| Re: New UK designed and built foiling catamaran
[Re: NacramanUK]
#274770 08/16/14 07:03 PM 08/16/14 07:03 PM |
Posts: 4,119 Northfield Mn | Jesus. Finally something else about this boat. Edge of my seat here.
#274784 08/17/14 11:59 AM 08/17/14 11:59 AM |
Posts: 1,307 Asuncion, Paraguay | Nice boat! With the light weight, it's probably possible to tip it over on the bows. Doable, provided the spinnaker pole is easy to swing out of the way. The use of Moth like (or equal) foil technology is a natural -and smart- move. It saves R&D time and money, plus the parts are readily available (or easy to scale up). Still, J foils are probably less draggy, besides the practical advantages already mentioned in this thread. No spi for me, please, just an upwind headsail for light conditions.
Luiz
[Re: NacramanUK]
#274787 08/17/14 06:14 PM 08/17/14 06:14 PM | Scarecrow
| Scarecrow
Unregistered | a couple of little things.
1. Moth style foils were tried on C-cats and proved slow. L/J/Z/C foils have proven fast. Obviously there are a lot of things that effect the cross over on where different systems are beneficial but right now the evidence points towards the non-wand systems being faster.
2. "52 MANUAL POWER A boat’s standing rigging, running rigging, spars and movable hull appendages shall be adjusted and operated only by the power provided by the crew. " <-- Moths modify this rule in their sailing instructions/class rules. As such sailing a boat like this in an event that doesn't change this rule would be impossible. It has taken how many years for cats to become "acceptable", how long will it take to get this rule dropped?
[Re: ]
#274789 08/17/14 07:30 PM 08/17/14 07:30 PM |
Posts: 12,310 South Carolina | a couple of little things.
2. "52 MANUAL POWER A boat’s standing rigging, running rigging, spars and movable hull appendages shall be adjusted and operated only by the power provided by the crew. " <-- Moths modify this rule in their sailing instructions/class rules. As such sailing a boat like this in an event that doesn't change this rule would be impossible. It has taken how many years for cats to become "acceptable", how long will it take to get this rule dropped? One could argue that the crew adjust the sails, sails capture wind propelling the boat forward, and the wands use the forward motion that resulted from the sailor's "power". The intent of that rule was to disallow motorized, hydraulics, and/or other types of stored energy systems. I don't think there should be an issue with a wand tapping the surface of the water and adjusting a foil.
Jake Kohl | | | Re: New UK designed and built foiling catamaran
[Re: ]
#274790 08/17/14 07:41 PM 08/17/14 07:41 PM |
Posts: 190 | a couple of little things.
... I agree with what you say, but as a sailplane pilot and avid HG pilot ; i really wouldn't mind having control over the height above the water, on a machine like a foiling Catamaran. IF the controls were made Simple !! Had this same discussion with a world class Rigid wing pilot who also happens to be an airline captain, and avid sailor . He's the one who convinced me of such . Only the inept arm-chair sailors Need a devise that does this automatically. Think about it : Your on a broad-reach, in 3-ft chop; you really want some mechanical devise telling Ya how High you should be above the water ? Bille | | | Re: New UK designed and built foiling catamaran
#274792 08/17/14 08:37 PM 08/17/14 08:37 PM | Scarecrow
| Scarecrow
Unregistered | One could argue that the crew adjust the sails, sails capture wind propelling the boat forward, and the wands use the forward motion that resulted from the sailor's "power".
I 100% agree and the issue expressed isn't mine but the accepted interpretation by the one class that has made foiling a true success and the reason they write the change of ISAF rules into their rules. Which is my point about the need for a rule change or an official interpretation. If I was one of the people behind this project I'd be contacting the ISAF and getting an official interpretation before investing production and marketing funds. This won't be a cheap boat and if is to be a success it will be racing sailors buying it and they wont buy it if they're worried about being protested out of big events. | | | Re: New UK designed and built foiling catamaran
[Re: NacramanUK]
#274799 08/18/14 02:57 AM 08/18/14 02:57 AM |
Posts: 4,451 West coast of Norway | What is the point of this boat? 1: To be faster than archimedan beachcats 2: To be a foiling beachcat 3: To be a line-honors beachcat 4: Have fun When comparing the technology in this boat with "Off Yer Rocker", why is this boat a possible success compared to the first foiling C-class? Is the wand control system a "faster" solution compared to non-adjusting foils? Do get meg right. I really like this boat and effort! Would definately like to have one myself  | | | Re: New UK designed and built foiling catamaran
[Re: Rolf_Nilsen]
#274802 08/18/14 07:59 AM 08/18/14 07:59 AM |
Joined: Apr 2005 Posts: 473 Panama City, Florida Redtwin
Posts: 473 Panama City, Florida | What is the point of this boat?
4: Have fun
Rolf, That's exactly what I was thinking. What speed is the boat traveling in the vortex test video? I would be curious to compare numbers with non-foiling (F-18?) and other foiling boats in the same conditions. The Whisper does seem to get up on foils pretty early but that doesn't surprise me comparing the lifting surface area. I bet it has an advantage in low wind but would get mowed down by a c-foiling boat once the wind picked up. I'm not an engineer or a scientist so this is all layman speculation. I think the Whisper would be a hoot to use in a light/moderate wind Round the Island. At least until you get to the "narrows". Regardless of the price it will be out of my budget, but I would be surprised if it comes out any lower than 30K. I would think a great price would be in the low to mid 20s. Heck, at that price I may own a used one in a decade or two. Rob V.
Nacra 5.2
Panama City | | | Re: New UK designed and built foiling catamaran
[Re: NacramanUK]
#274803 08/18/14 08:48 AM 08/18/14 08:48 AM |
Posts: 4,119 Northfield Mn | I think just about everything will get taken out by a modern C -Cat wouldn't it? But, hardly anyone can afford one, very few sail them, even less build them.
I just want to know how this, or any of the other readily available foiling boats, do around the cans. Does this, the Phantom, or the Nacra 20 foil going upwind? Do they go upwind well? How ugly are the tacks and gybes?
This thing looks, really cool and right up my alley. But if it can't go to weather for crap, there's no point for me. That's the downside of any of these videos. You can't really tell how they would do against another design. Line it up against a A-Cat, an F16, and an F18 on a windward leeward and see how they stack up.
It sure looks stable!
I'd bet by the time you get one shipped to the US, it'd be pushing close to $40k.
[Re: Karl_Brogger]
#274805 08/18/14 09:23 AM 08/18/14 09:23 AM |
Posts: 12,310 South Carolina | I think just about everything will get taken out by a modern C -Cat wouldn't it? But, hardly anyone can afford one, very few sail them, even less build them.
I'd bet by the time you get one shipped to the US, it'd be pushing close to $40k. I think there's some confusion on the terminology - I think somebody started talking about "c shaped foils" (which are old tech...I think they mean "J" boards like the America's Cup and C-cats used). Somebody mentioned C-cats and made it all confusing.
[Re: David Ingram]
#274807 08/18/14 09:28 AM 08/18/14 09:28 AM |
Posts: 12,310 South Carolina | GREAT Point! that boat has all but been forgotten! But, to address your question, the Windrider Rave weighed in around 400lbs and setup time was measured in fractions of a day. We should also ask the same question about this one that predates the Rave. The trifoiler came around in the early 90's (I think). Hobie Trifoiler
[Re: NacramanUK]
#274809 08/18/14 09:35 AM 08/18/14 09:35 AM |
Posts: 2,490 On the Water | Because the trifoiler, although fun, sucks in anything but the ideal conditions and point of sail.
Philip USA #1006 | | | Re: New UK designed and built foiling catamaran
[Re: NacramanUK]
#274833 08/18/14 06:27 PM 08/18/14 06:27 PM | Scarecrow
| Scarecrow
Unregistered | The reason C-cats were brought up (by me) was because the Canadians went down the same design path as the "whisper" 7 years ago when they spent hundreds of thousands of dollars building "Off Yer Rocker" And of course half way through the event, because it was slow, they did this: | | | Re: New UK designed and built foiling catamaran
[Re: NacramanUK]
#274839 08/18/14 10:39 PM 08/18/14 10:39 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Ah yes, the Ketterman tri foiler. I think he sold to Hobie? My old boat, the 'Millenium Falcon' sailed right by once one day when someone brought one to the TX City Dike. That boat that's in my Avatar It was on it's foils, I was on a close reach, not going to weather, and not quite beam.
F-18 Infusion #626- SOLD it!
[Re: NacramanUK]
#274840 08/18/14 10:57 PM 08/18/14 10:57 PM | Scarecrow
| Scarecrow
Unregistered |
[Re: ]
#274849 08/19/14 04:41 PM 08/19/14 04:41 PM |
... Moth style foils are called T-foils. T-foils are slower than J-foils. BUT We use T-foils with our kite boards ; and they have gone over 40kts with them. That's NOT too Bad ? Seriously -- if i were to build a catamaran for the purpose of selling it ; i wouldn't Want it to go much faster than 35-kts, because of liability issues !! ? I WOULD want it to be Very stable, and easy to sail. Up-wind on a T-foil with a kite board ; they will Blow-by any conventional devise currently available ; and do it in Less wind. SO a decently designed T-foil should do quite well on a catamaran. Wing loading on the hydrofoil, has proven to be a BIG thing with our kite boards ; wonder if it affects a heavier catamaran as well ? Bille | | |
2,924
guests, and 122
