Trial of the best cameraposition according this forum #255326
11/29/12 03:38 PM
11/29/12 03:38 PM
Petten Netherlands
N
northsea junkie Offline OP
N
Petten Netherlands
A few weeks ago there was a discussion here about camerapositions.
So I changed my helmet camera into a camera mounted astern on a little pole on a support bar which I already had.
Tried it today.
A bit cold (3 degrees Celsius), a tail of northern swell and according the meteo above 5 Bft. Which wasn't by the way.
Because of this new camera position I was tempted to extend the scenes to other things then just the sea.
Watching everything back, I'm content with this cam position.
Forum thank you.
http://www.youtube.com/watch?v=kMKThlRmCGE&list=UL
ronald reeder
ronald
RAIDER-15 (homebuilt)
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255384
12/02/12 06:58 AM
12/02/12 06:58 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Interesting video. I liked your tow vehicle.
Camera position was good. The open tramp weave let a lot of water through. Not a big problem though.
Angle of view seemed a bit narrower than my gopro. Not much visibility of skipper/crew.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Trial of the best cameraposition according this forum [Re: rehmbo] #255387
12/02/12 07:42 AM
12/02/12 07:42 AM
catman Offline
catman  Offline
Yes, but good for holding channel locks!
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255388
12/02/12 09:11 AM
12/02/12 09:11 AM
Petten Netherlands
N
N
Petten Netherlands
The open tramp is essential in passing a high break. Though there are ofcourse also downsides to a net-tramp.
But sailing away from the beach with a normal tramp was sometimes impossible for me (pushed back).
Yes the angle of view is always the problem with cameras, I think. You never have the range of the human eye.
But with my Sanyo-camera, I think its rather good. Mind you; there is a straight horizon in the images and I'm hanging out almost just sidewards away from the camera.
I've no experience with a go-pro camera, but I'm now always out of the picture.
Which is good by the way.
ronald reeder
ronald
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255412
12/03/12 09:21 AM
12/03/12 09:21 AM
M
MN3
MN3
M
your dedication to sailing is admirable
or, your insane... or both smile
that makes me appreciate Florida all that much more
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255415
12/03/12 10:09 AM
12/03/12 10:09 AM
There is a nuclear plant just north of where he sails, could explain a few things wink
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255417
12/03/12 10:18 AM
12/03/12 10:18 AM
what kind of boat is that? Interesting seeing a singlehander sailing a sloop rig
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255419
12/03/12 10:25 AM
12/03/12 10:25 AM
Petten Netherlands
N
N
Petten Netherlands
(I)like you Mn3. Red your profile.
Tony, to make it even more worse: I'm literally the neighbour of the nuclear plant. I live nextdoor on the dike of the provincial road. Sometimes I get the post from them and viceversa.
When the nuclear reactor should explode, I'm the first to be just broken down in atomes.
For that reason I have less fear
ronald
ronald
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255420
12/03/12 10:30 AM
12/03/12 10:30 AM
Petten Netherlands
N
N
Petten Netherlands
Jay, you have to digg dowm in the files of this catsailor forum. I wrote both in the general forum as well as in the homebuilt section several times about my catdesign.
It's a homebuilt one-off 15 ft epoxy-carbon cat with full foam inside and based on the good old Prindle-15
ronald
ronald
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255432
12/03/12 01:27 PM
12/03/12 01:27 PM
Outstanding. Especially since you can actually FUNCTION at 3 deg Celsius. smile
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255438
12/03/12 04:50 PM
12/03/12 04:50 PM
Petten Netherlands
N
N
Petten Netherlands
Yes Jay and 3 degrees Celsius plus 20 knot makes a windchill of around minus 6!
But let me tell you a little secret of my place near the nuclear-plant. The reactor has a wateroutlet in the sea for her secundary coolwater.
In fact there is a blown-off each day via a pipe in the sea of this hot water.
(I used to walk/swimm to the end of this pipe for having a hot bubble bath in my studenttime).
So starting to sail alongside this pipe should theoretically make things more bearable. But practically it doesn't care a hang!
ronald
ronald
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255444
12/03/12 09:41 PM
12/03/12 09:41 PM
Palm Harbor, FL
daniel_t Offline
daniel_t  Offline
Palm Harbor, FL
What I like best when watching youtube sailing videos, and something that seems sorely lacking, is seeing how the crew handles transitions; tacking and gybing of course, but also wave crests and big wind changes.
Daniel T.
Taipan F16 - USA 213
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255445
12/04/12 05:43 AM
12/04/12 05:43 AM
Petten Netherlands
N
N
Petten Netherlands
But Daniel, honestly, you do know, don't you, that transitions are the necessary evil in catsailing.
I mean if I do not gybe at a certain moment (I never tack), I will endup in England. In your case you will endup in Afrika, I guess.
So you have to.
But shooting that movements with a onboard cam is always a disillusion. What you endup seeing are images of stiff figures that go on all fours laborious to the other side.
And in my case with the cam astern and doing a gybe you will only see a big tired face, flashing before the lens.
No, I carefully delete all these moments in my footage.
ronald
ronald
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255446
12/04/12 07:53 AM
12/04/12 07:53 AM
M
MN3
MN3
M
why do you never tack?
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255448
12/04/12 08:13 AM
12/04/12 08:13 AM
Petten Netherlands
N
N
Petten Netherlands
First its never necesssary and second I can't.
My 15 ft cat is 2.55 m beamwide and is for that reason (or some other?) difficult to turn through the wind. Only the oldfashioned stitchin/stitchout manoeuvre works.
Besides that, because my boom is rather low situated, when tacking, I have to squeeze my fat body on my belly to the other side.
I assure you, not a thrilling sight and very uncomfortable too.
Doing a gibe in 25 knots in high waves is not only exciting but feels more safe then tacking
ronald
ronald
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255453
12/04/12 09:13 AM
12/04/12 09:13 AM
M
MN3
MN3
M
haha, ok .. gotcha
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255584
12/08/12 01:46 PM
12/08/12 01:46 PM
maui
jollyrodgers Offline
maui
Thanks for the video Ronald. Now i'm waiting for part 2 where we find out what happens to the pliers.
Is it superhuman to sail in the cold north sea this time of year?
here is another camera angle idea:
you can make a pole for a gopro with a ski pole and tape as a shim for the gopro mount.. there are also videos showing how to use 3/4" pvc, endocarps, and an elbow fitting. search for gopro stick.
once you have the stick, hang the camera from the bottom of the stick. attach that to the boom or anywhere. i like the boom because it is stable but it moves when you let the traveler out. the single camera angle gets old pretty fast so this allows a small amount of variety.
Re: Trial of the best cameraposition according this forum [Re: northsea junkie] #255585
12/08/12 03:46 PM
12/08/12 03:46 PM
Petten Netherlands
N
N
Petten Netherlands
The pliers was a little practical joke to show it is a home-made cat (you'r the first who mentioned it).
I think that indeed this new cam position eventually will bore also.
And I don't consider myself as superhuman. Well, I obviously am an exception with regard to catsailing in wintertime.
But with windsurfing I have a lot colleagues at sea in this time. Not to mention the wave-surfers and the kitesurfers!
A time ago I've told this forum that most dutch beaches can't be reached by sailors in wintertime.
So I suppose there are enough dutch catsailors who would also like to sail in wintertime but can't.
(At least that's what I hope for the honour of my country)
ronald
ronald
Re: Trial of the best cameraposition according this forum [Re: ] #258478
03/22/13 08:14 AM
03/22/13 08:14 AM
M
MN3
MN3
M
gopro has a helmet mount system
Originally Posted by barrett
please suggest me how to fix a camera in a helmet, Actually I am going to a campaign and I want to capture all the travel and work which we'll do here. so thanks in advance.
Re: Trial of the best cameraposition according this forum [Re: ] #258479
03/22/13 09:32 AM
03/22/13 09:32 AM
I just bought a camera to use on the boat. I was headed toward a GoPro Hero Black edition but the reviews on Amazon were terrible (battery life issues, freezing up, etc.). I just ordered a Contour+2 instead that has some of the same features (using an iphone as a viewfinder / start-stop remote, setup, etc.) and will be trying it out at spring fever.
0 registered members (), 618 guests, and 65 spiders.
