| Re: F18ht mast on I-20
[Re: samc99us]
#254748 11/14/12 08:36 PM 11/14/12 08:36 PM | MN3
| MN3
Unregistered | Any suggestions on preventing this in the future? many of us in my area use these tree augers shown above with good results (up to about 45-50mph) on our beach. above that wind they pull out and old tiedown lines snap. In this picture from 2 years ago i have 3 tie downs in play. 1 on each side with rope going across the hulls, and one out of shot aft of the boat that has a line wrapped around my beams. these days i would move my tie-downs in a bit and also work my trap handles into my tie down rigging | | | Re: F18ht mast on I-20
[Re: ]
#254749 11/14/12 09:11 PM 11/14/12 09:11 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | A good outdoorsman would put those anchors in at an angle and get enough hold down power to hold that boat down in a Hurricane. I anchored a 6.0 in my yard with 2 of those ran in at an angle and it held through Hurricane Ike.
Lee
[Re: TeamChums]
#254752 11/14/12 10:20 PM 11/14/12 10:20 PM |
Posts: 602 Wilmington,NC | A good outdoorsman would put those anchors in at an angle and get enough hold down power to hold that boat down in a Hurricane. I anchored a 6.0 in my yard with 2 of those ran in at an angle and it held through Hurricane Ike. A good sailor would take the mast down in a Hurricane
[Re: Dlennard]
#254755 11/14/12 11:58 PM 11/14/12 11:58 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | A good sailor would take the mast down in a Hurricane
Wasnt my boat but it was in my yard. The anchors were already in, so I just tied it to them. Had bigger fish to fry getting my boats to safety. Allways fun to experiment with someone elses stuff
Lee
[Re: TeamChums]
#254768 11/15/12 09:10 AM 11/15/12 09:10 AM | MN3
| MN3
Unregistered | as i said "these days i would move my tie-downs in a bit and also work my trap handles into my tie down rigging" however, there is no way in the world i would leave my cat on the beach/or with the mast up in any hurricane. That would be grossly irresponsible, negligent and liable if/when your gear hurt someone/something A good outdoorsman would put those anchors in at an angle and get enough hold down power to hold that boat down in a Hurricane. I anchored a 6.0 in my yard with 2 of those ran in at an angle and it held through Hurricane Ike.
[Re: ]
#254769 11/15/12 09:53 AM 11/15/12 09:53 AM |
Posts: 1,304 Gulf Coast relocated from Cali... | Like I said, it wasn't my boat. However, by looking at those photos, it's clear to see why those anchors pull out when you have them straight in the ground. Not rocket science.
Lee
[Re: TeamChums]
#254771 11/15/12 10:29 AM 11/15/12 10:29 AM |
Posts: 3,224 Roanoke Island ,N.C. | Like I said, it wasn't my boat. However, by looking at those photos, it's clear to see why those anchors pull out when you have them straight in the ground. Not rocket science. yep, and using your traplines puts all of the resistant leverage at the top of your mast where it can do the most good against the wind blowing on your .... wait for it, MAST. Not that I'm one to be giving advice on tying your boat down this year. I know how to do it, sometimes I just neglect to do it.
[Re: TeamChums]
#254775 11/15/12 11:14 AM 11/15/12 11:14 AM | MN3
| MN3
Unregistered | They replenish our beach (causeway) with very soft and fine sand (think kids sandbox). I wouldn't trust anything to hold (besides buried boards) in +50mph wind when it gets water logged (regardless of angle). Even if i had a great, trusting system ... the cat parked down the beach often doesn't... I even carry spare augers to tie down other peoples boats in summer if i am concerned they can flip on me It is simple, winds predicted above 25-30, mast comes down. boat goes home. Like I said, it wasn't my boat. However, by looking at those photos, it's clear to see why those anchors pull out when you have them straight in the ground. Not rocket science.
[Re: bacho]
#255079 11/20/12 11:59 PM 11/20/12 11:59 PM |
Joined: Jun 2001 Posts: 733 Home is where the harness is..... Will_R
Posts: 733 Home is where the harness is..... | The Riba section is shorter and heavier than Marstrom's M20 mast, which is longer and lighter than the N20c mast. That mast holds ~380 lbs of crew weight with a 24sqm main and 24sqm spinnaker double trapped reaching.... granted, I've burned holes in it with my eyes where I think its going to let go, but they never have. Every one of those masts that have come to the US have broken, some to design/construction failure, others to flips or mismanagement on the water or beach. That mast has to be handled carefully!
There is one crazy project boat that uses the Riba section with a LOT of sail area and huge beam dimensions. The mast was easily the best part of the Jav HT.
[Re: Will_R]
#255086 11/21/12 07:38 AM 11/21/12 07:38 AM |
Posts: 12,310 South Carolina | The Riba section is shorter and heavier than Marstrom's M20 mast, which is longer and lighter than the N20c mast. That mast holds ~380 lbs of crew weight with a 24sqm main and 24sqm spinnaker double trapped reaching.... granted, I've burned holes in it with my eyes where I think its going to let go, but they never have. Every one of those masts that have come to the US have broken, some to design/construction failure, others to flips or mismanagement on the water or beach. That mast has to be handled carefully!
There is one crazy project boat that uses the Riba section with a LOT of sail area and huge beam dimensions. The mast was easily the best part of the Jav HT. That's not much of an endorsement....
Jake Kohl | | | Re: F18ht mast on I-20
[Re: bacho]
#255778 12/17/12 10:32 PM 12/17/12 10:32 PM |
Posts: 713 WA, ID, MT | The tapered cone and seat should be fine, that's quite similar to the orginal design. How will you attach the new/moved hounds? Just rivets into the tube makes me nervous, although that may be how the factory issue is attached. I sure wouldn't lower the hounds and have more unsupported mast above. And if you were to raise them, wouldn't you want to reconfigure the diamonds too? And then you've probably changed the mast bend characteristics, not a problem if you can have a main built to fit.
20,861
guests, and 656
