| Re: AC72 Oracle Team USA Spaceship has landed
[Re: P.M.]
#255582 12/08/12 01:24 PM 12/08/12 01:24 PM |
Posts: 893 | So at best vmg of 42 knots, that makes the Tractor still probably not as fast as the current crop of Tri's which I think are averaging around 38 knots for 24 hours at a time ?
[Re: P.M.]
#255583 12/08/12 01:26 PM 12/08/12 01:26 PM |
Posts: 4,119 Northfield Mn | That jib looks like a hanky when they pan back. Kinda makes you wonder if there is a point they'd just drop it?
[Re: waynemarlow]
#255592 12/08/12 10:20 PM 12/08/12 10:20 PM |
Posts: 12,310 South Carolina | So at best vmg of 42 knots, that makes the Tractor still probably not as fast as the current crop of Tri's which I think are averaging around 38 knots for 24 hours at a time ? Designing a boat for 80% reaching and designing a boat for refined windward leeward are two very different things.
Jake Kohl | | | Re: AC72 Oracle Team USA Spaceship has landed
[Re: P.M.]
#255813 12/20/12 03:01 AM 12/20/12 03:01 AM |
Posts: 757 japan | or17 is going back together with good stiff looking beams
hopefully she'll be flying again in feb.
[Re: P.M.]
#255836 12/20/12 10:59 PM 12/20/12 10:59 PM |
Posts: 2,490 On the Water | O.K., this video has my curiosity up. The boat is a one design SL33, designed by Morrelli & Melvin and built by Hakes Marine . The video shows it foiling nicely, but it looks like it has a curved foil on port (windward hull) and "possibly" a L foil on starboard. Can't tell what the rudders are. Here are some pics of the SL33 foiling with a soft rig. Looks like it might be an S foil on the windward hull. Any body have any knowledge here?
Philip USA #1006 | | | Re: AC72 Oracle Team USA Spaceship has landed
[Re: P.M.]
#255851 12/21/12 02:59 PM 12/21/12 02:59 PM |
Posts: 3,224 Roanoke Island ,N.C. | O.K., this video has my curiosity up. The boat is a one design SL33, designed by Morrelli & Melvin and built by Hakes Marine . The video shows it foiling nicely, but it looks like it has a curved foil on port (windward hull) and "possibly" a L foil on starboard. Can't tell what the rudders are. Here are some pics of the SL33 foiling with a soft rig. Looks like it might be an S foil on the windward hull. Any body have any knowledge here? Obfuscation. Public released video. I wouldn't rely to heavily on what you see.
[Re: jollyrodgers]
#255882 12/23/12 08:36 AM 12/23/12 08:36 AM |
Posts: 12,310 South Carolina | I really don't think we will see them foiling upwind. I think they'll use the foils to make the boat a little lighter in the water - but not foil born. Downwind, however, probably.
#255887 12/23/12 07:45 PM 12/23/12 07:45 PM |
Posts: 307 maui | I really don't think we will see them foiling upwind. I think they'll use the foils to make the boat a little lighter in the water - but not foil born. Downwind, however, probably. Agreed, the no foiling to windward seems to be the consensus. Most likely they are canting the lee board for sailing off the wind, which when combined with the wing tip or "L" gives the enough vertical lift to fully foil. Their speed may or may not increase, and their angle downwind may improve. Some speculation says both speed and angle will improve from foiling. They are limited in the number of 72 dagger boards that they are allowed to make, but they can make as many SL33 or ac 45 dagger boards as they want to help figure this new development out. Mr. Melvin is on the design team for NZ so it makes sense for them to use the 33 as a test platform. Atrtemis focused on the big wing first and don't appear to be in agreement that fully foiling is the way to go. the original mockup of the 72s showed banana boards, but i imagine that they work better on small cats that are crew weight trimmed, and big tris that have a regular board in the center hull. once they tried "L" and "T" foils they didn't look back. can you imagine flying into the leeward gate at 40 knts., having to round up and crank the daggerboard to a de-canted position? what a learning curve this contest must have. On the jibes it seems like they would set the new board before the jibe, but when 17 capsized going into their jibe they still had the 1 board up. if it had been down maybe both hulls would have been clear of the water and nosing in would not have been an issue. | | |
377
guests, and 35
