| Re: Florida 300 May 19-May 22
[Re: cyberspeed]
#270652 03/25/14 01:52 PM 03/25/14 01:52 PM |
Posts: 5,590 Naples, FL | my kids did most of the sailing. +1. I'm getting the grommets into some "tiller time" which somewhat keeps them interested. Can you anchor and/or dock there? One of my evil plans is to cruise there in time for T-winds to watch the shenanigans. PS - thanks for setting a good example for the kids with your PFD.
[Re: David Ingram]
#270656 03/25/14 02:13 PM 03/25/14 02:13 PM |
Posts: 12,310 South Carolina | Takes a huge leap of faith, but the fast boats tend to have the crews trimming the main.
Mike As long as the skipper does exactly as they are told everything is fine and boat goes around the course efficently. It's only when the skipper starts to believe they have it figured out is when the wheels come off. Having confidence only means that you don't yet truly understand the situation.
Jake Kohl | | | Re: Florida 300 May 19-May 22
[Re: cyberspeed]
#270787 03/27/14 04:59 PM 03/27/14 04:59 PM |
Posts: 5,525 |
Pete Pollard Blade 702
[Re: waterbug_wpb]
#270792 03/27/14 07:34 PM 03/27/14 07:34 PM |
Joined: Dec 2003 Posts: 1,066 Wellington, FL-Singer Island, ... cyberspeed OP
Posts: 1,066 Wellington, FL-Singer Island, ... | PS - thanks for setting a good example for the kids with your PFD. I was also testing wearing my SPOT unit on my left shoulder. I forgot about it until my sister's friend asked what was blinking on my shoulder. Every transmission was received. My SPOT Track >>> The shoulder is the best place because the sailors shoulders always have clear view of the sky and if the skipper is wearing it, it will stay fairly dry. I found a local place that we can rent the SPOT units for about $40/unit for the week.
[Re: cyberspeed]
#270796 03/27/14 08:16 PM 03/27/14 08:16 PM |
Posts: 3,224 Roanoke Island ,N.C. | PS - thanks for setting a good example for the kids with your PFD. I was also testing wearing my SPOT unit on my left shoulder. I forgot about it until my sister's friend asked what was blinking on my shoulder. Every transmission was received. My SPOT Track >>> The shoulder is the best place because the sailors shoulders always have clear view of the sky and if the skipper is wearing it, it will stay fairly dry. I found a local place that we can rent the SPOT units for about $40/unit for the week. That's all well and good ,but I've got enough crap on my person already sailing and won't add anything else.More to tangle in tacks and I've had to swim after boats after breaking traps and all that stuff becomes a big problem.SPOT are for entertainment, Epirbs are for life saving, that will be on my person.If SPOTS are supplied I'd put it on the boat somewhere.
[Re: cyberspeed]
#270815 03/28/14 09:14 AM 03/28/14 09:14 AM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | Epirbs are for life saving, that will be on my person.If SPOTS are supplied I'd put it on the boat somewhere. Gotta agree with Todd here. EPIRB on one shoulder, strobe and flashlight on the other. | | | Re: Florida 300 May 19-May 22
[Re: Team_Cat_Fever]
#270818 03/28/14 09:47 AM 03/28/14 09:47 AM |
Posts: 3,906 Clermont, FL, USA | PS - thanks for setting a good example for the kids with your PFD. I was also testing wearing my SPOT unit on my left shoulder. I forgot about it until my sister's friend asked what was blinking on my shoulder. Every transmission was received. My SPOT Track >>> The shoulder is the best place because the sailors shoulders always have clear view of the sky and if the skipper is wearing it, it will stay fairly dry. I found a local place that we can rent the SPOT units for about $40/unit for the week. That's all well and good ,but I've got enough crap on my person already sailing and won't add anything else.More to tangle in tacks and I've had to swim after boats after breaking traps and all that stuff becomes a big problem.SPOT are for entertainment, Epirbs are for life saving, that will be on my person.If SPOTS are supplied I'd put it on the boat somewhere. can it be mounted on the boom?
[Re: David Ingram]
#270821 03/28/14 10:14 AM 03/28/14 10:14 AM |
Livingston had one on the boom once...I think he used a batten to extend the boom and mount the spot to. If memory serves me, I think the batten broke in a capsize or something and the spot was lost. I would be a little careful with the nuclear gybes but it's probably one of the better places for it. For the Everglades challenge, we strapped the spot to the boom on the tri just in front of the mainsail strop. It seemed to work just fine from there.
#270832 03/28/14 11:19 AM 03/28/14 11:19 AM |
Posts: 5,590 Naples, FL | what about the top edge of the front beam? I guess the spin might block the sky view occasionally, and it wouldn't work upside down, but I suspect you could build a pretty secure mount on there?
Or build a flush-mount into the center of the inspection port cover?
[Re: waterbug_wpb]
#270834 03/28/14 11:40 AM 03/28/14 11:40 AM |
Posts: 12,310 South Carolina | what about the top edge of the front beam? I guess the spin might block the sky view occasionally, and it wouldn't work upside down, but I suspect you could build a pretty secure mount on there?
Or build a flush-mount into the center of the inspection port cover? They're not TOTALLY waterproof...the front beam could be an issue.
#270844 03/28/14 02:47 PM 03/28/14 02:47 PM |
Posts: 5,590 Naples, FL | perhaps a suggestion for future product development.
but yes, some sort of boom-end mount might make the most sense..
[Re: waterbug_wpb]
#270848 03/28/14 03:24 PM 03/28/14 03:24 PM |
Posts: 1,066 Wellington, FL-Singer Island, ... | They are waterproof but not firehose proof. One of the best places to put it is to tape it to the top of the rotation limiter. I put mine in a waterproof cellphone bag clipped to my mast diamond wires. If you are using a clear map bag that goes on the tramp, that is another great option.
#270853 03/28/14 05:55 PM 03/28/14 05:55 PM |
Livingston had one on the boom once...I think he used a batten to extend the boom and mount the spot to. If memory serves me, I think the batten broke in a capsize or something and the spot was lost. I would be a little careful with the nuclear gybes but it's probably one of the better places for it. For the Everglades challenge, we strapped the spot to the boom on the tri just in front of the mainsail strop. It seemed to work just fine from there. We had ours on a batten on the boom of the 20 for a couple of tybees. Worked fine. If the jibe is so violent you make it go away the boom is probably gone too, unless you put it on with less than substantial stuff. I think anyone who wants to make me put stuff on my shoulders should get stuck under a tramp with said paraphernalia on and see if they still think it's a good idea. Been down that road and prefer not to go back.
[Re: cyberspeed]
#270854 03/28/14 05:56 PM 03/28/14 05:56 PM |
Posts: 3,224 Roanoke Island ,N.C. | They are waterproof but not firehose proof. One of the best places to put it is to tape it to the top of the rotation limiter. I put mine in a waterproof cellphone bag clipped to my mast diamond wires. If you are using a clear map bag that goes on the tramp, that is another great option. We lost coverage in our tramp bag, that was when we went to the boom.
[Re: cyberspeed]
#270879 03/30/14 03:12 PM 03/30/14 03:12 PM |
Posts: 3,224 Roanoke Island ,N.C. | Reservations made. The Best Western in cocoa was like pulling teeth, took 2 hours. The Seaspray and the Best Western both had issues with my id'ed ground crew checking in with my credit card, so if any other racers plan on having their ground crews check in for them, you better prepare for it. the other places were very cool. it's funny those are the same 2 places that took multiple phone calls to get booked also.
[Re: cyberspeed]
#270881 03/30/14 05:34 PM 03/30/14 05:34 PM |
Posts: 3,906 Clermont, FL, USA | It's official we're on the list. Team manager is booking rooms. Prepare to feel the shame of being beaten by team grandpa!
1 registered members (Talus1),
680
guests, and 163
