| Re: AC72 Oracle Team USA Spaceship has landed
[Re: P.M.]
#261146 07/10/13 08:37 AM 07/10/13 08:37 AM |
Posts: 2,490 On the Water | “Winning is a habit. Unfortunately, so is losing. Sure, there’s the talent, but there also has to be the will. Give me human will and the intense desire to win and it will trump talent every day of the week.” Larry Ellison
Philip USA #1006 | | | Re: AC72 Oracle Team USA Spaceship has landed
[Re: P.M.]
#261161 07/10/13 10:13 AM 07/10/13 10:13 AM |
Posts: 3,224 Roanoke Island ,N.C. | Newswire: The black panthers will riot if Team Luna Rossa doesn't win it's America's Cup protest.... Oh,wait....skip that... must have gotten my wires crossed.
[Re: P.M.]
#261164 07/10/13 11:38 AM 07/10/13 11:38 AM |
Posts: 2,490 On the Water | the race schedule: (right click on image/select view image/click "+" to enlarge)
[Re: catman]
#261169 07/10/13 02:38 PM 07/10/13 02:38 PM |
Posts: 307 maui | They're ok. Green did say that NZ was adjusting the ride height by moving the the rudder which is not correct. You'd think they would understand that by now. The English commentator really had things confused when he said one of the crewman's job was to adjust the rudder post angle during flight to stabilize the vessel….. Is this right? -pertaining to the rudder wing/hydro-foiling concept: The main foils' AOI has been dialed in so that the boat flies low and level/slightly bow down. The elevators are part of the hydro-foiling system, and perform the function of stabilizers, pulling the transom down while in flight. They are sized, and set with the AOI different than the main foil in such a way that they are of minimum drag to provide the necessary force. During take-off the elevators are apparently lifting like a water ski. Ride height is not under direct control. The tip of the main foil rising into the air seems to have something to do with that, along with the ability to change the AOI of the main foil. A move which seems to be mostly for take off and maneuvers, not general flight, i'm guesing. Why the term elevators? is it because they lift up and push down like an elevator? Also, there is some speculation that the on-board cameras would reveal too much and the other teams could get some data. | | | Re: AC72 Oracle Team USA Spaceship has landed
[Re: jollyrodgers]
#261170 07/10/13 03:21 PM 07/10/13 03:21 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | They're ok. Green did say that NZ was adjusting the ride height by moving the the rudder which is not correct. You'd think they would understand that by now. The English commentator really had things confused when he said one of the crewman's job was to adjust the rudder post angle during flight to stabilize the vessel….. Is this right? -pertaining to the rudder wing/hydro-foiling concept: The main foils' AOI has been dialed in so that the boat flies low and level/slightly bow down. The elevators are part of the hydro-foiling system, and perform the function of stabilizers, pulling the transom down while in flight. They are sized, and set with the AOI different than the main foil in such a way that they are of minimum drag to provide the necessary force. During take-off the elevators are apparently lifting like a water ski. Ride height is not under direct control. The tip of the main foil rising into the air seems to have something to do with that, along with the ability to change the AOI of the main foil. A move which seems to be mostly for take off and maneuvers, not general flight, I'm guessing. Why the term elevators? is it because they lift up and push down like an elevator? Also, there is some speculation that the on-board cameras would reveal too much and the other teams could get some data. I don't think anyone knows exactly what ENTZ's capability's are when it comes to adjusting the rudder/T-foil. I seem to remember that at one point they were ok with adjusting the T-foil up until the warning signal. With that in mind you would have to assume that they have the ability to change the rudder angle in a fore and aft fashion. Now can they do it on the fly? Don't know. I think it's proper to view the T-foil on the bottom of the rudders as just that. There are a couple videos posted here that explain Oracle's set up. In the one with RC he shows a T-foil with an adjustable elevator on the back of the T-foil. He said that it could only be adjusted by turning a small screw on the bottom. So I think that is where the term elevator fits into the conversation.
[Re: catman]
#261172 07/10/13 04:00 PM 07/10/13 04:00 PM |
Posts: 2,490 On the Water | They're ok. Green did say .... Remember, that they have to talk a lingo that can be understood to a much broader target group, especially the 4KSB captains.I don't know, Andy Green isn't so bad. We could have that half baked knucklehead Todd Harris back. NOT!
Last edited by mummp; 07/10/13 04:01 PM. Reason: insensitivity to multi-hull wannabees
[Re: jollyrodgers]
#261174 07/10/13 04:41 PM 07/10/13 04:41 PM |
Posts: 774 Greenville SC | They're ok. Green did say that NZ was adjusting the ride height by moving the the rudder which is not correct. You'd think they would understand that by now. The English commentator really had things confused when he said one of the crewman's job was to adjust the rudder post angle during flight to stabilize the vessel….. Is this right? -pertaining to the rudder wing/hydro-foiling concept: The main foils' AOI has been dialed in so that the boat flies low and level/slightly bow down. The elevators are part of the hydro-foiling system, and perform the function of stabilizers, pulling the transom down while in flight. They are sized, and set with the AOI different than the main foil in such a way that they are of minimum drag to provide the necessary force. During take-off the elevators are apparently lifting like a water ski. Ride height is not under direct control. The tip of the main foil rising into the air seems to have something to do with that, along with the ability to change the AOI of the main foil. A move which seems to be mostly for take off and maneuvers, not general flight, i'm guesing. Why the term elevators? is it because they lift up and push down like an elevator? Also, there is some speculation that the on-board cameras would reveal too much and the other teams could get some data. The daggerboard is adjusted on the fly to control foiling. Artemis has an article about it a few pages back. | | | Re: AC72 Oracle Team USA Spaceship has landed
[Re: ThunderMuffin]
#261175 07/10/13 04:53 PM 07/10/13 04:53 PM |
Posts: 2,490 On the Water | One thing about the coverage - WHAT HAPPENED TO THE ON BOARD CAMERAS?!
Those were SOOO cool during the ACWS and we were all led to believe that the 72's would have them as well.
Whats the deal?
Also, there is some speculation that the on-board cameras would reveal too much and the other teams could get some data. On-board cameras are definitely required and are included in the class rule. If you want to learn more of the techy stuff google "media module". It is the aero fairing box provided and mounted in center of the rear beam. It is the brains to all the on-board cameras and microphones. You can learn more about it: original class rule Amendment 15 rules and amendments here Pletty of good techy details here. What I haven't verified is if the Louis Vuitton is excluded and the cameras and mics are only used for the AC Finals.
[Re: P.M.]
#261181 07/10/13 06:46 PM 07/10/13 06:46 PM |
Posts: 12,310 South Carolina | wasn't the jury supposed to rule today?
Jake Kohl | | | Re: AC72 Oracle Team USA Spaceship has landed
#261183 07/10/13 07:36 PM 07/10/13 07:36 PM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | wasn't the jury supposed to rule today? Thats when they "expected" a ruling. No guarantees apparently. | | | Re: AC72 Oracle Team USA Spaceship has landed
[Re: P.M.]
#261184 07/10/13 08:16 PM 07/10/13 08:16 PM |
Posts: 2,490 On the Water | International Jury will publish its decision at 11:00 am PT on Thursday.
[Re: P.M.]
#261186 07/10/13 09:02 PM 07/10/13 09:02 PM |
Posts: 2,490 On the Water | International Jury will publish its decision at 11:00 am PT on Thursday. Question is will LR show up and get their point?? I love it, give 'em an hour to sort it out.
20,053
guests, and 1,598
