| Re: Cat Refinishing--What's your take?
[Re: JACKFLASH]
#260792 06/29/13 11:41 AM 06/29/13 11:41 AM |
Posts: 3,224 Roanoke Island ,N.C. | Ian and Rick, Is the stuff in Sam's link the right stuff?
[Re: Team_Cat_Fever]
#260802 06/30/13 01:32 PM 06/30/13 01:32 PM |
Posts: 291 | I have also used the Interlux performance epoxy on underside of a J24. It is great stuff. Good luck getting GT300 sticker or the like to stick once your sailing. The VC Epoxy has a teflon aditive in it.
[Re: JACKFLASH]
#260826 07/01/13 03:01 PM 07/01/13 03:01 PM |
Posts: 172 Anacortes | Yes that is the stuff. Like Rick I've done lots of boat bottoms with the stuff, as well as the rudders and boards on my Tiger. Always been very happy with the result. Definitely spray it on, its not worth it to roll it. Apply lots of thin coats within the re-coat timeframe. Then as Rick says wet sand it AS SOON as you can. It gets hard as a rock after full cure and if you wait too long it will take FOREVER to sand it down to a smooth finish. Try using an air powered jitterbug sander for the first couple of wet sanding runs with 220-400 grit, that will save you a lot of time hand sanding when you move to 600 and up. For repairs just prep it and spray as you would gelcoat, then wet sand and polish. Sam99 get in touch with Bobby Muller at Muller Marine in Annapolis if you want someone to do it for you. You won't be disappointed. Tell him I sent you
Anacortes Rigging.com Rigging and Yacht Services
[Re: Sloansailing]
#260827 07/01/13 03:24 PM 07/01/13 03:24 PM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | Yes that is the stuff. Like Rick I've done lots of boat bottoms with the stuff, as well as the rudders and boards on my Tiger. Always been very happy with the result. Definitely spray it on, its not worth it to roll it. Apply lots of thin coats within the re-coat timeframe. Then as Rick says wet sand it AS SOON as you can. It gets hard as a rock after full cure and if you wait too long it will take FOREVER to sand it down to a smooth finish. Try using an air powered jitterbug sander for the first couple of wet sanding runs with 220-400 grit, that will save you a lot of time hand sanding when you move to 600 and up. For repairs just prep it and spray as you would gelcoat, then wet sand and polish. Sam99 get in touch with Bobby Muller at Muller Marine in Annapolis if you want someone to do it for you. You won't be disappointed. Tell him I sent you  Bah Only available in white  | | | Re: Cat Refinishing--What's your take?
[Re: ThunderMuffin]
#260828 07/01/13 03:48 PM 07/01/13 03:48 PM |
Joined: Sep 2003 Posts: 97 Williamston, sc h18catsailor
Posts: 97 Williamston, sc | Yes that is the stuff. Like Rick I've done lots of boat bottoms with the stuff, as well as the rudders and boards on my Tiger. Always been very happy with the result. Definitely spray it on, its not worth it to roll it. Apply lots of thin coats within the re-coat timeframe. Then as Rick says wet sand it AS SOON as you can. It gets hard as a rock after full cure and if you wait too long it will take FOREVER to sand it down to a smooth finish. Try using an air powered jitterbug sander for the first couple of wet sanding runs with 220-400 grit, that will save you a lot of time hand sanding when you move to 600 and up. For repairs just prep it and spray as you would gelcoat, then wet sand and polish. Sam99 get in touch with Bobby Muller at Muller Marine in Annapolis if you want someone to do it for you. You won't be disappointed. Tell him I sent you  Bah Only available in white Well....you could finally "decide"
David Strickland Hobie 18 HEAVY air crew on a J22
[Re: Sloansailing]
#260832 07/01/13 04:44 PM 07/01/13 04:44 PM |
Posts: 932 Solomon's Island, MD | Yes that is the stuff. Like Rick I've done lots of boat bottoms with the stuff, as well as the rudders and boards on my Tiger. Always been very happy with the result. Definitely spray it on, its not worth it to roll it. Apply lots of thin coats within the re-coat timeframe. Then as Rick says wet sand it AS SOON as you can. It gets hard as a rock after full cure and if you wait too long it will take FOREVER to sand it down to a smooth finish. Try using an air powered jitterbug sander for the first couple of wet sanding runs with 220-400 grit, that will save you a lot of time hand sanding when you move to 600 and up. For repairs just prep it and spray as you would gelcoat, then wet sand and polish. Sam99 get in touch with Bobby Muller at Muller Marine in Annapolis if you want someone to do it for you. You won't be disappointed. Tell him I sent you I'll talk to Bobby and see what he can do for me, he's a 5 minute walk from my place. My bottom is in pretty good shape after all the hours of sanding, gelcoating, sanding, gelcoating then polishing I did back in April. Might want my boards re-faired before nationals but I can sand and happen to know where a paint booth is hidden
Scorpion F18
[Re: ThunderMuffin]
#260835 07/01/13 09:10 PM 07/01/13 09:10 PM |
Posts: 172 Anacortes | Yes that is the stuff. Like Rick I've done lots of boat bottoms with the stuff, as well as the rudders and boards on my Tiger. Always been very happy with the result. Definitely spray it on, its not worth it to roll it. Apply lots of thin coats within the re-coat timeframe. Then as Rick says wet sand it AS SOON as you can. It gets hard as a rock after full cure and if you wait too long it will take FOREVER to sand it down to a smooth finish. Try using an air powered jitterbug sander for the first couple of wet sanding runs with 220-400 grit, that will save you a lot of time hand sanding when you move to 600 and up. For repairs just prep it and spray as you would gelcoat, then wet sand and polish. Sam99 get in touch with Bobby Muller at Muller Marine in Annapolis if you want someone to do it for you. You won't be disappointed. Tell him I sent you  Bah Only available in white Pigment
[Re: Sloansailing]
#260836 07/02/13 07:02 AM 07/02/13 07:02 AM |
Posts: 12,310 South Carolina | Yes that is the stuff. Like Rick I've done lots of boat bottoms with the stuff, as well as the rudders and boards on my Tiger. Always been very happy with the result. Definitely spray it on, its not worth it to roll it. Apply lots of thin coats within the re-coat timeframe. Then as Rick says wet sand it AS SOON as you can. It gets hard as a rock after full cure and if you wait too long it will take FOREVER to sand it down to a smooth finish. Try using an air powered jitterbug sander for the first couple of wet sanding runs with 220-400 grit, that will save you a lot of time hand sanding when you move to 600 and up. For repairs just prep it and spray as you would gelcoat, then wet sand and polish. Sam99 get in touch with Bobby Muller at Muller Marine in Annapolis if you want someone to do it for you. You won't be disappointed. Tell him I sent you  Bah Only available in white Pigment unpredictable results.
Jake Kohl | | | Re: Cat Refinishing--What's your take?
[Re: waterbug_wpb]
#260839 07/02/13 10:02 AM 07/02/13 10:02 AM |
Posts: 12,310 South Carolina | I've been trying to find a few folks interested in this so I can justify buying the material to produce several hull wraps....the stuff isn't that cheap and you have to buy in bulk. It's not something I really care to get into from a business perspective, but I hate to buy $1,200 in materials to just do my boat.
#260842 07/02/13 10:37 AM 07/02/13 10:37 AM |
Posts: 172 Anacortes | Yes that is the stuff. Like Rick I've done lots of boat bottoms with the stuff, as well as the rudders and boards on my Tiger. Always been very happy with the result. Definitely spray it on, its not worth it to roll it. Apply lots of thin coats within the re-coat timeframe. Then as Rick says wet sand it AS SOON as you can. It gets hard as a rock after full cure and if you wait too long it will take FOREVER to sand it down to a smooth finish. Try using an air powered jitterbug sander for the first couple of wet sanding runs with 220-400 grit, that will save you a lot of time hand sanding when you move to 600 and up. For repairs just prep it and spray as you would gelcoat, then wet sand and polish. Sam99 get in touch with Bobby Muller at Muller Marine in Annapolis if you want someone to do it for you. You won't be disappointed. Tell him I sent you  Bah Only available in white Pigment unpredictable results. What kind of pigments did you try? I've never done it, always just applied it white. I would think an epoxy pigment (like the West System black pigment) if mixed thoroughly would work.
[Re: JACKFLASH]
#260843 07/02/13 11:05 AM 07/02/13 11:05 AM |
Posts: 932 Solomon's Island, MD | I'm with Jake on the pigment. Tried it once (West Systems Green), granted on a lighter weight part where using lots of pigment wasn't an option, and ended up with splotches of pigment strewn throughout the part, it looked ugly. Black may do OK since it's black.
Scorpion F18
[Re: JACKFLASH]
#260846 07/02/13 11:32 AM 07/02/13 11:32 AM |
Posts: 3,224 Roanoke Island ,N.C. | Sounds like you didn't mix it thoroughly. Not a pigment problem. I can't vouch for epoxy based pigments ,but they work fine in gel-coat as long as you play by the rules.
[Re: bacho]
#260849 07/02/13 12:10 PM 07/02/13 12:10 PM |
Posts: 12,310 South Carolina | Jake, what's the shelf life of the stuff? They say 2 years on the shelf. The print life (before significant signs of fading) is nine years. The recommended interval of application is about 5 years (before it becomes a real pain to remove). There is an intermediate level of material with a 5 year print life...but typically these are harder to remove (I really don't know in this case)
#260854 07/02/13 01:13 PM 07/02/13 01:13 PM |
Posts: 3,655 Portland, Maine | Jake, what's the shelf life of the stuff? They say 2 years on the shelf. The print life (before significant signs of fading) is nine years. The recommended interval of application is about 5 years (before it becomes a real pain to remove). There is an intermediate level of material with a 5 year print life...but typically these are harder to remove (I really don't know in this case) What is the durability? Meaning, how would it take beach landings? | | |
1 registered members (edraciunas),
572
guests, and 383
