| Re: 7:1 to 8:1 conversion
[Re: ]
#244464 02/21/12 09:13 PM 02/21/12 09:13 PM |
Posts: 12,310 South Carolina | I agree with Andinista and have recently added another block to my 8:1(even after reading this thread). Sure i can now probably apply more force, but i don't want to. my goal was to need less strength to sheet to the same amount (i have shoulder issues). Also i have a hard time believing the sheeting forces are the same on an f18 and n20... but i am not an engineer I don't suggest modifying an existing block system. "Upgraded" an 8:1 system to a 9:1, but the existing block hardware was not beefy enough to handle the loads, found out the hard way 3 days into Tybee. This statement suggests that an increase in purchase means necessarily an increase in max load applied. Is that really true? Don't we want to actually lower the pull to acheive similar results? Therefore more pulleys should mean lower load and not higher, except at the connections in both ends, where the total load is applied. That's assuming that the goal is to distribute the load rather than apply more total tension. Maybe I'm wrong there.. Still, we are talking about a 10 to 15% increase in purchase, which comes with a decrease in overall efficiency because of the higher friction, therefore, the total tension is increeased in less than that. Would that be enough of an increment to break the blocks? If not rearranging blocks too differently (like the single block suggested in the first post) I think it shoudn't Nacra 20 has a softer, bendier, mast so you have to be careful not to oversheet more so than the F18...but, we sheet them similarly.
Jake Kohl | | | Re: 7:1 to 8:1 conversion
[Re: samc99us]
#244467 02/21/12 11:21 PM 02/21/12 11:21 PM |
Posts: 3,224 Roanoke Island ,N.C. | I don't suggest modifying an existing block system. "Upgraded" an 8:1 system to a 9:1, but the existing block hardware was not beefy enough to handle the loads, found out the hard way 3 days into Tybee. If you added a point of purchase you decreased the load on the hardware (blocks)itself. I think you were just using some old busted-butt, brokedown, shite. i've used an 8:1 modded to 9:1 since it was allowed by class rules ,at least 4 Tybees worth.
#244583 02/23/12 10:26 AM 02/23/12 10:26 AM |
Posts: 5,590 Naples, FL |
? I thought it was easier to oversheet Rob's wildcat than Forrest's N20 - both in 18+ conditions... maybe I was just seeing things? Or are you referring to the N20 with aluminum mast? I never considered that carbon mast particularly "bendy"???
[Re: Andinista]
#244586 02/23/12 10:38 AM 02/23/12 10:38 AM |
Joined: Jan 2007 Posts: 139 Hernando, Florida Mlcreek
Posts: 139 Hernando, Florida | Jake,
Can you oversheet the N20 to the point of breaking the mast? Using the OEM 8:1.
Forrest
Forrest I-20 USA 645
" There ain't enough rum in the drum!"
[Re: Mlcreek]
#244591 02/23/12 11:00 AM 02/23/12 11:00 AM |
Posts: 1,152 tampa, fl | Jake,
Forrest Not with a wuss like Stank pulling strings you can't!
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: 7:1 to 8:1 conversion
[Re: ksurfer2]
#244593 02/23/12 11:10 AM 02/23/12 11:10 AM |
Posts: 5,590 Naples, FL | +1 on that Karl!
I don't recall anyone ever breaking a mast from oversheeting a main (on any boat except maybe an H16 before they started raking the masts back). Even with the 10:1 setups?
Only N20 masts I've heard that broke were stuffing into a wave with spinnaker up (Mike H), letting the mainsheet go with the spin up, and getting tossed around at Jensen Beach during the T500. Maybe there are more out there?
[Re: Andinista]
#244603 02/23/12 12:24 PM 02/23/12 12:24 PM |
Posts: 139 Hernando, Florida | Karl, Don't let him fool you....when others ain't looking, he begs me to pull them. Plus, I'm expected to keep the waves off of him.....was that skipper or slave driver?
[Re: Mlcreek]
#244614 02/23/12 12:53 PM 02/23/12 12:53 PM |
Posts: 12,310 South Carolina | Jake,
Forrest I doubt it. In big air upuwind and sheeted properly, the I20 mast looks like a wind surfer rig to me. After sailing F18 for a while and coming back to the 20, I had to get used to seeing that much bend in the rig. I'm not sure you could do any damage even with 10:1 though.
[Re: Mlcreek]
#244669 02/23/12 04:29 PM 02/23/12 04:29 PM |
Posts: 3,906 Clermont, FL, USA | So with a 10:1, you crank your stick and don't break it? Typical 20 drivers, always inappropriately cranking their stick. Speed tip, less cranking more sailing.
[Re: ccat]
#244886 02/28/12 09:27 AM 02/28/12 09:27 AM | MN3
| MN3
Unregistered | HM is right.
There is a much better way to reeve than the Harken diagram.
PM for a pic Hi CCAT, i have PM'ed you 2x trying to see that diagram. Can you please send or post it? Thanks | | |
20,217
guests, and 543
