Hi Mark
I,d like to see an {open class} in future years for the 1000 mile race .
Had a rough year ,-an injury kept me from racing ,-so I,m really looking forward to getting back and racing the 1000 miles again , starting to work-out, looking for a crew and gr crew ,-do have a sponsor again ,-its great fun to put one of these together though alot of planning and prep. goes into it.This will be my 8th.
On the rules aspect for these 1000 mile races a class has been the history , but think the Formula class concept works evan better.
The dispensation rule Formula classes use include ALL similar existing boats just as they are --like the N-6/0 NE spin as example.
.THE f-18 RULE WORKS VERY WELL it is yet to be seen if an older existing 18 design with updated same sailplan or the option of dispensation of larger spin on existing could compete with the Tiger or N-F-18 .
A Hobie 18 w spin was sailed very successfully in previous W-1000 TO A GREAT TIME AND FINISH.
Here are basic F-20 rules outline ,--
The specalized requirements teams need to make to boats with Safety considerations in mind for this type of more extreme ocean racing alone make this rule adaptation worth implimenting .
If your out in huge seas miles offshore sometimes at night racing, your sailing craft is all you have, it gives one a very different perspective as to boat preparation and set up .
Sail pattern and outline are defined per class model -
this simplifies things greatly . Additional rules on more specific minor modification can be added if desired .-
A review of the other existing Formula rules provides the rules example and definitions in areas of concern .
Most all understand what a formula rule is and its intent
FORMULA 20 CATAMARAN CLASS
For people of good will to race together for the enjoyment of the sport in accordance with the Racing Rules of Sailing and in the spirit of rule #2 of fair sailing under ISAF rules –To compete within recognized principles of sportsmanship and fair play.
Intent -.
To race 20-ft catamarans by numerous builders of various design features that will encourage development and better safer craft as a class on a first across the finish line wins basis in buoys and distance racing.
Amendments—We wish to keep rules as simple as possible and rely on good intent of sailors in accordance with standard safety requirements per sailing rules and required gear and class principles as stated.
Future rule additions definitions and amendments per majority vote of active class members.
The -F-20 Committee will propose amendments to the rule if necessary. Amendments shall be placed on one year’s notice unless it is considered essential to act immediately to prohibit an unseaworthy feature. Formula 20 boats will often be sailed in EXTREME type distance racing events and all components are to be constructed accordingly and sailed extensively in varied conditions before competing.
Basic specifications - FORMULA 20 C C .
LENGTH –20 ft one inch max. —Stern to bow meas.
BEAM - 8.5 ft –max.hull point meas.
WEIGHT –two categories of boat wgt. –380 Lb. and above
-410 Lb. and above
-Definition boat weights –boat sails and all att gear fully rigged
Boats may add permanently fixed gear and floatation to meet min.
Corrector weights will also be allowed for boats under 380lb. total.
SAIL AREA –two corresponding categories
380 min boat wgt –MAINSAIL =210 sq. ft inc. mast --53 sq. ft jib +270 sq. ft spin, max.
410 min.boat weight MAINSAIL =210 sq. ft – 60 sq. ft jib + 300 sq. ft spin. Max.
Increases of 7-sq. ft. in jib and 30 sq. ft in spin area in 30-LB boat wgt differential.
Sail area may be traded off from main to jib of equal sq. ft to allow modification and design variation of sail plan to any max. S A combination of smaller main in category
All measurements per standard current ISAF measurement rules, --see diagrams and instruction.
-Roller furlers and main reef points may be used. -
-All teams to use the same set of sails for a regatta or distance race, but may be replaced if severely damaged to allow a team to continue racing with the permission of race organizers per event racing instructions.
Sailmakers and owners to list sq. ft in 2 inch numerals at the tack of each sail next to the sailmakers logo with signature over.
All sails are to be commercially available to any and all sailing teams min one month before an event or sails may not be used for that event
-. Existing class catamaran designs will be accepted as listed per mfg. or sailmaker. -Racing will be on the honor system, but any boat may be challenged and checked along with the protesting party also being checked for weight and sail area compliance. Mainsails must be within the pattern outline of the current I-20 sails . Mast height is limited to 32 ft , added main area of equal sq ft may be added below the boom area .Those not in compliance will be DSQ for those races.
CREW -
-CREW WEIGHT –-A class min of 320 Lb., crews may carry corrector weights attached to boat to meet min.
Wgt based on teams wearing standard swim apparel and shirt.
-MASTS –May be of alum. and/or carbon fiber or combinations of non conducting materials in standard section tapered or uniform and a Max 32 ft length. With-standard wire rigging in any configuration.
-HULLS -BOARDS and RUDDERS–Of any standard material or configuration.
SPIN POLES –any length may be used made of any material in standard configuration with snuffer configuration of any type. Improvements to spin systems and hardware placement and coresponding design improvements and developments are permitted.
Dispensation -
Older existing designs may be given dispensation per F-20 committee by owners request in design feature trade offs -
example = an existing heavier mast rig and standard class smaller mainsail in compensation for larger spin area, again only applied to older existing designs --The current NA Nacra 6/0 with heavier boat weight and mast rigging and sailplan compensations of 348 sq ft spin as example.
contact O F 20 committee
--crdesign@cac.net-
CLASS EMBLEM
The starboard side of the mainsail MAY carry the -Formula-20 CC logo of racing Formula 20s along with individual sail number for scoring purposes.
