Jib triangle #247170
04/18/12 06:46 PM
04/18/12 06:46 PM
PTP Offline OP
PTP  Offline OP
Are the jib triangles on all the F16s the same? I believe they are, but wanted a second opinion.
Anyone have the measurements?
Anybody want to measure a their new F16 jib for me?
Re: Jib triangle [Re: PTP] #247174
04/18/12 09:06 PM
04/18/12 09:06 PM
Brisveagas
Aido Offline
Aido  Offline
Brisveagas
No they are all different. Yes I have the measurements for a few. No you can't have them. Just buy one from a sailmaker that knows the class.
If you are thinking of making your own don't bother, it's actually quite a difficult sail to get right. Some sailmaking software struggles to get it right as well.
Aido
Viper 288
Re: Jib triangle [Re: Aido] #247192
04/19/12 05:27 AM
04/19/12 05:27 AM
Brisveagas
Aido Offline
Aido  Offline
Brisveagas
Perhaps what you are after is the fore triangle. The measurement from the top of your bridal to the hounds. Hounds to the turning block or the main beam. And the measurement from the mast base to the bridal. That is your triangle. It varies between different types of boat quite a lot.
The only thing that will be the same about f16 jibs of different boat or manufacturers is the area which is < 3.7 square meters.
Aido
Viper 288
Re: Jib triangle [Re: PTP] #247194
04/19/12 06:00 AM
04/19/12 06:00 AM
PTP Offline OP
PTP  Offline OP
Thanks.... I guess
Re: Jib triangle [Re: PTP] #247200
04/19/12 08:50 AM
04/19/12 08:50 AM
Maryland
Kris Hathaway Offline
Maryland
They are different and continue to be tweeked. The attached fits a 2009 Falcon.
Kris Hathaway
Re: Jib triangle [Re: Kris Hathaway] #247202
04/19/12 09:02 AM
04/19/12 09:02 AM
Maryland
Maryland
I would add that you can order a new one for just over $500, made to the latest specs and with the latest material, and a LOT LESS AGGRAVATION (LOL)!
You still have a VMW Blade?
Kris Hathaway
Re: Jib triangle [Re: PTP] #247204
04/19/12 09:39 AM
04/19/12 09:39 AM
pgp Offline
pgp  Offline
I think Patrick has the sewing bug. It's surprisingly addictive.
Pete Pollard
Blade 702
Re: Jib triangle [Re: Kris Hathaway] #247206
04/19/12 09:46 AM
04/19/12 09:46 AM
PTP Offline OP
PTP  Offline OP
Kris,
Thanks. yes, still have a VWM Blade. Am I missing something though? Rje diagram is for a main, not a jib.
Re: Jib triangle [Re: PTP] #247213
04/19/12 10:39 AM
04/19/12 10:39 AM
Maryland
Maryland
LOL!!!! I got gypped! It is the main. Sorry, I do not have the jib. Exclusively soling back then and managed not to get the jib measured.
Kris Hathaway
Re: Jib triangle [Re: PTP] #247216
04/19/12 10:58 AM
04/19/12 10:58 AM
pgp Offline
pgp  Offline
Mine is blank as well. I get you some numbers this afternoon.
Pete Pollard
Blade 702
Re: Jib triangle [Re: PTP] #247233
04/19/12 03:45 PM
04/19/12 03:45 PM
Netherlands
geert Offline
geert  Offline
Netherlands
Hi,
The triangle on as Blade is pretty small; I have a couple of measurements and this one is about as big as possible, for a Blade.
JIB
s1 (luff) 5,47
perp. H1 1,245
area triangle 3,51
s1 (luff) 1,245
perp. P1 0,014
area segment 0,01
s2 5,3
perp. P2 -0,033
area segment -0,12
s3 1,25
perp. P3 0,062
area segment 0,05
s4 0,04
perp. H4 -0,17
area triangle 0,00
Area total: 3,45
Geert
Re: Jib triangle [Re: geert] #247237
04/19/12 04:24 PM
04/19/12 04:24 PM
Maryland
Maryland
Reminds me. Nacra's F16 sports a square top jib in their website photos.
Kris Hathaway
Re: Jib triangle [Re: geert] #247242
04/19/12 08:27 PM
04/19/12 08:27 PM
PTP Offline OP
PTP  Offline OP
Geert,
Thanks a bunch, that is what I am looking for. It also closely matches my rough jib measurements on my older than heck jib.
Re: Jib triangle [Re: PTP] #247288
04/20/12 06:39 PM
04/20/12 06:39 PM
Palm Harbor, FL
daniel_t Offline
daniel_t  Offline
Palm Harbor, FL
I was curious about this as well. Since the mast height and mainsail area are restricted, it basically means that all the boats are going to have the same size main (maybe some slight differences in the length of the foot depending on how full the leach is.)
However, if I remember right, the only restriction on the jib is its area. Although the leach and luff are indirectly limited by spinnaker hoist height, I doubt that anybody would want a jib that tall...
Daniel T.
Taipan F16 - USA 213
Re: Jib triangle [Re: daniel_t] #247296
04/21/12 02:56 AM
04/21/12 02:56 AM
limits on jib are max area and max lufflength
Re: Jib triangle [Re: Kris Hathaway] #247449
04/25/12 11:51 AM
04/25/12 11:51 AM
Pensacola, FL
Junior Offline
Junior  Offline
Pensacola, FL
Hunter at Schurr Sails in Pensacola can make a jib for whatever foretriangle you have. He is also able to print and cut out panels and send them to you for assembly. We have a few home sailmakers who like to put their own sails together.
Schurr Sails- 850-438-9354
Cheers,
Bert Rice Jr
Bert Rice Jr
Viper USA-3
Re: Jib triangle [Re: Junior] #247486
04/26/12 05:29 AM
04/26/12 05:29 AM
PTP Offline OP
PTP  Offline OP
Cheers,
Bert Rice Jr
HEY!!!
Thats me!
smile
Put on my F31 main yesterday that Hunter cut for me and I put together. first time I ever saw the thing fully unrolled. looks good aside from some small modifications I need to do
1 registered members (vasil), 512 guests, and 31 spiders.
