DIY Snuffer hoop and bag #25505
10/27/03 09:50 PM
10/27/03 09:50 PM
Victoria, Australia
Inland_Sailor Offline OP
Victoria, Australia
Has anyone tried to make their own Snuffer setup?
Any leads/tips on how to make one?
What materials are best?
Thanks in advance.
Magnum
Re: DIY Snuffer hoop and bag [Re: Inland_Sailor] #25506
10/27/03 11:24 PM
10/27/03 11:24 PM
Yeah....see the following link. I have some updates and photos that I'll probably post this weekend. I learned that the pelican striker on a Nacra 6.0NA bridle foil presents some unique problems to a mid pole snuffer.. hmmm. ("load torpedo bay number TWO!").
The Sailing Shack Snuffer Ring
Agassi, eat your heart out! [Re: Inland_Sailor] #25507
10/28/03 12:16 AM
10/28/03 12:16 AM
There're some guys running around the Gulf Coast with a Randy-designed contraption using (no joke) a tennis racquet. Don't have construction details - looks funny (ha ha AND strange) but it seems to be working pretty well.
Any of you other PSTs have any details of how to build that thing?
Re: Agassi, eat your heart out! [Re: John Williams] #25508
10/28/03 12:43 AM
10/28/03 12:43 AM
St Croix Virgin Islands
vicatman Offline
vicatman  Offline
heres a pic of the racket set up
Re: Agassi, eat your heart out! [Re: John Williams] #25509
10/28/03 09:01 AM
10/28/03 09:01 AM
I am pretty sure that only works on a uni-rig. but it allows you to set and douse from either side.
Midpole Snuffer problems with 6.0 foil? [Re: Jake] #25510
10/28/03 11:51 AM
10/28/03 11:51 AM
What problems are you running into with the mid pole snuffer on the 6.0 foil?
Thank for the info.
Re: Midpole Snuffer problems with 6.0 foil? [Re: ] #25511
10/28/03 11:56 AM
10/28/03 11:56 AM
The chute catches on the pelican striker as I'm trying to snuff it and literally gets wrapped around it. I've tried snuffing dead downwind, reaching, and upwind and it always blows back and catches. I'm considering moving the snuffer hoop out farther from the bridle but would be interested to hear if anyone else has tried a mid-pole snuffer on a 6.0NA. As you can see in this picture, there is quite a bit of stuff behind and above the ring.
Re: Midpole Snuffer problems with 6.0 foil? [Re: Jake] #25512
10/28/03 01:14 PM
10/28/03 01:14 PM
Ohio
TeamTeets Offline
TeamTeets  Offline
Ohio
Jake, what about using your pelican striker as the snuffer? Instead of making it round, make a triangular feeder with rounded edges that fits inside/around one side of the striker. That would get the bunch of sail in front of the foil.
Mike, Ohio
Re: Midpole Snuffer problems with 6.0 foil? [Re: TeamTeets] #25513
10/28/03 01:33 PM
10/28/03 01:33 PM
Oooooooo! I never even came close to considering that....I'm off to the drawing board! The jib tack might lend a clearance issue but I might be able to work around that. Thanks Mike!
Re: DIY Snuffer hoop and bag [Re: Inland_Sailor] #25514
10/28/03 01:36 PM
10/28/03 01:36 PM
I've got another question too....why is it that most snuffer rigs are setup for a port tack takedown yet the hoops are on the port side (the side opposite the spinnaker on a port tack)?
After looking at photos like this, now I'm wondering why I had so much trouble to begin with. The relationship of these bridle wires to the hoop is worse than that of my pelican striker. I wonder what I'm doing wrong?
Re: Midpole Snuffer problems with 6.0 foil? [Re: TeamTeets] #25515
10/28/03 03:10 PM
10/28/03 03:10 PM
You mean instead of using a tennis racket, use a pool ball rack?
Re: Midpole Snuffer problems with 6.0 foil? [Re: Mary] #25516
10/28/03 03:22 PM
10/28/03 03:22 PM
vicatman Offline
vicatman  Offline
check this one out....
Re: Midpole Snuffer problems with 6.0 foil? [Re: vicatman] #25517
10/28/03 03:50 PM
10/28/03 03:50 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
How big is the chute you are trying to snuff?
The T chute is 25 sq m.... the NE N6.0 is 28 sq meter (i think).... its a huge difference when going into the snuffer and sock.
crac.sailregattas.com
Re: Midpole Snuffer problems with 6.0 foil? [Re: Mark Schneider] #25518
10/28/03 04:33 PM
10/28/03 04:33 PM
I've got an Ulman chute that is probably much closer to the NE chute size than the Tornado (it totally eclipses the I20 chute). Can it be done?
DIY Snuffer hoop and bag [Re: Inland_Sailor] #25519
10/29/03 10:27 PM
10/29/03 10:27 PM
Victoria, Australia
Victoria, Australia
Thanks to all for the tips and further discussions.
Next problem!!
What diameter should the head/hoop be?
[color:"black"] [/color]
Magnum
0 registered members (), 1,140 guests, and 126 spiders.
