| Re: Infusion Main Halyard (not) Locking (ing)
[Re: Karl Funk]
#247022 04/15/12 06:51 AM 04/15/12 06:51 AM |
Posts: 93 | Just so everyone understands the very frustrating launch, this is the newer Infusion rig...
This was over 1 hour or work. Boat had to be flipped twice to look at the issue, finally flipped the boat to lock the ring on the hook.
Not using a bowline, so we are getting max hoist.
Knot forward Knot aft Reverse hook - retie Knot forward Knot aft Pull and reverse the main halyard Knot forward Knot aft Reverse hook - retie Knot forward Knot aft
With the hook that swivels do you need to notch the headboard so the headboard does not turn the hook when at max hoist hoisting? it looks like the top of the headboard actually can turn the hook when it hits the bottom of the "floating" hook.
I have sailed cats since 1991 and I have never had a locking issue as bad as this one with any of the rigs I have ever owned.
F18 USA 1273 Andrews 77 (SOLD) Melges 32 (SOLD) Formula18 Olympic 49er (FOR SALE) Always outnumbered - Never outgunned....
[Re: Karl Funk]
#247028 04/15/12 09:16 AM 04/15/12 09:16 AM |
Posts: 3,293 Long Beach, California | I'm not sure why it works, but try running the halyard up the other side of the hook - if it is on the starboard side, switch to port.
[Re: Karl Funk]
#247029 04/15/12 09:43 AM 04/15/12 09:43 AM |
Posts: 4,119 Northfield Mn | No experience with the Infusion, but on the AHPC boats, sometimes what direction the knot is tied matters, (I have no idea why), as in left over right or right over left. Also we use a double over hand knot.
My latest boat was a nightmare to hook and unhook. I tried every which way, and nothing worked consistently. I ended up making a tapered main halyard, splicing a loop on the end, and luggage tagged the ring on to the halyard. It too is crabby sometimes.
[Re: Karl Funk]
#247039 04/15/12 08:43 PM 04/15/12 08:43 PM |
Posts: 4,119 Northfield Mn | The Wildcat has a cool setup. The ring is sewn into the head of the sail, and you tie the halyard on I think. Except for scratching the bu-jesus outta the mast, I'm a huge fan of the skyhook.
[Re: Karl Funk]
#247057 04/16/12 09:28 AM 04/16/12 09:28 AM |
Posts: 297 | Todd's (WildTsail) suggestion is good. I sailed that boat and it works better than mine, which was done the conventional way. However, also check to see that the hook freely swivels. Ours would catch on the mast, and did not freely swivel. This made taking the main down a bit of a hassle, as turning the mast would also turn the hook too, as there is a loop on the inside of the hook that can catch. A little tweak with pliers and no problem.
Nacra F18 #856
[Re: Karl Funk]
#247082 04/17/12 08:58 AM 04/17/12 08:58 AM |
Posts: 93 | Thanks everyone, lots of stuff for us to try..... and good to know that we were not the only team struggling with this set up....
See everyone at the NE training Sunday.
[Re: Karl Funk]
#247350 04/22/12 09:57 PM 04/22/12 09:57 PM |
Posts: 93 | Switched to our new Glaser main - locked on the first try every time, every session, this weekend.... looks like a ring vs. a headboard and cutting the boltrope down 2 inches makes a huge difference.
[Re: Karl Funk]
#247390 04/23/12 02:46 PM 04/23/12 02:46 PM |
Posts: 4,119 Northfield Mn | Makes sense, the ring that hooks on the mast can't twist as easily with a head board.
[Re: Karl Funk]
#247394 04/23/12 03:45 PM 04/23/12 03:45 PM |
Posts: 3,293 Long Beach, California | FWIW, I did some rigging on a 2007 Infusion over the weekend that included a new main halyard - the team complained that they had significant difficulty both raising and lowering the main, to the point that their halyard broke from pulling it so hard. I used a low-stretch halyard, cleaned out the mast track, lubed it with good silicon spray, and filed two pinch-points that appear to have resulted either from trailering or dropping the mast. Got a "thank you" email last night indicating that the main went up and came down on the first try. Seasonally checking the track, a good cleaning to get out the salt and sand, and using a quality silicon spray is a good idea.
[Re: John Williams]
#247395 04/23/12 04:30 PM 04/23/12 04:30 PM |
Posts: 291 | Silicone spray? Wouldn't a dry tef/Mclube be better in that it won't attract sand and salt to stick to it.
[Re: Karl Funk]
#247420 04/24/12 09:00 AM 04/24/12 09:00 AM |
Posts: 606 Maryland | Hoisting the main is probably the most ritualistic operation I follow. I always use the same "Aussie" halyard ring. The knot is always tied the same and always facing aft. The halyard is always on the port side of the "hook". As a result, it is always a clean hoist and douse.
Nothing worse than being on a crowded "beach" and have your hoist ring hung up. Especially after a challenging day of racing and the beer is cold.
Kris Hathaway | | |
2,763
guests, and 299
