SNU snuffer question #242672
01/19/12 10:39 PM
01/19/12 10:39 PM
Madison WI
ewindsail Offline OP
Madison WI
Thinking about switching to a SNU system from my current mid pole system on a Blade 16. Is it worth the cost to switch. Pros and cons please Thanks in advance smile
Re: SNU snuffer question [Re: ewindsail] #242673
01/19/12 10:55 PM
01/19/12 10:55 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
I've got the SNU on my Stealth, HT, and ARC22, and I'm thoroughly pleased with all of them. I enjoy giving Dennis my money. I haven't seen the Blade system though, so can't say which is better.
Dave
Re: SNU snuffer question [Re: ewindsail] #242676
01/19/12 11:29 PM
01/19/12 11:29 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
I've had 4 snuffers. The stock Hobie one and 3 SNU's. I keep upgrading and selling my old one. Advantage smooth operation, no drilling easy use. Disadvantage, can't think of any.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: SNU snuffer question [Re: F-18 5150] #242679
01/20/12 06:47 AM
01/20/12 06:47 AM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Be sure to tie wrap tightly and tape securely, else the SNU will slide down the pole on retrieval; thereby constricting the opening and making deploying and retrieving very difficult.
Note: You can always rivet the SNU to the pole and this would never happen ... downside is that then you can't take the hoop off if you need to travel with the spin pole outside your trailer box.
USA 777
Re: SNU snuffer question [Re: tback] #242680
01/20/12 07:53 AM
01/20/12 07:53 AM
Maryland
Kris Hathaway Offline
Maryland
I've had the SNU on a Blade and Falcon. Sexy, very well designed, and nice cover. I preferred the none mesh bottom bag, less drag on the chute and never had any issues with water in the bag. Functionally, pretty much the same as a simple hoop. If I broke a hoop or needed to replace the bag then I would replace it with the SNU.
I always riveted it.
Kris Hathaway
Re: SNU snuffer question [Re: tback] #242682
01/20/12 07:59 AM
01/20/12 07:59 AM
K
kristin Offline
kristin  Offline
K
Be sure to tie wrap tightly and tape securely, else the SNU will slide down the pole on retrieval; thereby constricting the opening and making deploying and retrieving very difficult....
Don't ask him how he knows.....
Re: SNU snuffer question [Re: ewindsail] #242686
01/20/12 08:52 AM
01/20/12 08:52 AM
Contact your local AHPC representative when ready to order......... lol
Did you move your 20?
Re: SNU snuffer question [Re: ewindsail] #242691
01/20/12 09:59 AM
01/20/12 09:59 AM
M
MN3
MN3
M
Dennis is extreemly nice to work with. Although i didn't end up getting a snu, he was willing to customize one for my taperd pole, and next time i would go with him (esp after seeing them in person)
Re: SNU snuffer question [Re: ] #242710
01/20/12 11:01 AM
01/20/12 11:01 AM
Maryland
Maryland
Yes....Dennis provides very good support, is always looking to improve the SNU, and will customize hoops and bags.
Kris Hathaway
Re: SNU snuffer question [Re: Kris Hathaway] #242715
01/20/12 11:33 AM
01/20/12 11:33 AM
DUH
DUH
We have a SNU on the M20 and F18 that works great!
Re: SNU snuffer question [Re: ewindsail] #242717
01/20/12 11:53 AM
01/20/12 11:53 AM
M
MN3
MN3
M
i did have a question about the mesh bag i have seen, My friend has one on his TheMightyHobie18, and it looked a bit abrasive to me... any issues with that mesh wearing spins out faster than the old sail material ones?
Re: SNU snuffer question [Re: ewindsail] #242735
01/20/12 01:38 PM
01/20/12 01:38 PM
I didn't notice any more wear, but it did seem to take some more effort to snuff the spinnaker, even with them Homelko'd (sp)
Re: SNU snuffer question [Re: ewindsail] #242741
01/20/12 03:54 PM
01/20/12 03:54 PM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
I put the SNU on my Wildcat... worth every penny. I've seen too many poles scoop water and break at the rivets. The SNU addresses these problems and actually works better than any other snuffer I've used.
It might be a little bit harder to snuff with mesh instead of sailcloth at the bottom, but it's worth the reduced stress added by the lack of drainage in a full sailcloth snuffer bag. I've not noticed any added wear to the spinnaker from this.
Re: SNU snuffer question [Re: ewindsail] #242747
01/20/12 05:03 PM
01/20/12 05:03 PM
Madison WI
Madison WI
So are you saying that its better not to rivet the SNU on but to just tape and tie as shown on the web site
Re: SNU snuffer question [Re: ewindsail] #242748
01/20/12 05:14 PM
01/20/12 05:14 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
I have been tape and tying mine since 2007 never had it move on me.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: SNU snuffer question [Re: ewindsail] #242756
01/20/12 07:33 PM
01/20/12 07:33 PM
I don't even bother with the zip-ties. I just tape the length, and have had zero issues.
Re: SNU snuffer question [Re: Karl_Brogger] #242757
01/20/12 07:48 PM
01/20/12 07:48 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Ties and tape has worked fine for me as well.
Dave
Re: SNU snuffer question [Re: davefarmer] #242758
01/20/12 08:40 PM
01/20/12 08:40 PM
TeamChums Offline
TeamChums  Offline
I just ordered a Snu for my N20. Been meaning to for a long time. I don't thing the pole breaking at the rivets is an issue. I've broken at least 3 poles from driving the bows into a wave too fast and they have all broken at the bridal wire/pole support area. If the rivets were an issue, I would have had at least one failure there. Initialy I was concerned about drilling holes and rivets due to possibly creating a weak spot. In my experiences, that just hasn't been the case.
Dennis is constantly evaluating the Snu and what could be done better. I don't think there is any other system on the market that has that kind of "evolving" engineering behind it. Besides, Dennis is just a cool mofo.
Lee
Re: SNU snuffer question [Re: Karl_Brogger] #242836
01/23/12 10:01 AM
01/23/12 10:01 AM
M
MN3
MN3
M
good to know, thanks Karl (et al)
Re: SNU snuffer question [Re: ewindsail] #271588
04/20/14 10:43 AM
04/20/14 10:43 AM
E
Eric B. Holmes Offline
E
Hello Everyone,
[Re: Hobie 20 Midpole Snuffer System]
Please pardon the simple question, but I can't seem to find any contact info. for the SNU folks. Could you let me know their Phone/Website/email? I've already tried: [email protected] but no response. I'm looking for a Midpole snuffer for the Hobie 20. Here is a link to their installation instructions [ezsnu.com site not working...]:
http://www.gobarefootstudio.com/PDFs/SNU_H20Spin_1.pdf
Hobie 20 Profile showing Sloop Rig:
http://www.sailboat-data.com/images/bateau/31/2.jpg
Does anyone have the Skip Elliot standard dimensions for the Spinnaker using the SNU?
Many Thanks,
Eric
Blog:
http://porsche924s1987.blogspot.co.uk/p/hobie-20-mainsail-hoist-problem.html
0 registered members (), 5,361 guests, and 684 spiders.
Most Online7,274
4 hours ago
