Hull weight #241890
12/28/11 09:10 PM
12/28/11 09:10 PM
Gold Coast QLD
Damo Offline OP
Damo  Offline OP
Gold Coast QLD
Hi Guys
Just wondering if some one can point me in the right direction as I recently bought the Boyer moulds and about to start the laminating of the hulls.In order for the platform to be 55kg can any one tell me what one bare hull should weigh as a guide? A hull only weight would be best but a whole hull is fine, can any one help?
Damien
Damien 1820 Raw Prawn (under construction)!!!
QLD
Re: Hull weight [Re: Damo] #241920
12/29/11 07:30 PM
12/29/11 07:30 PM
Matt_Stone Offline
Matt_Stone  Offline
its usally between 25 to 27 kgs per hull. the other free kgs are used in the beams and tramp! all depends what weight of glass and resign you use.
Good luck
Re: Hull weight [Re: Damo] #241924
12/29/11 10:04 PM
12/29/11 10:04 PM
Scarecrow
Scarecrow
Damien,
this is the laminate I was going to use. Note, I've left the core 50mm shy of the gunwales so you can add the flanges after curing and clear of the areas where chain plates would fit as I was going to do composite chain plates which work best on a solid skin. If you want those drawings I'll email them through.
If you infuse like I believe you planned, this laminate should result in a hull skin weight of about 11-12kg leaving you heaps of weight for decks, bulkheads etc. whatevber you do, don't let anyone talk you in to using 0/90 cloth (of any kind) as any fibres wrapped around the hull will be worthless and make no contribution to your stiffness. [Linked Image]
Hull Laminate.jpg (707 downloads)
Re: Hull weight [Re: Damo] #241926
12/30/11 01:12 AM
12/30/11 01:12 AM
Gold Coast QLD
Damo Offline OP
Damo  Offline OP
Gold Coast QLD
Thanks Matt
Cheers for the info Scarecrow also, this helps heaps and yes I will be using the infusion process. A mate will be helping me with the core process as I have only used the infusion process with laminate only. Buy the way thanks for all the other gear you tossed in it was a surprise when it all arrived "Thank you"
Damien :-)
QLD
Re: Hull weight [Re: Damo] #241930
12/30/11 03:17 AM
12/30/11 03:17 AM
Scarecrow
Scarecrow
I still have a parcel here for you with plans and templates. Will drop off at the post office on Tuesday. Can you email me your postal address again.
Re: Hull weight [Re: Damo] #241940
12/30/11 07:54 AM
12/30/11 07:54 AM
Gold Coast QLD
Damo Offline OP
Damo  Offline OP
Gold Coast QLD
Hey Scarecrow check your PM
Thanks
Damo
QLD
Re: Hull weight [Re: Damo] #242145
01/07/12 06:44 PM
01/07/12 06:44 PM
First_Try Offline
First_Try  Offline
Damo,
Bare hull weight with deck on maximum 20.75Kgs. Most recent hull have been in the order of 19.0 to 20Kgs and the complete platforms have been coming in around 52 to 53 kgs.
Peter
Peter
First Try
Re: Hull weight [Re: Damo] #242146
01/07/12 08:33 PM
01/07/12 08:33 PM
Gold Coast QLD
Damo Offline OP
Damo  Offline OP
Gold Coast QLD
Thanks for that Peter, that gives me a good guide. The Glass suppliers are open from tomorrow so I can start getting the build under way
Thanks once again
Damien
QLD
Re: Hull weight [Re: Damo] #242147
01/08/12 06:23 AM
01/08/12 06:23 AM
C
craig5319 Offline
craig5319  Offline
C
Damien if you would like to know the Boyer layup to produce 19 to 20 kg hulls I have it all in my head as I used to build them. It's really only three layers of glass or what ever your choice and some unidirectional to reinforce areas with frames in it. If you want to know more email me [email protected]
Re: Hull weight [Re: Damo] #242149
01/08/12 08:19 AM
01/08/12 08:19 AM
Gold Coast QLD
Damo Offline OP
Damo  Offline OP
Gold Coast QLD
Thanks Craig I have sent you an e-mail
Damien :-)
QLD
Re: Hull weight [Re: Damo] #242150
01/08/12 08:23 AM
01/08/12 08:23 AM
Gold Coast QLD
Damo Offline OP
Damo  Offline OP
Gold Coast QLD
Hey Scarcrow As I'm back at work now if you haven't already sent the paperwork could you send it to my work address C/O BCS Awnings 3/20 Hutchinson st Burleigh Heads QLD 4220 as this will be the better address for me now.
Thanks once again
Damien :-)
QLD
Re: Hull weight [Re: Damo] #242211
01/09/12 05:52 PM
01/09/12 05:52 PM
Scarecrow
Scarecrow
On its way
0 registered members (), 636 guests, and 682 spiders.
