Spinnaker sheet #248708
05/22/12 08:36 AM
05/22/12 08:36 AM
waynemarlow Offline OP
OK next corner of the Spinny, I have used D12 as the halyard, it is soft and relatively easy on the hands, you can create alsorts of nice knots and the best bit, it doesn't burn the spinny like other halyards will when you don't quite get the snuffing bit right.
So what about using 3mm D12 for the sheet and put a cover or covers over it to bulk things up bit where we are handling it, some of the dedicated sheets are bulky heavy and least desirable, expensive. Any body been there done that ?
Re: Spinnaker sheet [Re: waynemarlow] #248711
05/22/12 08:41 AM
05/22/12 08:41 AM
pgp Offline
pgp  Offline
Not I! Just the opposite, I (most of us I think) strip the outer core off the halyard for some suitable distance. I destroyed my first spin by NOT stripping the outer core, this time very little problem.
Pete Pollard
Blade 702
Re: Spinnaker sheet [Re: waynemarlow] #248712
05/22/12 08:43 AM
05/22/12 08:43 AM
Satellite Beach, FL
Ringo Offline
Ringo  Offline
Satellite Beach, FL
I have not, but I'm a HUGE fan of FSE Robline Racing Sheet ...not the Pro version though as that is the double braid. I love the feel of the line. I have used this on two boats.
As for the halyard, Matt builds his with tapered spiderline. Works great. Just pull the core out so that when the head is at the top block that the cover goes a few inches up past the halyard cleat. Then you only need maybe 3 feet of core left in the cover, and strip all the core out of the rest. I never get kinks this way and the line is easy on the hands. The cover by itself on the douse will not burn the spin or the hoop.
George P. Harrison
Falcon F16 - USA 236
Re: Spinnaker sheet [Re: waynemarlow] #248743
05/22/12 03:04 PM
05/22/12 03:04 PM
Wayne;
Spi sheets - I used Marstrom Purple (or what ever it's called); light; does not hold water but not cheap.
Spi Halyard; Tapered D12 2.5mm to 5mm maffoli. was the Biz !
Re: Spinnaker sheet [Re: waynemarlow] #248767
05/23/12 02:27 AM
05/23/12 02:27 AM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
I used in the past 10mm (or 8mm I don't remember) PP line (the yellow stuff which is usually used as safety line). It is very light (swims on water), nice to your hands, does not kink and cheap. Drawback is that it starts to fluff after some time.
At the moment I use Liros magic sheet (9mm). Not as light and a bit more expensive but free of fluff.
Cheers,
Klaus
0 registered members (), 368 guests, and 521 spiders.
