| Attach trapeze handle to Dyneema #260376 06/13/13 09:48 PM 06/13/13 09:48 PM |
Joined: Aug 2011 Posts: 182 Grafton, NSW Greg/Debra OP
Posts: 182 Grafton, NSW | I have bought a roll of Dyneema to make some new trapeze "wires". The splicing looks straight forward, but how do I fit the trapeze handle? On SS wire one just has a single swage or stop crimped on the wire to position the handle. How is it done with Dyneema?
Thanks, Greg.
1140 Gadfly 1434 J.I.B.E. 1727 Atreus
| | | Re: Attach trapeze handle to Dyneema
[Re: Greg/Debra]
#260381 06/14/13 05:47 AM 06/14/13 05:47 AM | Scarecrow
| Scarecrow
Unregistered | You thread the line through the handle and splice on a thimble. Then pull the handle down over the splice till it sits on the thimble. | | | Re: Attach trapeze handle to Dyneema
[Re: Greg/Debra]
#260416 06/15/13 03:58 AM 06/15/13 03:58 AM |
Posts: 182 Grafton, NSW | Many thanks to Scarecrow for the advice.
Let me see if I have this right; splice on a thimble, then instead of cutting off the tail, continue it down to the dog-bone, and terminate it there with another thimble splice?
[Re: Greg/Debra]
#260423 06/15/13 01:30 PM 06/15/13 01:30 PM | Scarecrow
| Scarecrow
Unregistered | You could do that but its not what I meant. Will take a photo at the club today. | | | Re: Attach trapeze handle to Dyneema
[Re: Greg/Debra]
#260428 06/16/13 02:54 AM 06/16/13 02:54 AM |
Posts: 182 Grafton, NSW | Thanks, I look forward to seeing the photo.
[Re: Greg/Debra]
#260437 06/16/13 06:17 PM 06/16/13 06:17 PM | Scarecrow
| Scarecrow
Unregistered | I got a bit distracted when doing these and forgot to go back and shoot any more. As mentioned above. Thread the trap line through the handle then splice in a thimble using a locking eye splice and then pull the handle back down over the splice. As shown below I just run the retracting portion of the trap wire through the eye, most people will add a small block. | | | Re: Attach trapeze handle to Dyneema
[Re: Greg/Debra]
#260440 06/16/13 07:56 PM 06/16/13 07:56 PM |
Posts: 182 Grafton, NSW | Thanks Scarecrow for the photos, and I can see that the handle sits on the eye splice at the end of the Dyneema. And it appears that the dog-bone is tied on with cord which passes through the thimble, and then joins onto bungee cord. When one attaches the dog-bone to the harness, the cord pulls through the thimble until it is stopped at the thimble by the red knob.
Is this correct? I haven't seen this setup before. I would imagine that having the dog-bone up high like that would make hooking on easier?
[Re: Greg/Debra]
#260441 06/16/13 09:53 PM 06/16/13 09:53 PM | Scarecrow
| Scarecrow
Unregistered | That's correct, it is a pretty standard cat setup as it keeps upwards pressure on the dogbone so you don't come unhooked. Google image "catamaran trapeze" and you'll see plenty of similar photos. | | | Re: Attach trapeze handle to Dyneema
[Re: Greg/Debra]
#260442 06/17/13 03:07 AM 06/17/13 03:07 AM |
Posts: 182 Grafton, NSW | OK, I get it now, and will put something similar on my boat. Many thanks to Scarecrow.
3,076
guests, and 357
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
