| Mainsheet systems #239970 11/10/11 09:34 PM 11/10/11 09:34 PM |
Joined: Nov 2008 Posts: 136 Thorneside | QLD | AUS furr_ball OP
Posts: 136 Thorneside | QLD | AUS | Hey,
Looking at changing my older Harkens and sheet.
What are others using?
Looking at -
8:1 system using either - Ronstan 40 or 55 series Harken Carbo 40 or 57.
Are the Ronstan or carbo 40 enough for our mossies? Not center sheeting, sort of like it all at the traveller.
What diameter sheet are people running?
Drew........Furr_ball........Mosquito 1635
| | | Re: Mainsheet systems
[Re: furr_ball]
#240039 11/12/11 07:16 PM 11/12/11 07:16 PM |
Joined: Mar 2010 Posts: 77 Gippsland Lakes mitchellsailor
Posts: 77 Gippsland Lakes | The only issues using smaller blocks is it restricts the size of line you can use. (series 40 would be like 8mm) I personally think 8:1 is as much as anyone would ever use on a mozzi (read small girls)!! The norm is 6:1 with 10 or 12mm line keeping in mind larger diameter lines grip better in the ratchet but don't run as nicely and you find that the diameter differs greatly depending on brands and quality
Mosquito 1750 Bonnie-GLYC / Peninsula
The plan was simple.... Like my brother in law Phil, except this plan just might work!
[Re: Matt_Stone]
#240044 11/13/11 05:21 AM 11/13/11 05:21 AM |
Currently run 10mm with 6:1 on some old heavier harkens.
Had been thinking that if I went down to 8mm sheet it may be better to have the extra purchase of 8:1.
Part of the aim was weight reduction in the combined sheet block arrangement.
Ronstan website says 9mm for the 40 series orbits, anyone using 40 series orbits?
[Re: furr_ball]
#240057 11/13/11 03:53 PM 11/13/11 03:53 PM |
Joined: Jan 2007 Posts: 81 To windward of you! Sixth Element
Posts: 81 To windward of you! | hi,
i am using the ronstan 55 series orbits as a 6:1 system with 8mm line. i find that this is fine with the 8mm to hold onto. got it before the 40's came out other wise would probably use them, have them as my jib sheets and they are fine there no problems with them as a block.
"Sixth Element" 1782 MK2 w/spinnaker. Lake Bonney Y.C. National Sec. / S.A President / S.A Measurer / Commodore LBYC
[Re: furr_ball]
#240071 11/14/11 03:04 AM 11/14/11 03:04 AM |
Posts: 1,383 Kingston SE South Australia | I have 6 to 1 40mm Ronstan blocks from my old A class on my 15yo daughters Mozzy and no way would you run a full 8mm line through them easily. I found an orange 8mm line that was more like 7mm that runs beautifully through them, if you go into a marine store and look at 10 mm or 12 mm sheet I'm sure you will start laughing, you can tie a 100 ft yacht to the dock with it
[Re: furr_ball]
#240111 11/14/11 10:51 PM 11/14/11 10:51 PM |
Joined: Aug 2007 Posts: 142 3 weeks Newman WA 1 week Robe ... Brian P
Posts: 142 3 weeks Newman WA 1 week Robe ... | i have 7 :1 40mm harkens on my A class, running 6 mm sheet and im pulling over a 9.6m surperwing, they are fine, work great, i have 6:1 55mm on top of a 75mm ratchet on the stingray (basically an F18) and thats more than enough. i would say that 40mm for the mosquito is just fine. the only issue with the 40mm gear is that autoratchet is only available in 55mm which adds about $100 to the price. i bought my 40mm stuff from catsailor.net, arrived in 4 days, $15 postage.
Brian Partridge STINGRAY 580 "Fantasia" A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD BUT YOU CAN ROLL IT IN GLITTER!!!!!
[Re: furr_ball]
#240152 11/16/11 03:30 AM 11/16/11 03:30 AM |
Posts: 416 | | | | Re: Mainsheet systems
[Re: furr_ball]
#240226 11/16/11 07:33 PM 11/16/11 07:33 PM |
Thanks for the info from all, has helped greatly, helps to know what others use & works.
Yep, the ebay ones are too big and similar to what I have.
Probably go with the 40mm harkens as cannot find a ronstan triple block with cleat in the orbit 40, may go through mauri pro online as pricing is great.
22,305
guests, and 506
