nacra 18 SQ #249088
06/02/12 07:49 AM
06/02/12 07:49 AM
Hollister CA, Plano TX
avalondarlyn Offline OP
a few months ago i bought the peices of a 1979 NACRA 18 SQ. I now have a working boat. kinda. I know i'll have several questions. one thing at a time.
rudder foil/blade. the boat didn't have them. I now have aquired two sets. one set has a much larger/thicker chord.
what are the correct foils for the boat? what are the differences? which ones are better? etc?
Re: nacra 18 SQ [Re: avalondarlyn] #249091
06/02/12 09:24 AM
06/02/12 09:24 AM
some pictures might help us help you figure it out...hard to say based on "thicker chord".
Re: nacra 18 SQ [Re: Jake] #249095
06/02/12 10:11 AM
06/02/12 10:11 AM
catandahalf Offline
catandahalf  Offline
stick with NACA 12...are the foils original NACRA products? - if so make sure they are not flatish on one side. There was a molding problem with earlier versions of the rudder for the boat, and I feel the 18m2 was borrowing parts from the 5.2 and 5.8. The 5.2s suffered until we were able to get our hands on the Aussie foils which I am guessing were 13 - 15 NACA.
Modern foils are higher aspect and have less thickness. Jake has been in on this. I'm just glad to see one headed back to the beach. There is one at Birmingham Sailing Club that should be in the National Sailing Hall of Fame, and that is a fact.
Jim Leonard wastes no effort or gram of fat in his restoration work. Ya'll oughta see the Stilleto 23 he has restored. He does not allow black anodized aluminum go without a nice chrome polished appearance. His 5.2 looked NASCAR in the mid seventies.
Best of fortune with your 18m2 affair of honor.
Re: nacra 18 SQ [Re: avalondarlyn] #249107
06/03/12 10:29 AM
06/03/12 10:29 AM
V
Ventucky Red Offline
V
Take the boat sailing with both set on board, swap them out and see what set works better..
Also, M6.0 is the for a Mystere 6.0?
Re: nacra 18 SQ [Re: avalondarlyn] #249217
06/05/12 09:44 AM
06/05/12 09:44 AM
Thanks for all the info i'll try to get some pics. I have learned that the thicker naca 12ish are the original blades from a 5.2. and have the constuction issues as described above. I will try them both out.
Ventucky, yes a mystery cat.
Re: nacra 18 SQ [Re: avalondarlyn] #249288
06/06/12 02:28 PM
06/06/12 02:28 PM
V
V
A Mystere 6.0 with the name Whisk.
Things that make you go hmmmmmmmmmm..
Re: nacra 18 SQ [Re: avalondarlyn] #251572
08/22/12 09:28 AM
08/22/12 09:28 AM
a pic of my progress so far. first hoist new used sail. (nice). Excuse the mud Stewart Creek Park. Lake Lewisville. not a good launch spot. the list keeps growing of repairs and adjustments. thanks for your help again. still havn't switch out rudders. other more important repairs a.k.a. sail.
Re: nacra 18 SQ [Re: avalondarlyn] #251573
08/22/12 10:02 AM
08/22/12 10:02 AM
On the Water
P.M. Offline
P.M.  Offline
On the Water
if only that N20 sail could talk.....
could it tell some great stories
Philip
USA #1006
Re: nacra 18 SQ [Re: P.M.] #251580
08/22/12 11:37 AM
08/22/12 11:37 AM
holy s$it. That thing still looks great for all it's done...
Re: nacra 18 SQ [Re: avalondarlyn] #255826
12/20/12 03:45 PM
12/20/12 03:45 PM
i'm in need of a n6.0 or i-20 boom.(alum) any leads would be great. thanks
Re: nacra 18 SQ [Re: avalondarlyn] #255832
12/20/12 08:14 PM
12/20/12 08:14 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
The N6.0 does not have a boom.
Philip
USA #1006
Re: nacra 18 SQ [Re: P.M.] #255835
12/20/12 09:38 PM
12/20/12 09:38 PM
yeah, but you probably couldn't understand them because of the slurred speech.
Re: nacra 18 SQ [Re: avalondarlyn] #255837
12/20/12 11:45 PM
12/20/12 11:45 PM
Mike Fahle Offline
Mike Fahle  Offline
How about a Mystere 6.0 boom?
Re: nacra 18 SQ [Re: Ventucky Red] #255843
12/21/12 09:40 AM
12/21/12 09:40 AM
M
MN3
MN3
M
ha
Re: nacra 18 SQ [Re: Mike Fahle] #255844
12/21/12 09:41 AM
12/21/12 09:41 AM
M
MN3
MN3
M
how about converting a sunfish mast or just an alum pole
Re: nacra 18 SQ [Re: avalondarlyn] #255849
12/21/12 02:28 PM
12/21/12 02:28 PM
thanks that was easy boom from a tornado. 15 min away.
Re: nacra 18 SQ [Re: avalondarlyn] #255867
12/21/12 10:24 PM
12/21/12 10:24 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Tell us all your boom story Brad! Some of us might learn something.
Dave
Re: nacra 18 SQ [Re: avalondarlyn] #255877
12/22/12 09:07 PM
12/22/12 09:07 PM
E
EdB Offline
EdB  Offline
E
Sq looks great
I put an I 20 sail on mine as well. Very close dimensions.
Light weight mast had trouble flattening the main up wind in a blow.
I built my own boom. Went to a local scrap yard and bought similar section
Ed Baldwin
Central OH
Bimare 18HT #4
0 registered members (), 3,356 guests, and 90 spiders.
Most Online3,694
59 minutes ago
