C20na ... downwind nospin. traveler question #253077
10/03/12 04:30 PM
10/03/12 04:30 PM
M
MN3
MN3
M
on thebeachcats someone posted pics on the new Nacra C20na.
Someone responded with this "If its nuking and you're in survival mode to get home, you'd be fine two sailing it without the kite, as long as you kept it deep, and STILL didn't travel out the main to keep the power manageable. Closer to DDW, if not exactly."
what are your thoughts on keeping the travler IN in heavy air (downwind/no spin)
Re: C20na ... downwind nospin. traveler question [Re: ] #253078
10/03/12 05:23 PM
10/03/12 05:23 PM
I only drop the traveler if I'm over stood.
Re: C20na ... downwind nospin. traveler question [Re: ] #253079
10/03/12 05:43 PM
10/03/12 05:43 PM
It depowers the boat some - but you're really vulnerable to a wind shift and auto-gybe. When the wind is up, it's usually pretty unstable. If that main gybes with it closer to center, it will overpower the rudders and you'll be practicing your synchronized swimming manuevers in short order.
Re: C20na ... downwind nospin. traveler question [Re: ] #253083
10/03/12 06:57 PM
10/03/12 06:57 PM
Arizona
AzCat Offline
AzCat  Offline
Arizona
I believe that there is video on youtube of a large planing mono hull pulling the Chinese Gybe while DDW in gale force survival mode. Great to reduce exposed sail area, but Gybe and you're Goose is Cooked.
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
Re: C20na ... downwind nospin. traveler question [Re: Jake] #253084
10/03/12 07:44 PM
10/03/12 07:44 PM
M
MN3
MN3
M
that's what i thought
thanks
Re: C20na ... downwind nospin. traveler question [Re: AzCat] #253085
10/03/12 07:45 PM
10/03/12 07:45 PM
M
MN3
MN3
M
I recall it
Re: C20na ... downwind nospin. traveler question [Re: AzCat] #253086
10/03/12 07:46 PM
10/03/12 07:46 PM
I've got the t-shirt.
Re: C20na ... downwind nospin. traveler question [Re: ] #253088
10/03/12 08:41 PM
10/03/12 08:41 PM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
Key is NOT to sail ddw. It's much easier and safer to reach a little with the traveler dropped, in conditions where hoisting the kite on a planning boat is dangerous.
The real question is what do you do when you are reaching at exactly 90 degrees to the wind and are fully depowered, traveled down and start running out of main sheet? This is with the crew on the wire, helm not because the waves are questionable.
We came to a consensus at the club this week but I'm curious what others think. Doesn't matter if is a spin boat or not for the most part but the main is a square top and fully powered up.
Scorpion F18
Re: C20na ... downwind nospin. traveler question [Re: samc99us] #253093
10/03/12 10:12 PM
10/03/12 10:12 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
You HTFU and drive it like you stole it.
Isak Dinesen
E. B. White
Re: C20na ... downwind nospin. traveler question [Re: samc99us] #253100
10/04/12 07:30 AM
10/04/12 07:30 AM
Try 32+ knots. You have no choice but DDW.
Re: C20na ... downwind nospin. traveler question [Re: ] #253103
10/04/12 08:34 AM
10/04/12 08:34 AM
pgp Offline
pgp  Offline
I've rarely been in such conditions. In survival mode I go head to wind as close as possible and still maintain steerage. Haven't drowned..yet.
Pete Pollard
Blade 702
Re: C20na ... downwind nospin. traveler question [Re: pgp] #253105
10/04/12 08:39 AM
10/04/12 08:39 AM
What if you want to go the other direction?
The correct answer is to drop the main and let the jib drag you along...if you're not still racing or convinced that it would still be faster than flipping a dozen times.
Re: C20na ... downwind nospin. traveler question [Re: ] #253106
10/04/12 08:47 AM
10/04/12 08:47 AM
pgp Offline
pgp  Offline
In survival mode I'm interested in survival.
Where I sail intense down bursts of high wind are fairly common, are of sudden onset, though not without warning and rarely last more than a few minutes. I wouldn't care to try handling the main in those circumstances.
Pete Pollard
Blade 702
Re: C20na ... downwind nospin. traveler question [Re: Jake] #253108
10/04/12 08:56 AM
10/04/12 08:56 AM
M
MN3
MN3
M
I can't see myself EVER trying this method(center the traveler in heavy air) on a $30,000 cat (let alone my 19 year old cat)
Re: C20na ... downwind nospin. traveler question [Re: pgp] #253110
10/04/12 09:03 AM
10/04/12 09:03 AM
M
MN3
MN3
M
we camp a lot in the bay spoil islands during the fall/spring. Often we wake up on sunday to much higher than predicted wind and must sail back to our cars at the causeway with literally up to 100lbs (or more) of gear/pets, etc...
There is no choice in which way you point the boat, only if you sail main or jib or mast only (done that a few times).. or if we are not going home and missing work on monday .
Re: C20na ... downwind nospin. traveler question [Re: ] #253111
10/04/12 09:12 AM
10/04/12 09:12 AM
pgp Offline
pgp  Offline
I'd opt for missing work...always.
Pete Pollard
Blade 702
Re: C20na ... downwind nospin. traveler question [Re: pgp] #253113
10/04/12 09:20 AM
10/04/12 09:20 AM
M
MN3
MN3
M
much easier to say/type that than actually do it ... often the food and supplies are done by then, people have jobs they can't just call in and miss, etc. Come to think of it... no one i have seen in my 6 years camping with this crew has ever stayed over sun night and missed work
Re: C20na ... downwind nospin. traveler question [Re: Jake] #253114
10/04/12 09:45 AM
10/04/12 09:45 AM
samc99us Offline
samc99us  Offline
Try 40+ gusting to 50+ knots. Balls of steel+DDW seem to be the consensus. And people were giving me **** for wanting reef points in a new TheMightyHobie18 main.
Scorpion F18
Re: C20na ... downwind nospin. traveler question [Re: samc99us] #253118
10/04/12 10:20 AM
10/04/12 10:20 AM
I agree with both Pete and Jake.
Hove-to if you think it's going to be a short-term thing and you're not dying to win a race. Wait it out and carry on when it's safer
If you absolutely, positively have to go in that direction now rather than later, fly the jib only (or bare poles and go slow). Even if you have to flip to initially get the main started down...
I don't consider it "racing" when it's over 25 kts. It's more like "(s)he who makes the fewest mistakes in handling". As Jake pointed out, flipping 10 times is most likely slower than flying a jib only downwind.
At the 35+ kts he mentioned, I'd be good with bare pole since the minute wind gets under that tramp, it's going to fly away from you and leave you bobbing.. sans boat - which is hardly advisable.
Re: C20na ... downwind nospin. traveler question [Re: samc99us] #253119
10/04/12 10:25 AM
10/04/12 10:25 AM
I don't know if reef points would help at all in that situation. If you're caught in that is one thing. Choosing to go out in that is entirely different. I would suspect in a white squall like that keeping the boat in one piece WITH the crew on it is first priority. Making forward progress against a lee shore or toward safe harbor is second. If it's DDW, then bare-pole makes the most sense, as you'll probably be going close to 8-10 knots anyway.
1 registered members (FredL), 446 guests, and 68 spiders.
