| Need help..got a deal on old style H 17 rudder castings.. #243458 02/03/12 10:13 AM 02/03/12 10:13 AM |
Joined: Jan 2012 Posts: 28 Louisiana, Pcola Fl. Mark Milam OP
Posts: 28 Louisiana, Pcola Fl. | Hi everyone, Just by sheer luck..a guy in my town has a H 17 he is parting out and has both rudder castings and tiller tubes and EPOs.....I have a 2009 Wave with EZ lock rudders. When I go look at it, How do I know if its going to be the same castings as the old style Waves.....I 've heard that the H17 is the same, is there any year that they Weren't the same and would not fit???
Also, I think I need to change out my newer pintles...is it just the Top Pintle or is it both?? Also...since the boat is a 2009, maybe the pintle bolts will come loose, Do y'all recommend heating them with a soldering iron first (to soften up the locktite)...do they usually come unscrewed or do the Break the heads off most of the time???
Finally, would the upgrade be worth it, assuming I can get the whole set up for couple of hundred dollars...we haven't talked price yet...What is Fair???? I do want to set up the boat for the Best racing setup, realizing the lose nut on the tiller is hardest part to fix :D:D.
Thanks so much any help.
Mark Milam Louisiana. | | | Re: Need help..got a deal on old style H 17 rudder castings..
[Re: Mark Milam]
#243479 02/03/12 02:20 PM 02/03/12 02:20 PM |
Posts: 921 Alachua, FL | Umm I think the new style pintles will work with the old style casting and the Ez lock. I have a older Bravo with the old style casting (same part number at least) and it fits on the 09' wave pintles, so maybe I won't have to change the pintles and can go back and forth between rudder systems.
Mark Milam Louisiana I switched and didn't change the pintels. You may need to put a spacer on top of the housing at the lower position so the rudder can't move up and down. The spacer goes between the cotter clip and the housing. You will also need to order the proper Wave tiller tubes and swap them out. Not very expensive and it is easy to do. The last parts is that you will need a shorter x-bar and most of us use the H20 adjustable fittings on one end. It is risky to try and remove the pintel screws if they are stuck. If you are lucky, the are loose enough that you can slowly back them out without stressing (twisting) them. It is a good idea to check them from time to time so that they DON'T get stuck. If you break one, they are very hard to drill out cleanly. Once they have been twisted, they should be replaced because the metal has been stressed and is weak.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: Need help..got a deal on old style H 17 rudder castings..
[Re: Mark Milam]
#243486 02/03/12 03:15 PM 02/03/12 03:15 PM |
Posts: 921 Alachua, FL | Thanks...What about the EPO rudders that he has on the H 17....Does anyone know it the Holes should be the same that fit the casting for the WAVE......or would I need to fill them and Re drill..........
If I need to re drill is there a Template out there or something I can use???
Mark They should transfer without any problem. They are somewhat adjustable for rudder rake. but most of us just set them and forget them.
[Re: Mark Milam]
#243525 02/04/12 03:29 AM 02/04/12 03:29 AM |
Posts: 28 Louisiana, Pcola Fl. | Thanks everyone..I picked up the used set of H17 castings...Of course they need new cams and all...but the price was good and the guy lived in my home town....He throw in two EPO rudders...older ones...One is in real good shape, but the other one has about 3 in. ground off the bottom and some of the Glass is showing through, It was dragged down the road  ..... I guess its really hard to change the cams without backing off the Tension adjuster, Which was frozen solid....I drilled out the delrin bolt for it and got everything ready to just rebuild them, might as well do it now. Mark Milam Lafayette, La. | | | Re: Need help..got a deal on old style H 17 rudder castings..
[Re: Mark Milam]
#243534 02/04/12 08:46 AM 02/04/12 08:46 AM |
Joined: Aug 2007 Posts: 342 Indianapolis, IN - Midwest USA... IndyWave
Posts: 342 Indianapolis, IN - Midwest USA... | All that extra maintenance is why Hobie ditched those obsolete rudders several years ago. The EZ Locs are so much simpler and work much better. I think you'd be crazy to switch.
What - Me Worry?
2006 Hobie Wave 7358 "Ish Kabibble"
[Re: Mark Milam]
#243537 02/04/12 11:31 AM 02/04/12 11:31 AM |
Posts: 28 Louisiana, Pcola Fl. | Hi Indy, I'm Am CRAZY...:D .if I was Sane, you'd think I'd be messing around with boats :D:D.....Its a Love/Hate Relationship Well, I'm not really switching, I'm keeping both  ....the pintles on the new boat fit both styles,....So most of the time I'll have the EZ lock on when my daughters take the boat out or we drag it behind the Big Boat.....When I go out sailing, I'll just pop on the older style with the EPO's........ I never really had any trouble with Cams on my other Hobies from the past, once you get them adjusted right and a little preventive maintenance, they were good.....You are Definitely Right Though, the EZ lock is a No Brainer as far as simplicity... and I probably wouldn't have got the Older style if they weren't being sold by a guy in my town for a couple hundred bucks including EPO's....so that was part of it.......Besides, better spending money on Boats, then chasing Women and Gambling...:D:D........I have to keep one bad Vice  . Thanks for all the advice, much appreciated. Mark M. Lafayette La. | | | Re: Need help..got a deal on old style H 17 rudder castings..
[Re: Mark Milam]
#244161 02/16/12 05:21 PM 02/16/12 05:21 PM |
Posts: 3,969 | Here's a great way to remove the Derlin screw, without risking damage to the threads.
Get the biggest, longest screwdriver you can find that will fit in the screw head.
Heat the screwdriver until it is very, very, very hot (such as, put the tip of the screwdriver in the flame of a BBQ grill for a few minutes).
When it's hot enough, immediately put it into the screw and push it in as the Derlin melts. Make sure it goes into the screw at least 1/2 inch. DO NOT turn the screwdriver while doing this.
After you've made this new slot in the screw, remove the screwdriver. Pour cold water over the screw so the plastic hardens. Place the screwdriver into some cold water (such as in a cooler with ice).
When the screw and screwdriver are sufficiently cold, insert the screwdriver and remove the screw. If the screw is really stuck, it helps to use a pair of vice grips on the shaft of the screwdriver to add leverage when turning.
The beauty of this method is, you don't destroy the screw (it can be re-used) OR the threads, and everything you need can be found on the beach at a typical Hobie event!
Mike | | |
1 registered members (basket.case),
474
guests, and 38
