Alt 8:1 reeve #245307
03/07/12 09:09 AM
03/07/12 09:09 AM
M
MN3
MN3
M
Can anyone post the alternative way to reeve an 8:1?
Thanks
Re: Alt 8:1 reeve [Re: ] #245312
03/07/12 11:22 AM
03/07/12 11:22 AM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
... And I gave you hints ...
Ok, since I don't know how to post pic's/diagrams I'll walk you through it ... maybe someone can post a pic or diagram
1) Start w/ a Harken Quad Block for the top "Boom Block" and a Triple Block w/ becket and camcleat for the Bottom "Traveler Block" Now you need to modify/add to the bottom Block a "Single Block" attached above the camcleat to a eyestrap that you install on the (2) mach screws that hold the Camcleat on. Now here is the "BIG TRICK" ... the single block must be installed so that it is orientated across, orthogonally (that means 90* to ...)to the triple block ... I tie mine on w/ 1/8" spectra/vectra ... OK?
Now wreaving/threading as follows ....
2) Start w/ the mainsheet passing through the Triple block at the camcleat and center shive .... (the mainsheat exits the triple at the back).... up to the Quad Block to the second shive on the left (this can work both ways, I just picked "left"), thread the mainsheat through over the top from back to front ... next down to the Triple Block to outboard left shive, threading the mainsheet from front to back ... continue up to the Quad Block to the outboard left shive, again threading the mainsheat through over the top from back to front .... NOW FOR THE TRICK .... continue w/ the mainsheat down to the SINGLE BLOCK(!!!) attached to the Triple at the camcleat, threading the mainsheat from left to right through the "single block" ... now up to the Quad Block to the outboard right shive and thread the mainsheat through over the top from front to back ... now down to the triple block, threading the mainsheat through the outboard right shive back to front ... continue up to the Quad Block, the inboard right shive and thread through over the top front to back ... continue down and tie off at the becket on the triple. There you have it ....
Now when you weave/thread an 8X1 Mainsheat Stack this way you will notice that by having the "Single Block" attached to the camcleat the mainsheat will not rub anywhere as it crosses from the left side shives to the right side shives. This works best if the "Single Block" shive is the same size diameter as the "Triple Block's" shives (ie: smaller is NOT better). I use the Harken Quad as my "Top/Boom" block as I know of no other manufacture making a "Quad Block" (but there maybe someone) For the Traverler/Bottom Triple w/ Becket and Camcleat you can use any manufacture you please ... I determined my preference based on the finer adjustment ability and on the angle of the camcleat ... (I like Lewmars personally ... but the Harken "Carbo" series is good also )
(I can't explain "how" I can do this, but I can close my eyes and visualize things in 3D ... rotating it and viewing it from different angles ... something that amazed my Architectural/Engineering Drafting Teacher in those ol' days where you actually used a lead pencil and drew drawings on paper ....)
Harry Murphey
H18Mag/P19MX
Re: Alt 8:1 reeve [Re: ] #245314
03/07/12 12:24 PM
03/07/12 12:24 PM
M
MN3
MN3
M
Thanks Harry, Cheers!
Re: Alt 8:1 reeve [Re: ] #245339
03/08/12 06:45 AM
03/08/12 06:45 AM
Cairns FNQ
engineer Offline
engineer  Offline
Cairns FNQ
Seeming as though Ben Moon doesn't come here frequently, i'll pitch in
http://www.ronstan.com.au/marine5/product.asp?ProdNo=RF55410
Nacra 430 Rocket
Re: Alt 8:1 reeve [Re: engineer] #245342
03/08/12 10:12 AM
03/08/12 10:12 AM
M
MN3
MN3
M
Thanks but i am lookking for an image of how to reeve (run the lines), not of a quad block
Re: Alt 8:1 reeve [Re: ] #245343
03/08/12 10:52 AM
03/08/12 10:52 AM
Like this?
http://www.harken.com/OneDesign/F18.php
Re: Alt 8:1 reeve [Re: ] #245348
03/08/12 11:16 AM
03/08/12 11:16 AM
M
MN3
MN3
M
No Tony (but thanks)
That is the same method as i posted in this thread - http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=244097#Post244097
someone said he had an image and to PM him, but he has not responded to my 3 requests.
Re: Alt 8:1 reeve [Re: ] #245349
03/08/12 11:30 AM
03/08/12 11:30 AM
What kind of blocks do you have?
Re: Alt 8:1 reeve [Re: ] #245350
03/08/12 11:39 AM
03/08/12 11:39 AM
Y
yurdle Offline
yurdle  Offline
Y
I have mine almost identical to the pic in the other thread, with the exception that I swap #1 and #4, which uncrosses them.
Re: Alt 8:1 reeve [Re: ] #245351
03/08/12 11:41 AM
03/08/12 11:41 AM
M
MN3
MN3
M
harken 8:1 (upgraded to a 9:1 - I added a double eye-spliced line through the top quad, added a 40mm below)
ratch-o-matic 57(?)mm
Re: Alt 8:1 reeve [Re: yurdle] #245354
03/08/12 01:37 PM
03/08/12 01:37 PM
M
MN3
MN3
M
ditto yurdle, but it was mentioned in the previous thread (above), there is a better way to run the main.
Re: Alt 8:1 reeve [Re: HMurphey] #245355
03/08/12 02:00 PM
03/08/12 02:00 PM
Santiago, Chile
Andinista Offline
Andinista  Offline
Santiago, Chile
It's easy:
- Create your message using the "post reply" button at the top, instead of the "Quick Reply" box at the bottom.
- Click at "File Manager" (below, at Post Options)
- Select your file
- Click Add File
- Click Done adding files
Then sumbit your message.
You will attach the file to the message, it won't be visible yet but from there anyone can make it visible and can explain how.
Re: Alt 8:1 reeve [Re: ] #245356
03/08/12 02:13 PM
03/08/12 02:13 PM
Santiago, Chile
Andinista Offline
Andinista  Offline
Santiago, Chile
Ok, Step 2:
After sumbitting the message with the attached file, you will edit it to put the image:
- click the link of the attached file on your message, the image will open (on a different window)
- Right click on the image
- "Copy image url"
- Go back to your message
- Click Edit
- Place the cursor where you want the image
- click at the "Enter image" icon
- Click any of the options (non floating, left, right,..)
- At the text box, right click, "paste"
There you go
Re: Alt 8:1 reeve [Re: ] #245376
03/09/12 07:50 AM
03/09/12 07:50 AM
Cairns FNQ
engineer Offline
engineer  Offline
Cairns FNQ
Scroll down to the bottom of this page mate....
http://www.ronstan.com.au/marine5/mainsheet_systems.asp
Nacra 430 Rocket
Re: Alt 8:1 reeve [Re: engineer] #245382
03/09/12 11:04 AM
03/09/12 11:04 AM
M
MN3
MN3
M
Thanks but that is not the same.
That one has a double block on the bottom becket, i added a single and still have 9:1
Re: Alt 8:1 reeve [Re: ] #245420
03/11/12 09:15 AM
03/11/12 09:15 AM
Cairns FNQ
engineer Offline
engineer  Offline
Cairns FNQ
oh well, just trying to help mate....
Nacra 430 Rocket
Re: Alt 8:1 reeve [Re: ] #245425
03/11/12 12:15 PM
03/11/12 12:15 PM
Netherlands
DennisMe Offline
DennisMe  Offline
Netherlands
I think this is what Harry Murphey means.
At lest, this is a kind of exploded view of what I see in my mental image of his description..
Re: Alt 8:1 reeve [Re: ] #245435
03/11/12 08:03 PM
03/11/12 08:03 PM
HMurphey Offline
HMurphey  Offline
Yep ... that looks like it ...
Harry
Re: Alt 8:1 reeve [Re: ] #245483
03/13/12 08:35 AM
03/13/12 08:35 AM
M
MN3
MN3
M
Thanks to all (including engineer for trying!)
Re: Alt 8:1 reeve [Re: ] #246058
03/24/12 10:51 PM
03/24/12 10:51 PM
Y
yurdle Offline
yurdle  Offline
Y
I stumbled across it today. It's in the hobie tiger manual. The blocks aren't perpendicular...never seen that before.
0 registered members (), 14,899 guests, and 622 spiders.
Most Online15,551
9 minutes ago
