AM
so, the consensus seems to be that you're going to flip anyway, so pick the way that causes the least amount of damage/injury. I would presume a flip would be less injurous than a pitch pole..?
Re: NACRA I20 [Re: I20RI] #238993
10/13/11 09:51 AM
10/13/11 09:51 AM
mikekrantz Offline
mikekrantz  Offline
You're not going to do it DDW without a knife..
Go head to wind and drop the main.
Re: NACRA I20 [Re: evansdb78] #239000
10/13/11 10:25 AM
10/13/11 10:25 AM
JACKFLASH Offline
JACKFLASH  Offline
I finally watched the video last night. One of the things that caught my eye is that the mast was rotated out quite a bit. With 10:1 downhauls and squaretop mains pulling the rotator all the way in is the way to depower, which is the exact opposite thing you would do on say a Hobie 18 pinhead main.
Collin Casey
Re: NACRA I20 [Re: JACKFLASH] #239003
10/13/11 10:41 AM
10/13/11 10:41 AM
M
MN3
MN3
M
All the way or to the back beam bolts?
Re: NACRA I20 [Re: ] #239014
10/13/11 03:21 PM
10/13/11 03:21 PM
Will_R Offline
Will_R  Offline
Line that bad boy up as close to the boom as you can. Keeping the roatation close to the boom will also protect the mast by limiting the amount of swing and keeping the most rigid cross section lined up with the load. This will also, hopefully limit the whiping going on up there.
Also consider the downhaul: Hammering it opens the leech and exposes more sail area while DDW. IMO, ease it enough to keep the leech semi closed, however you want to keep it on enough to take power out and support the mast.
When it gets hairy and you have to go head-to, rememeber to ease the DH then as well.
Re: NACRA I20 [Re: Will_R] #239015
10/13/11 04:34 PM
10/13/11 04:34 PM
FL
sail7seas Offline
sail7seas  Offline
FL
Have you ever seen a plane fly backwards? or stalled?
Sailing stalled out (falling in an airplane) with managed projected area (twist or travel) is the key to reducing the excess of wind power you are experiencing. Every notice how slow it is when the crew oversheets the jib, he is depowering/STALLING the sails.
Have you ever seen a plane fly backwards? Sailing stalled out with managed projected area is the key to reducing the excess of wind power you are experiencing.
I addition to getting your weight back, pull your main traveller (& jib) near the center of the boat with minimal twist(sheet in tight), steering ALMOST Dead Down Wind. The closer the mainsail is to the centerline the smaller the projected sail area to the wind reducing wind force and pitchpoling. This sail configuration puts the sail in a STALL, like an airplane falling through the air NEGATING lift.
For steering DDW try using the following (3)three indicators,
that kind of 'check and balance' each other.
First, the bow wind indicator.
Second, pay attention to the feel on helm.
You can maintain a very slight weather to neutral helm with the sails stalled out.
If the helm goes a lee you WILL eventually jibe,
so push the helm away from you to get back to neutral helm.
If the weather helm helm increases pull the stick to get back/close to neutral helm.
Finally, with the jib strapped in (stalled) watch which side the jib FAVORS, as it oscillates
back and forth (how it behaves) out of the corner of your eye, and react accordingly.
This is useful when it is raining so hard you can not see the bridal fly.
Looking behind you, often helps, as you can sheet in before the puff (dark water)
hits you. Its fun watching the other boats go over next to you, as they let OUT their sails.
With the sails stalled the effective shape looks like a big fat wedge whose lee side isn't bending the wind near as much as you'd like, so the lift (component of the force at right angles to the apparent wind) is much less and the drag (component of the force parallel to the apparent wind) is excessive. The combination of the two is smaller and points aft, robbing the boat of the drive.
The above has kept me upright in registered 40kn wind in the "Round the Island" Florida race on a H20.
So downwind try sheeting in the jib in the puffs to stall out.
To depower more travel in the main to reduce projected sail.
To depower more and stall out reduce twist(sheet in)
and enter the 'Stalled Out Zone'.
(CAUTION sailing stalled in winds under 20nt is SLOW)
Re: NACRA I20 [Re: JACKFLASH] #239027
10/13/11 09:28 PM
10/13/11 09:28 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Thanks, That clears up some of the confusion I had with the strategies of the rotator on my N20 vs my previous Hobie 18.
Re: NACRA I20 [Re: sail7seas] #239033
10/14/11 10:18 AM
10/14/11 10:18 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
The more nulear it gets, I totally agree with this post.
IMHO
F-18 Infusion
#626- SOLD it!
0 registered members (), 20,249 guests, and 749 spiders.
Most Online22,490
Yesterday at 08:14 AM
