| Re: nacra 18 SQ
[Re: avalondarlyn]
#249091 06/02/12 09:24 AM 06/02/12 09:24 AM |
Posts: 12,310 South Carolina | some pictures might help us help you figure it out...hard to say based on "thicker chord".
Jake Kohl | | | Re: nacra 18 SQ
[Re: avalondarlyn]
#249107 06/03/12 10:29 AM 06/03/12 10:29 AM |
Posts: 1,403 | Take the boat sailing with both set on board, swap them out and see what set works better..
Also, M6.0 is the for a Mystere 6.0?
| | | Re: nacra 18 SQ
[Re: avalondarlyn]
#249288 06/06/12 02:28 PM 06/06/12 02:28 PM |
Posts: 1,403 | Thanks for all the info i'll try to get some pics. I have learned that the thicker naca 12ish are the original blades from a 5.2. and have the constuction issues as described above. I will try them both out.
Ventucky, yes a mystery cat. A Mystere 6.0 with the name Whisk. Things that make you go hmmmmmmmmmm.. | | | Re: nacra 18 SQ
[Re: avalondarlyn]
#251573 08/22/12 10:02 AM 08/22/12 10:02 AM |
Posts: 2,490 On the Water | if only that N20 sail could talk..... could it tell some great stories
Philip USA #1006 | | | Re: nacra 18 SQ
[Re: P.M.]
#251580 08/22/12 11:37 AM 08/22/12 11:37 AM |
Posts: 5,590 Naples, FL | holy s$it. That thing still looks great for all it's done...
| | | Re: nacra 18 SQ
[Re: P.M.]
#255835 12/20/12 09:38 PM 12/20/12 09:38 PM |
Posts: 12,310 South Carolina | if only that N20 sail could talk..... could it tell some great stories yeah, but you probably couldn't understand them because of the slurred speech.
[Re: Ventucky Red]
#255843 12/21/12 09:40 AM 12/21/12 09:40 AM | MN3
| MN3
Unregistered | A Mystere 6.0 with the name Whisk. Things that make you go hmmmmmmmmmm..
ha
| | | Re: nacra 18 SQ
[Re: Mike Fahle]
#255844 12/21/12 09:41 AM 12/21/12 09:41 AM | MN3
| MN3
Unregistered | How about a Mystere 6.0 boom? how about converting a sunfish mast or just an alum pole | | | Re: nacra 18 SQ
[Re: avalondarlyn]
#255877 12/22/12 09:07 PM 12/22/12 09:07 PM |
Posts: 13 | Sq looks great I put an I 20 sail on mine as well. Very close dimensions. Light weight mast had trouble flattening the main up wind in a blow. I built my own boom. Went to a local scrap yard and bought similar section
Ed Baldwin Central OH Bimare 18HT #4
538
guests, and 298
