| Re: tilt trailer plans
[Re: mikekrantz]
#211846 05/25/10 03:46 PM 05/25/10 03:46 PM |
Posts: 3,116 Annapolis, MD | check out Darren Bundock's old Tornado web site. They had a very simple rig for use at home and published plans on their site.
A super delux set of plans for a Tornado Flip trailer that grabs the boat by the cross beams and flips it over are available from Greg Scace or Kevin Cook.
crac.sailregattas.com
[Re: mikekrantz]
#211851 05/25/10 04:22 PM 05/25/10 04:22 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | Mike, I could build you a BADASS one. Dobb's trailer was pretty nice. I know it pretty well. Just depends on how much you want to spend. It really wont need to be that expensive. I could even start with an existing beach cat trailer and make it fit with a tilting frame.
Lee
[Re: TeamChums]
#211853 05/25/10 04:40 PM 05/25/10 04:40 PM |
Posts: 3,116 Annapolis, MD | Hmm... you really want to use a powerboat trailer... the wheel base is too narrow on a cat trailer... it will flip over in a cross wind. Scace built his for a 60 mph cross wind... tramp on.
[Re: Mark Schneider]
#211866 05/25/10 06:32 PM 05/25/10 06:32 PM |
Posts: 3,224 Roanoke Island ,N.C. | Hey Mark, PM Mike, Greg's number. I told him the other day that was probably the baddest tilt trailer there was. The ballast would be a pain, but there probably is no real way around that and be able to leave the tramp on.
[Re: TeamChums]
#211902 05/26/10 08:15 AM 05/26/10 08:15 AM |
Posts: 3,116 Annapolis, MD | Who said anything about a power boat trailer chief? I did... A beach cat trailer has the axle and wheels set to be inside an 8 foot cat beam.... not so good for 10 foot or whatever wide boat. A beach cat trailer is not a starting point for a tilt cat trailer that will remain right side up.
[Re: mikekrantz]
#212178 05/28/10 01:45 PM 05/28/10 01:45 PM |
Posts: 1,200 Vancouver, BC | My tilt trailer uses a max width torsion beam axle...these can be bought for less than $200 shipped and retrofit to any standard trailer width...that means you can mod any existing trailer to be a stable tilt trailer. This saves money and effort. FullTiltTrailer Site My Tilt system uses pivoting cradles on one hull and a single lifting post with a hand winch on the other hull to lift at the mainbeam/hull point. Lifting is a trival matter, taking less than 40 secs once the all is in place. No electric power/hydraulics needs. I built my trailer competely out of alu with no welds (which de-tempers alloy). Done ~20k miles on it in both tilted and fully disassembled modes. Had it tilted in 20 kt winds with tramp on with no issues. I have detailed plans available for purchase...pm me if interested.
[Re: mikekrantz]
#248823 05/24/12 06:39 AM 05/24/12 06:39 AM |
Posts: 43 | Go here: http://thebeachcats.com/pictures/?g2_itemId=11313and see the Tilley tilting trailer. 1. Takes an ordinary cat trailer. 2. Cut the axle and insert piece for max width. 3. Build frame which bolts on. 4. Go wherever. Been using this for 10 or so years now. If it's blowing over 20 or so crosswind, Tami strips the trampoline but even then all the thing does is fishtail some, which is hard on the tires but not really that bad. | | | Re: tilt trailer plans
[Re: TeamChums]
#248912 05/27/12 10:15 AM 05/27/12 10:15 AM |
Posts: 1,403 | Mike, I could build you a BADASS one. Dobb's trailer was pretty nice. I know it pretty well. Just depends on how much you want to spend. It really wont need to be that expensive. I could even start with an existing beach cat trailer and make it fit with a tilting frame. Build it first then sell it... Maybe Mike could distribute them for you.
[Re: mikekrantz]
#283673 10/22/16 06:19 AM 10/22/16 06:19 AM |
Joined: Oct 2013 Posts: 38 Lugoff, South Carolina Mac McCallum
Posts: 38 Lugoff, South Carolina | I have the plans you're talking about I believe. Wanted to make a tilt trailer for my SC20, but didn't do it. Tracked them down from David Tilley. If you want me to forward you the email with them pm me your email address or post it on here.
'09 Viper F16 USA102 A Cat USA 366
1 registered members (vasil),
512
guests, and 31
