Page 30 of 202 1 2 28 29 30 31 32 201 202
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #260654
06/25/13 10:20 AM
06/25/13 10:20 AM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #260710
06/26/13 06:31 PM
06/26/13 06:31 PM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #260711
06/26/13 06:32 PM
06/26/13 06:32 PM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Seeing double
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #260713
06/26/13 08:21 PM
06/26/13 08:21 PM
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #260716
06/26/13 09:22 PM
06/26/13 09:22 PM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Great pictures of two boat training. Can't wait to see the videos.
Two Boat Training
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #260718
06/27/13 01:13 AM
06/27/13 01:13 AM
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #260724
06/27/13 08:29 AM
06/27/13 08:29 AM
M
MN3
MN3
M
awsomenesss! (except for the lame drum loop in the background)
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #260729
06/27/13 10:17 AM
06/27/13 10:17 AM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #260754
06/28/13 07:52 AM
06/28/13 07:52 AM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Well Done.
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #260755
06/28/13 08:24 AM
06/28/13 08:24 AM
The only way I can tell boat 1 from boat 2 is on boat 1, the center "pod" (underneath the net) is longer. Boat 2 has a more raked pod trailing edge.
Re: AC72 Oracle Team USA Spaceship has landed [Re: mbounds] #260756
06/28/13 09:58 AM
06/28/13 09:58 AM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Two spars on the spin pole vs. one spar on the other.
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #260757
06/28/13 09:59 AM
06/28/13 09:59 AM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #260759
06/28/13 11:16 AM
06/28/13 11:16 AM
brucat Offline
brucat  Offline
Well, at least they'll have closure... and going to court is not an option (until you lose, I guess).
Simple answer (not likely to happen): If this is all about safety, have Oracle share all of their design and testing data related to the rudders with all of the teams.
Re: AC72 Oracle Team USA Spaceship has landed [Re: brucat] #260761
06/28/13 11:35 AM
06/28/13 11:35 AM
It's not that simple - the Oracle boats have lower aerodynamic profiles than ETNZ, which has more volume up front to counteract pitching.
Allowing rudder elevators would give a significant advantage to Oracle.
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #260762
06/28/13 11:54 AM
06/28/13 11:54 AM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
He said the yacht “pitch-poled” . . . . Peyron said that, contrary to some reports, the boat did not break before it capsized.
NY Times Article
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #260763
06/28/13 12:06 PM
06/28/13 12:06 PM
NY Times Article
good to know - thanks for posting that.
Re: AC72 Oracle Team USA Spaceship has landed [Re: mbounds] #260764
06/28/13 12:24 PM
06/28/13 12:24 PM
Boat 1 has two pelican strikers and its boards are further forward.
Re: AC72 Oracle Team USA Spaceship has landed [Re: Jake] #260766
06/28/13 12:50 PM
06/28/13 12:50 PM
catandahalf Offline
catandahalf  Offline
Rudder elevators, wings, tips, whatever your cultural area calls them are becoming "the new performance stimulator" across the board. From A Cats to AC 72s there is evidence and growing faith that lifting foils add stabilization.
The rudder elevators, do, in fact, reward good driving and sailhandling! This makes it arguable as a safety feature in the light of two other AC teams supporting Emirates since have made hull modifications which they claim make the boat safer.
Now the sailing jury will decide which is the modern path to safety - high performance control (Oracle) or the 20th century approach by the whiners (Others sans elevators).
Could this be a ploy for "more time to train?" The move certainly adds drama for the audience. Let us hope that safety through modern design and athletic performance prevails over the traditional 'displacement (adding weight) approach' for safety. The Jury is out... postpone racing for higher speeds and thrills in lighter air??? But, Oracle may have stepped outside the lifelines for the sake of modernism a titch too late...
Re: AC72 Oracle Team USA Spaceship has landed [Re: brucat] #260768
06/28/13 01:27 PM
06/28/13 01:27 PM
Hillsborough, NC USA
I
Isotope235 Offline
Isotope235  Offline
I
Simpler answer: Add an electronic interlock to the rudder elevator control. The interlock would indicate its status to the boat's communication pod at all times. Oracle would engage the interlock before racing, thereby satisfying the class rule that the elevator cannot be adjusted. If the indicator ever showed that the interlock had been disengaged during a race, Oracle would forfeit.
I think there's merit to ETNZ and Luna Rosa's argument. Changing the class rule to allow elevator adjustment while racing would be a "back to the drawing board" proposition. The challengers have no time left to design, build, and test such modifications.
Re: AC72 Oracle Team USA Spaceship has landed [Re: Isotope235] #260771
06/28/13 02:25 PM
06/28/13 02:25 PM
I agree with that. Added to the situation is that Oracle has been using them for several months as training wheels so they have additional time learning to use them and possibly refining them.
0 registered members (), 2,894 guests, and 136 spiders.
