stealth marine F16 needs a new daggerboard! #248931
05/28/12 12:32 PM
05/28/12 12:32 PM
Norway
sindrulf Offline OP
sindrulf  Offline OP
Norway
Suddenly today the leeward daggerboard broke in half while we were out in the waves. I am trying to contact John Pierce. Is he still active with his boats?
Stealth F16
Re: stealth marine F16 needs a new daggerboard! [Re: sindrulf] #248932
05/28/12 01:09 PM
05/28/12 01:09 PM
The Stealth F16 uses a standard 49er daggerboard. Any 49er supplier could sell you one.
John is still around and making to order. He can be contacted via email at stealthmarine(at)tiscali.co.uk
Re: stealth marine F16 needs a new daggerboard! [Re: sindrulf] #248933
05/28/12 02:16 PM
05/28/12 02:16 PM
Norway
sindrulf Offline OP
sindrulf  Offline OP
Norway
Wow! Nice to know. Thanks!
Stealth F16
Re: stealth marine F16 needs a new daggerboard! [Re: sindrulf] #248934
05/28/12 02:28 PM
05/28/12 02:28 PM
Norway
sindrulf Offline OP
sindrulf  Offline OP
Norway
Oh my god they were expensive!
Ovington Boats have them at 577GBP. Do you know of any other shops in europe?
Stealth F16
Re: stealth marine F16 needs a new daggerboard! [Re: sindrulf] #248935
05/28/12 02:52 PM
05/28/12 02:52 PM
Build one wink
Or repair the broken one, if you still have both parts..
Re: stealth marine F16 needs a new daggerboard! [Re: Rolf_Nilsen] #248938
05/28/12 03:34 PM
05/28/12 03:34 PM
pgp Offline
pgp  Offline
Speaking of building. Is vacuum bagging small parts (dagger board size) worth the effort? I'm doing something similar and it seems good vacuum pumps are expensive.
Pete Pollard
Blade 702
Re: stealth marine F16 needs a new daggerboard! [Re: sindrulf] #248941
05/28/12 03:57 PM
05/28/12 03:57 PM
Try Simon Hiscocks at Schock Sailing:
Schock
Re: stealth marine F16 needs a new daggerboard! [Re: pgp] #248949
05/29/12 01:40 AM
05/29/12 01:40 AM
If you are getting into building, get a vacum pump. If you have a compressor you could consider a cheap venturi vacum pump. Alternatively pick up a used refrigderator compressor from a recycling center.
Re: stealth marine F16 needs a new daggerboard! [Re: Jalani] #248964
05/29/12 04:23 AM
05/29/12 04:23 AM
waynemarlow Offline
waynemarlow  Offline
I think the later Stealths has a specific board and not the 49ER which the early boats had. Length was the same but very different in chord width.
I have a spare wider 49er style board which is sitting in the back of the garage which I could sell for not a lot of money, where are you based ?
Re: stealth marine F16 needs a new daggerboard! [Re: pgp] #248968
05/29/12 07:18 AM
05/29/12 07:18 AM
Pensacola, FL
C
Cab Offline
Cab  Offline
C
Pensacola, FL
Pete,
I have had great luck with one of these. No oil. Does not get hot even when running for 12 hours straight. Around $250 seems to be the going price on ebay for a used one.
http://www.ebay.com/itm/Welch-2585B...ps&hash=item43af0f721e#ht_522wt_1398
Chris
Trident F16
Re: stealth marine F16 needs a new daggerboard! [Re: sindrulf] #248970
05/29/12 08:09 AM
05/29/12 08:09 AM
pgp Offline
pgp  Offline
I'll give it a look thanks! What was the application?
Pete Pollard
Blade 702
0 registered members (), 21,105 guests, and 1,028 spiders.
Most Online23,137
29 minutes ago
