carbon repairs #241983
01/03/12 08:54 AM
01/03/12 08:54 AM
claus Offline OP
claus  Offline OP
Hi!
I have just switched to a boat with carbon daggerboards and I would like to ask if someone could comment on how to do little repairs (dents on the trailing edge from contact with dagger slot) with carbon boards. On my Tiger I just used gelcoat w/ sanding, is this the way to go for carbon too? Maybe black gelcoat? Or should I use some special epoxy resin?
Re: carbon repairs [Re: claus] #241986
01/03/12 10:33 AM
01/03/12 10:33 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Fill the chips with epoxy resin thickened with coloidal silica/cabosil
Sand it down
Colour it in with a black permenant marker pen
Overspray with lacquer
1200/1500 wet and dry
polish
Re: carbon repairs [Re: claus] #242019
01/03/12 06:48 PM
01/03/12 06:48 PM
catman Offline
catman  Offline
Use epoxy with some west system graphite for color, a little mil fiber for strength and thicken with cabosil ( It's called fumed silica now ) . If you can't get the graphite then what VMG said. I wouldn't use the black gel coat. No point in mixing polyester with the epoxy.
Re: carbon repairs [Re: claus] #242020
01/03/12 06:53 PM
01/03/12 06:53 PM
I'd gelcoat the whole thing white.
I like the exposed carbon on the edges on my last couple of Vipers, but you can never make it look 100% like you can if its just white.
Re: carbon repairs [Re: claus] #242023
01/04/12 04:30 AM
01/04/12 04:30 AM
claus Offline OP
claus  Offline OP
Thanx a lot, looks like epoxy is the way to go. I have found this product, which is black and seems to be thickened, do you think it is apt?
http://www.carbonmods.co.uk/products/epoxy-resin-repair-filler-sealer.aspx
Re: carbon repairs [Re: claus] #242026
01/04/12 08:38 AM
01/04/12 08:38 AM
You don't need a specialized product. Some regular epoxy (West System), cabosil filler, black dye (www.uscomposites.com). Mix in the filler to get a thick, almost peanut butter-esque, consistency, stir in a few drops of dye, use some tape as a guide on one side of the board, apply goo to the board. Let it cure, sand to a finish.
Re: carbon repairs [Re: claus] #242485
01/17/12 12:04 PM
01/17/12 12:04 PM
Palm Beach County
TheManShed Offline
TheManShed  Offline
Palm Beach County
I agree with Jake thickened West System and dye or pigment. Be careful when sanding to not cut into your "good" Carbon Fiber laminate around your repair and weaken the area.
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
0 registered members (), 634 guests, and 344 spiders.
