| Re: F18ht mast on I-20
[Re: bacho]
#253202 10/05/12 06:44 PM 10/05/12 06:44 PM |
Posts: 3,224 Roanoke Island ,N.C. | You guys have missed the point of the platform swap. The harm to the mast would be done by the increased weight of the platform creating more righting moment on the mast.Has nothing to do with the wires or any of that stuff. That being said I think the HT mast could handle the task fine with proper boat handling.
[Re: Team_Cat_Fever]
#253213 10/06/12 11:02 AM 10/06/12 11:02 AM |
Posts: 465 FL | If you are concerned about Buckling? http://en.wikipedia.org/wiki/Buckling>3.The boundary conditions have a considerable effect on the critical load of slender columns. The boundary conditions determine the mode of bending and the distance between inflection points on the deflected column. The closer together the inflection points are, the higher the resulting capacity of the column.< add SPREADERS if you are really concerned. | | | Re: F18ht mast on I-20
[Re: sail7seas]
#253262 10/08/12 11:23 AM 10/08/12 11:23 AM |
Posts: 5,590 Naples, FL | jeeze, just let the boy put it on there and have him take pictures or describe the results (snap or no snap).
[Re: bacho]
#253316 10/09/12 10:40 AM 10/09/12 10:40 AM | MN3
| MN3
Unregistered | I see in your original post you have new sails for an I-20. I am not sure if i missed this: is the goal solely to have a lighter mast or did you snap your current stick? I have one more option. I could get a blank tornado section from Forte for just under 3,000 clams shipped. Anyone have experience with Forte? | | | Re: F18ht mast on I-20
[Re: bacho]
#253320 10/09/12 12:27 PM 10/09/12 12:27 PM |
Posts: 3,906 Clermont, FL, USA | The i20 mast is snapped. Getting my sails re-cut for a softer mast isn't a big deal according to my sail maker and will cost about $300 to have it done. I know a guy that has a carbon I20 stick he wants to get rid of if you're intersted.
[Re: bacho]
#253338 10/09/12 03:31 PM 10/09/12 03:31 PM |
Joined: Jul 2005 Posts: 267 Ocean Springs, MS Capt_Cardiac
Posts: 267 Ocean Springs, MS | I would definitely go for an i20 mast if you can find one. I know someone with an extra I20 stick too. The HT is 3 ft taller and it uses a different mast ball size. I'm sure you can do it but it will be a serious pain to accommodate the change. Good luck and let us know how it goes. Cheers.
Capt Cardiac Ocean Springs Yacht Club Sailor Nacra20 - Flight of Ideas #5 | | | Re: F18ht mast on I-20
[Re: bacho]
#254702 11/14/12 01:22 AM 11/14/12 01:22 AM | Scarecrow
| Scarecrow
Unregistered | I was surprised that the spin bail on the HT was much lower. Did that ring any alarm bells? Make sure you get cash pledges from all those who advised you to buy this mast before you go ahead and rig it. | | | Re: F18ht mast on I-20
[Re: bacho]
#254709 11/14/12 09:18 AM 11/14/12 09:18 AM | MN3
| MN3
Unregistered | what was the cause of the original mast fail? | | | Re: F18ht mast on I-20
[Re: bacho]
#254718 11/14/12 10:35 AM 11/14/12 10:35 AM | MN3
| MN3
Unregistered | | | | Re: F18ht mast on I-20
[Re: bacho]
#254724 11/14/12 01:05 PM 11/14/12 01:05 PM |
Posts: 932 Solomon's Island, MD | Any suggestions on preventing this in the future? Its the second such incident I've heard of in the past month. Currently my boat is on the beach, rig up, with the dolphin striker tied to a screw-type stake (used for beach umbrellas). So far so good in winds up to 37 kts.
Scorpion F18
[Re: bacho]
#254731 11/14/12 01:23 PM 11/14/12 01:23 PM |
Posts: 1,121 Eastern NC, USA | Sand or hard packed soil? For sand, bury 2 2x4s a few feet deep and run lines from the 2x4s to the shrouds or trapezes. If hard pack, get more of the screws to add multiple tie down points.
Tom | | | Re: F18ht mast on I-20
[Re: bacho]
#254735 11/14/12 02:17 PM 11/14/12 02:17 PM |
Posts: 3,224 Roanoke Island ,N.C. | Go to the sides/ traps with 2 tie-downs ( stakes, boards trees, signs,etc.) and not your dolphin striker they can bend out. Don't ask me how I know. Plus you get less leverage to the middle, engineer boy. tshan is right about burying boards, I just use 2X 10s or 12s 2 or 3 feet long.
[Re: bacho]
#254740 11/14/12 03:44 PM 11/14/12 03:44 PM |
Posts: 1,121 Eastern NC, USA | I will add that if using the screw-in type anchors with an eyelet, make sure the eyelet is at or below surface level. the boat may slide a little and the eyelet can damage/puncture your hull. You may also want to secure your wing mast from rotating freely.
Tom | | |
285
guests, and 47
