Page 6 of 6 1 2 3 4 5 6
Re: Cat Refinishing--What's your take? [Re: JACKFLASH] #262069
08/05/13 09:48 AM
08/05/13 09:48 AM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
Yep it's the 3mm EVA decking grip, Matt sent me a roll as well but I'm doing the slicing myself.
Did you remove the stock Nacra grippy gelocoat before you put on the EVA? That's what is putting me off most about the project, the need to sand all that out first frown
Scorpion F18
Re: Cat Refinishing--What's your take? [Re: JACKFLASH] #262070
08/05/13 09:53 AM
08/05/13 09:53 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Yes... that took a bit of time. I used 40 and 60 grit paper on the DA and buzzbox to get that crap smooth. It took forever but its worth it.
Re: Cat Refinishing--What's your take? [Re: Jake] #264141
09/18/13 11:19 AM
09/18/13 11:19 AM
Anacortes
Sloansailing Offline
Anacortes
Originally Posted by Jake
Yes that is the stuff. Like Rick I've done lots of boat bottoms with the stuff, as well as the rudders and boards on my Tiger. Always been very happy with the result. Definitely spray it on, its not worth it to roll it. Apply lots of thin coats within the re-coat timeframe. Then as Rick says wet sand it AS SOON as you can. It gets hard as a rock after full cure and if you wait too long it will take FOREVER to sand it down to a smooth finish. Try using an air powered jitterbug sander for the first couple of wet sanding runs with 220-400 grit, that will save you a lot of time hand sanding when you move to 600 and up.
For repairs just prep it and spray as you would gelcoat, then wet sand and polish.
Sam99 get in touch with Bobby Muller at Muller Marine in Annapolis if you want someone to do it for you. You won't be disappointed. Tell him I sent you smile
Bah
Only available in white frown
Pigment
unpredictable results.
Just a quick follow up to this... I just painted the bottom of a 27' race boat with VC Performance Epoxy, and thought it a good time to do a test with pigment. Used System 3 Epoxy Pigment in black to get a nice "gunmetal gray" color, rolled onto a test panel, and it came out great. Application and drying were exactly as expected. Everything went just the same as the base white color.
Anacortes Rigging.com
Rigging and Yacht Services
Re: Cat Refinishing--What's your take? [Re: JACKFLASH] #265483
09/30/13 01:27 PM
09/30/13 01:27 PM
Portland, Maine
Portland, Maine
Finally finished up with the refinishing project. The port hull needed a lot more work. I had to go:
220 dry
400 dry
600 dry
800 wet
1500 wet
compound
polish
wax
I still have some bad gelcoat on the bottom of this hull. Next project is a pseudo-bottom job. No new gelcoat but definitely a sanding and refinishing.
Re: Cat Refinishing--What's your take? [Re: ThunderMuffin] #265487
09/30/13 01:55 PM
09/30/13 01:55 PM
wow...that looks awesome. Well done, sir.
Re: Cat Refinishing--What's your take? [Re: JACKFLASH] #265492
09/30/13 02:48 PM
09/30/13 02:48 PM
Portland, Maine
Portland, Maine
Thanks Jake! smile
I can brush my teeth in the reflection... lovin it.
Re: Cat Refinishing--What's your take? [Re: JACKFLASH] #265543
10/01/13 05:07 PM
10/01/13 05:07 PM
Western New York
wyatt Offline
wyatt  Offline
Western New York
I wouldn't paint it; did you ever try wet sanding it with a 800 first, then a 1000? Then use a fibreglass cleaner and wax. Collonite makes a great product and you don't need much at all.
0 registered members (), 2,369 guests, and 385 spiders.
