| Re: Scheurer G7 -- another foiling design, that can be done solo
[Re: Bille]
#271271 04/09/14 11:54 AM 04/09/14 11:54 AM |
Posts: 12,310 South Carolina | Oh my mind...camera zoom should never be used on an unstable platform.
Jake Kohl | | | Re: Scheurer G7 -- another foiling design, that can be done solo
#271274 04/09/14 04:00 PM 04/09/14 04:00 PM |
Posts: 190 | Oh my mind...camera zoom should never be used on an unstable platform. It pains me to say this, (cause i think "Your" just as Unstable as the camera used in this film ) But YEA, i also got sea-sick watching the video. Still though, solo on this machine, looks to be WAY more fun , than solo on a Moth ? Bille | | | Re: Scheurer G7 -- another foiling design, that can be done solo
[Re: Bille]
#271275 04/09/14 04:25 PM 04/09/14 04:25 PM |
Posts: 4,119 Northfield Mn | Still though, solo on this machine, looks to be WAY more fun , than solo on a Moth ? If I were given either for free, I wouldn't complain. Given the choice between the two? Tough call for me. Probably the cat, just because I don't live in a great place to be sailing a Moth.
[Re: Karl_Brogger]
#271276 04/09/14 05:06 PM 04/09/14 05:06 PM |
Posts: 12,310 South Carolina | I don't know...the moth seems to be a more efficient platform for foiling. Half as many foils, smaller, lighter. I suppose that maybe the cat is better suited for the upper speed end of things (once they get better stability through design) but the moth is going to be foiling at lower wind ranges.
[Re: Bille]
#271279 04/09/14 06:08 PM 04/09/14 06:08 PM |
Posts: 3,224 Roanoke Island ,N.C. | You can get it for 7k but you won't be competitive at that price and you can't sail in less than 4 or 5 feet of water ever. Well I guess you could as long as you were foiling and didn't come down.
[Re: Bille]
#271290 04/10/14 08:15 AM 04/10/14 08:15 AM |
Posts: 4,119 Northfield Mn | I don't see how getting it into the water is different from any other cat. You need to do something with the boat while your dealing with the cat-trax no matter what.
[Re: orphan]
#271292 04/10/14 09:45 AM 04/10/14 09:45 AM |
Posts: 5,590 Naples, FL | Not sure if you want to sail any foiling craft in less than 4/5 ft of water.
or weeds, or turtles, or jellyfish, or...
#271294 04/10/14 10:11 AM 04/10/14 10:11 AM |
Posts: 190 | ... I suppose that maybe the cat is better suited for the upper speed end of things (once they get better stability through design) ...
Had to stand up, and view that video from 4-ft away, in-order to not get sick. Once i watched how stable this Lil cat was,(at speed); i was SOLD !! SO -- i looked up the specification for the A-class cat on Wikipedia. http://en.wikipedia.org/wiki/International_A-class_catamaranCurrently the main A-Class class rules are:[3] Min overall boat weight : 75 kg Max overall boat length : 5.49 m (= still the old IYRU rule) Max overall boat width : 2.30 m (= still the old IYRU rule) Max sail area incl. mast : 13.94 m2 (= still the old IYRU rule) I got to say : "I'm impressed" ! How can a Guy make a 19-ft cat , (fully rigged) for only 165 Lb ? I could basically, pick up the entire boat by myself,if i could find a balance point !! I think that is where the High-Cost comes from, That machine would need to be made of carbon or Spectra, to be competitive. If 75kg is there target weight ; wonder what the actual weight of the competitive ones are ? Bille | | | Re: Scheurer G7 -- another foiling design, that can be done solo
[Re: Bille]
#271295 04/10/14 10:39 AM 04/10/14 10:39 AM |
Posts: 1,121 Eastern NC, USA | If 75kg is there target weight ; wonder what the actual weight of the competitive ones are ?
Pretty sure it is going to be 75kg or very close to it.
Tom | | | Re: Scheurer G7 -- another foiling design, that can be done solo
[Re: Bille]
#271296 04/10/14 10:58 AM 04/10/14 10:58 AM |
Joined: Jun 2005 Posts: 302 Daytona Beach Florida orphan
Posts: 302 Daytona Beach Florida | Difference in launching solo is I can pull the tracks and leave it on the hard(1 to 2 inches of water) then pull/float it on the waves to deeper water.
[Re: Bille]
#271297 04/10/14 01:24 PM 04/10/14 01:24 PM |
Posts: 12,310 South Carolina | ... I suppose that maybe the cat is better suited for the upper speed end of things (once they get better stability through design) ...
Had to stand up, and view that video from 4-ft away, in-order to not get sick. Once i watched how stable this Lil cat was,(at speed); i was SOLD !! SO -- i looked up the specification for the A-class cat on Wikipedia. http://en.wikipedia.org/wiki/International_A-class_catamaranCurrently the main A-Class class rules are:[3] Min overall boat weight : 75 kg Max overall boat length : 5.49 m (= still the old IYRU rule) Max overall boat width : 2.30 m (= still the old IYRU rule) Max sail area incl. mast : 13.94 m2 (= still the old IYRU rule) I got to say : "I'm impressed" ! How can a Guy make a 19-ft cat , (fully rigged) for only 165 Lb ? I could basically, pick up the entire boat by myself,if i could find a balance point !! I think that is where the High-Cost comes from, That machine would need to be made of carbon or Spectra, to be competitive. If 75kg is there target weight ; wonder what the actual weight of the competitive ones are ? Bille My 13 year old Kevlar constructed, aluminum beamed Boyer MKIV was only 6 pounds over minimum weight. It's actually not that hard to build to minimum for that class and the boats are durable (i.e I was sailing a 13 year old boat).
[Re: Bille]
#271330 04/11/14 05:13 PM 04/11/14 05:13 PM |
Posts: 6,049 Sebring, Florida. | There are foiling windsurfers now, and foiling kite boards, that would be easier and cheaper than building a new 15 foot foiler.
Blade F16 #777
[Re: Bille]
#271331 04/11/14 05:14 PM 04/11/14 05:14 PM |
Blade F16 #777
2,368
guests, and 417
