| Clearcoat suggestions #239210 10/20/11 08:35 PM 10/20/11 08:35 PM |
Joined: Jul 2001 Posts: 1,253 Columbia South Carolina, USA dave mosley OP
Posts: 1,253 Columbia South Carolina, USA | What do you guys suggest for clearcoating over West System on carbon and/or standard epoxy fiberglass?
| | | Re: Clearcoat suggestions
[Re: catman]
#239225 10/21/11 08:04 PM 10/21/11 08:04 PM |
Posts: 3,224 Roanoke Island ,N.C. | Read this, 6th post down. link Good link. Great info.
[Re: bvining]
#239282 10/24/11 04:41 PM 10/24/11 04:41 PM |
Posts: 3,224 Roanoke Island ,N.C. | If that's what you put on your beams of the DK , I wouldn't suggest it. Didn't hold up very well.
[Re: Team_Cat_Fever]
#239314 10/25/11 09:14 AM 10/25/11 09:14 AM |
Posts: 172 Anacortes | Just did some Cplate panels using Awlgrip 545 CLEAR primer with Awlcraft clear over the top. They came out absolutely beautiful! I never knew Awlgrip made clear 545 until last year. The 545 gives a great surface to block sand smooth and flat and with the Awlcraft topcoat on top it looks like its about 1/4" thick. Definitely the best high build clearcoat solution I have found. Awlcraft clear has UV inhibitors in it.
Anacortes Rigging.com Rigging and Yacht Services
2,526
guests, and 167
