| Re: Quick release trap harness
[Re: ]
#254791 11/16/12 06:32 AM 11/16/12 06:32 AM | Mac m OP
| Mac m OP
Unregistered | Do you use that system? Seems like it would be difficult to engage when going out? | | | Re: Quick release trap harness
[Re: ]
#254795 11/16/12 07:45 AM 11/16/12 07:45 AM | Mac m OP
| Mac m OP
Unregistered | That might be what I need especially since we have MM harnesses | | | Re: Quick release trap harness
[Re: ]
#254801 11/16/12 08:59 AM 11/16/12 08:59 AM |
Posts: 5,525 | Yes, I wouldn't call it difficult but it does take some getting use to. The (standing end?) uses a ball and there are a couple of different styles.
I've caught the standard hook on everything imaginable. This system has the additional benefit of not poking holes or dents in the hull when I'm scrampling back onboard after a pitch pole. And it seems to stay hooked a little better than the standard system.
Pete Pollard Blade 702
[Re: ]
#254802 11/16/12 09:21 AM 11/16/12 09:21 AM |
Posts: 12,310 South Carolina | I've got several different varieties of quick release harnesses and none of them work reliably over time. I do maintain them (cleaning, greasing, etc.). I've got one like the one you picture that has some detent keeper balls and I think that's probably the best type...although, on mine, the detents are too deep and it too has a hard time unlocking if it's loaded up. I've used the pin type with a retainer clip and they're terrible for corroding and even in good shape, if you try to release the hook with a side load on it, they don't like to come out. A good safety knife is a good idea too. I like the kinds with the replaceable razor blades like this (as long as you can find a good sheath): http://www.meltontackle.com/products/zak-s-safety-knife.html
Jake Kohl | | | Re: Quick release trap harness
[Re: orphan]
#254828 11/16/12 03:10 PM 11/16/12 03:10 PM |
Posts: 5,590 Naples, FL | Jake, can you design me one with explosive bolts?
[Re: samc99us]
#254833 11/16/12 03:21 PM 11/16/12 03:21 PM |
Posts: 1,152 tampa, fl | The trap hook is no where near Stank's freezer.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Quick release trap harness
[Re: ksurfer2]
#254840 11/16/12 04:56 PM 11/16/12 04:56 PM |
Posts: 5,590 Naples, FL | Ha! I was going to ask if Sam was married or not...
[Re: ]
#254851 11/17/12 03:51 AM 11/17/12 03:51 AM |
Joined: Jun 2009 Posts: 524 Petten Netherlands northsea junkie
Posts: 524 Petten Netherlands | I was really shocked seeing the opening pictures of this thread and reading Mac's story.
This is one of the sailors nightmares.
It reminds me on the small gap between between having a good and relaxed time on the water and being in total distress. It can happen in seconds or even a split second.
But it also belongs to the cat-sport. In the years I myself have add so many safety systems to my catamaran that I find it now and then a bit ridiculous. But this occasion inspires me to maintain this filosophy.
By the way what did "trapped in downhaul lines" excatly mean? Will a normal V-shaped windsurf hook prevent this?
ronald (with a 30 cm legknife, which can also be trapped under my net-tramp!)
ronald RAIDER-15 (homebuilt)
[Re: ]
#254855 11/17/12 06:57 AM 11/17/12 06:57 AM | Mac m OP
| Mac m OP
Unregistered | Her harness hook caught on the dyneema downhaul lines that run up the side of the mast thought the grommet on the sail and back down the other side of the mast. I couldn't pull the picture off of the AHPC site, but copied the link to it. The picture is on page 31
http://www.ahpc.com.au/images/pdf/VIPER%20Owner's%20Manual.pdf
[Re: ]
#254860 11/17/12 10:05 AM 11/17/12 10:05 AM |
Posts: 524 Petten Netherlands | Mac,
Probably she was caught by several lines together under the hook. That and the fact that these lines are normally under great tension explains everything. A V-hook will only help a little bit more in this situation.
The main problem in this kind of situations is panique!
If she was for instance caught sitting upon the tramp during shifting from site to site, she would have had normally no problem with shifting the ropes free from her hook. But seeking under water the ropes which you cannot see and then shifting them from the hook in the right direction is another matter!!! Especially when when you think you are drowning.
Only a real marine training would help her with this.
I hope sincerly that the fear will not pin down in her mind. It is important that she goes sailing again as soon as possible!
All the best.
ronald
[Re: ]
#254863 11/17/12 12:40 PM 11/17/12 12:40 PM | Mac m OP
| Mac m OP
Unregistered | I think it scared me more than her. I told the chase boat we were done for the day, but she insisted we continue! | | | Re: Quick release trap harness
[Re: ]
#254869 11/17/12 03:53 PM 11/17/12 03:53 PM |
Posts: 4,119 Northfield Mn | Ronald is right. panic is your worst enemy.
I've gotten wrapped up in stuff going over, and had a boat start to come over on me, being cool and keeping your head about you is the key.
The other is knowing how to crash, either picking where you are going to go sliding through, or grabbing onto something so you don't go whistling through a mess of lines is important and it comes with experience. I don't know the details, but I can imagine if she got hooked on that stuff, she could have just as easily planted a foot against the mast, which I've done plenty of times myself. The other thing I do is cling onto the hull like a spider monkey. Doesn't help if you're on the wire, but sitting on the boat it usually works. Then you just slide down the underside of the boat to the hull thats in the water.
[Re: Karl_Brogger]
#254953 11/19/12 01:53 PM 11/19/12 01:53 PM |
Posts: 5,590 Naples, FL | I was hoping that the transition from sideways to turtle was long enough for both of you to grasp the situation and avoid too much panic... It looked like she was working on the problem in a few of those photos before it went completely turtle. Probably just needed a good foothold somewhere to lift the hook off those lines...
I got tangled in something (likely the spin sheet or downhaul which was tied to the shroud) as Rob's Wildcat gybed on top of me and flipped which didn't give me as much time to react as the "normal" flips that I'm used to.
Definitely got the blood moving when all I felt over my head was hull, my harness was caught, and I didn't have a lot of air in my lungs.
Thankfully, an arm sweep of the hook to clear the line and a push to get my PFD clear of the shroud and I was good.
20,023
guests, and 1,305
