Page 3 of 3 1 2 3
Re: 7:1 to 8:1 conversion [Re: ] #244464
02/21/12 09:13 PM
02/21/12 09:13 PM
Originally Posted by MN3
I agree with Andinista and have recently added another block to my 8:1(even after reading this thread).
Sure i can now probably apply more force, but i don't want to. my goal was to need less strength to sheet to the same amount (i have shoulder issues).
Also i have a hard time believing the sheeting forces are the same on an f18 and n20... but i am not an engineer
Originally Posted by Andinista
Originally Posted by samc99us
I don't suggest modifying an existing block system. "Upgraded" an 8:1 system to a 9:1, but the existing block hardware was not beefy enough to handle the loads, found out the hard way 3 days into Tybee.
This statement suggests that an increase in purchase means necessarily an increase in max load applied. Is that really true? Don't we want to actually lower the pull to acheive similar results? Therefore more pulleys should mean lower load and not higher, except at the connections in both ends, where the total load is applied.
That's assuming that the goal is to distribute the load rather than apply more total tension. Maybe I'm wrong there.. Still, we are talking about a 10 to 15% increase in purchase, which comes with a decrease in overall efficiency because of the higher friction, therefore, the total tension is increeased in less than that. Would that be enough of an increment to break the blocks? If not rearranging blocks too differently (like the single block suggested in the first post) I think it shoudn't
Nacra 20 has a softer, bendier, mast so you have to be careful not to oversheet more so than the F18...but, we sheet them similarly.
Re: 7:1 to 8:1 conversion [Re: samc99us] #244467
02/21/12 11:21 PM
02/21/12 11:21 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
If you added a point of purchase you decreased the load on the hardware (blocks)itself. I think you were just using some old busted-butt, brokedown, shite. i've used an 8:1 modded to 9:1 since it was allowed by class rules ,at least 4 Tybees worth.
Isak Dinesen
E. B. White
Re: 7:1 to 8:1 conversion [Re: Jake] #244583
02/23/12 10:26 AM
02/23/12 10:26 AM
? I thought it was easier to oversheet Rob's wildcat than Forrest's N20 - both in 18+ conditions... maybe I was just seeing things? Or are you referring to the N20 with aluminum mast? I never considered that carbon mast particularly "bendy"???
Re: 7:1 to 8:1 conversion [Re: Andinista] #244586
02/23/12 10:38 AM
02/23/12 10:38 AM
Hernando, Florida
M
Mlcreek Offline
Mlcreek  Offline
M
Hernando, Florida
Jake,
Can you oversheet the N20 to the point of breaking the mast? Using the OEM 8:1.
Forrest
Forrest
I-20
USA 645
" There ain't enough rum in the drum!"
Re: 7:1 to 8:1 conversion [Re: Mlcreek] #244591
02/23/12 11:00 AM
02/23/12 11:00 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Originally Posted by Mlcreek
Jake,
Forrest
Not with a wuss like Stank pulling strings you can't! smile
Re: 7:1 to 8:1 conversion [Re: ksurfer2] #244593
02/23/12 11:10 AM
02/23/12 11:10 AM
+1 on that Karl!
I don't recall anyone ever breaking a mast from oversheeting a main (on any boat except maybe an H16 before they started raking the masts back). Even with the 10:1 setups?
Only N20 masts I've heard that broke were stuffing into a wave with spinnaker up (Mike H), letting the mainsheet go with the spin up, and getting tossed around at Jensen Beach during the T500. Maybe there are more out there?
Re: 7:1 to 8:1 conversion [Re: Andinista] #244603
02/23/12 12:24 PM
02/23/12 12:24 PM
Hernando, Florida
M
Mlcreek Offline
Mlcreek  Offline
M
Hernando, Florida
Karl,
Don't let him fool you....when others ain't looking, he begs me to pull them. Plus, I'm expected to keep the waves off of him.....was that skipper or slave driver?
Forrest
I-20
USA 645
Re: 7:1 to 8:1 conversion [Re: Mlcreek] #244614
02/23/12 12:53 PM
02/23/12 12:53 PM
Jake,
Forrest
I doubt it. In big air upuwind and sheeted properly, the I20 mast looks like a wind surfer rig to me. After sailing F18 for a while and coming back to the 20, I had to get used to seeing that much bend in the rig. I'm not sure you could do any damage even with 10:1 though.
Re: 7:1 to 8:1 conversion [Re: Andinista] #244654
02/23/12 03:11 PM
02/23/12 03:11 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
I've got a 10:1 on my N20 and I crank the hell out of it with absolutely no concern about my stick breaking.
Re: 7:1 to 8:1 conversion [Re: ThunderMuffin] #244668
02/23/12 04:16 PM
02/23/12 04:16 PM
Hernando, Florida
M
Mlcreek Offline
Mlcreek  Offline
M
Hernando, Florida
So with a 10:1, you crank your stick and don't break it?
Forrest
I-20
USA 645
Re: 7:1 to 8:1 conversion [Re: Mlcreek] #244669
02/23/12 04:29 PM
02/23/12 04:29 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Typical 20 drivers, always inappropriately cranking their stick. Speed tip, less cranking more sailing.
F18 USA 242
http://www.solarwind.solar
Re: 7:1 to 8:1 conversion [Re: Andinista] #244715
02/24/12 07:31 AM
02/24/12 07:31 AM
Daytona Beach Florida
O
orphan Offline
orphan  Offline
O
But they can say "My stick is bigger than your stick".
Re: 7:1 to 8:1 conversion [Re: David Ingram] #244718
02/24/12 08:04 AM
02/24/12 08:04 AM
Hernando, Florida
M
Mlcreek Offline
Mlcreek  Offline
M
Hernando, Florida
If Grand Pa can find the stick!
Forrest
I-20
USA 645
Re: 7:1 to 8:1 conversion [Re: ccat] #244886
02/28/12 09:27 AM
02/28/12 09:27 AM
M
MN3
MN3
M
Originally Posted by ccat
HM is right.
There is a much better way to reeve than the Harken diagram.
PM for a pic
Hi CCAT, i have PM'ed you 2x trying to see that diagram. Can you please send or post it?
Thanks
Re: 7:1 to 8:1 conversion [Re: Andinista] #244972
02/29/12 04:11 PM
02/29/12 04:11 PM
L
Lost in Translation Offline
L
We sail with 10:1 as well on the I20 and can really crank it. Amazing how much it flattens the sail along with the downhaul. No problem on the mast for us.
Re: 7:1 to 8:1 conversion [Re: Andinista] #244975
02/29/12 05:21 PM
02/29/12 05:21 PM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
I've run < 2" separation block to block on the N20 with a 10:1 purchase, the mast barely winces.
Scorpion F18
Page 3 of 3 1 2 3
0 registered members (), 2,472 guests, and 347 spiders.
Yesterday at 10:10 AM
