| Viper traveler line #251077 07/29/12 07:02 AM 07/29/12 07:02 AM | Mac m OP
| Mac m OP
Unregistered | My viper traveler line broke on me. It has the two tails that splice together into one line that runs through the cleat. Is there a place I can get this from? I don't know how to splice line. | | | Re: Viper traveler line
[Re: ]
#251079 07/29/12 08:13 AM 07/29/12 08:13 AM |
Joined: Feb 2005 Posts: 4,118 Northfield Mn Karl_Brogger
Posts: 4,118 Northfield Mn | Red Gear Racing, or I can make one and send it to you.
[Re: ]
#251080 07/29/12 09:14 AM 07/29/12 09:14 AM | Mac m OP
| Mac m OP
Unregistered | | | | Re: Viper traveler line
[Re: ]
#251086 07/29/12 08:51 PM 07/29/12 08:51 PM |
Posts: 217 Palm Harbor, FL | Mine broke recently as well. My Taipan has the same set-up as your boat. I bought 10 feet of 5/16" Staset, cut two feet off and bent it on one end to make the two tails.
When I rig the boat, I bend the traveller line to the mainsheet and off I go. So far the setup has worked out well.
Daniel T. Taipan F16 - USA 213 | | | Re: Viper traveler line
[Re: orphan]
#251103 07/30/12 09:42 AM 07/30/12 09:42 AM |
Posts: 4,118 Northfield Mn | Quick and easy. Pull about 8 inches of core out of double brand. Re run the core back thru the the cover and put a few stiches in. Tie the core to one side the cover to the other. That's pretty much what I sent him. Difference being I put the cover through the core, and the core through the cover, then there's no need to throw any stitches in. It locks down pretty hard. What I want to try doing is taking a short piece of dyneema, splicing an eye on each end onto the eye straps on the rear beam, then splicing an eye on the core of the actual sheet with the split tail going through that eye, then just pull the eye splice back into the cover a bit. There needs to be something there to lock the cover to the core on the sheet though, just stitching it would probably work fine. Doing that way should make it self centering, and should run pretty cleanly. Once in a while I get something that hangs up and I have to pump the traveller sheet to get it centered.
[Re: ]
#251104 07/30/12 09:55 AM 07/30/12 09:55 AM | Mac m OP
| Mac m OP
Unregistered | I guess it's time for me to learn to splice and stitch and pull cores and whatnot! | | | Re: Viper traveler line
[Re: ]
#251105 07/30/12 10:02 AM 07/30/12 10:02 AM |
Posts: 4,118 Northfield Mn | I used to think it was black magic voodoo, only for those with a few ocean crossings, a couple of Olympic medals, and maybe an America's Cup under your belt.
Its really simple, doesn't take much for tooling, and is a really handy skill to have.
[Re: ]
#251108 07/30/12 11:11 AM 07/30/12 11:11 AM |
Posts: 6,049 Sebring, Florida. | And a couple different sized, cheap knitting needles will help you open the weave to do the splices, and run the core/cover through each other.
Available at your local Walmart.
Blade F16 #777
[Re: Timbo]
#251151 08/01/12 07:14 AM 08/01/12 07:14 AM |
Joined: Dec 2008 Posts: 329 Chicago, Illinois USA TEH
Posts: 329 Chicago, Illinois USA | As Karl suggests, I bought a multi-size set of needles from Wal Mart. Cut them to length and sanded off the pink paint. Worked well for the larger sizes which were hollow. For the smallest size, I had to drill out the first 1/2 inch or so. This was a little tricky to keep from going through the needle wall. I also drilled a small hole through the end of each needle for putting in a stitch to hold the line while splicing.
With a little practice, I can now do a basic splice and I also learned to do a soft shackle.
BTW, I made two soft shackles and am going to try those with the traveller sheet to see if I can get consistent centering and avoid having to tie. The potential snag will be if its a hassle to run the sheet through the traveller with pre-tied knots.
Blade F16 USA 725
1 registered members (Talus1),
680
guests, and 163
