| Sail number removal question..... #276508 12/03/14 06:37 AM 12/03/14 06:37 AM |
Joined: Apr 2013 Posts: 858 Victoria Australia Pirate OP
Posts: 858 Victoria Australia | Mylar sail with "stick-on" numbers..... any tips / tricks for the removal of the numbers from this type of sail would be appreciated (before I stuff it up )  cheers Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
Kingy started with Impara Cadet #3 / Mosquito #245 & now Mosquitos #1182 & #1740 | | | Re: Sail number removal question.....
[Re: Pirate]
#276509 12/03/14 07:37 AM 12/03/14 07:37 AM |
Posts: 12,310 South Carolina | No real tips - they should come off pretty easy. Once you get an edge, though, go sloooowwww. It will make you pay a penalty if you get anxious and the second you try to go for speed, the number will tear and explode into tiny strips. If you are patient and go slow, it should come up in big pieces. Also go super slow at the very last bit or it leaves a tiny tip.
Once removed, if you have any adhesive left behind on the sail, use goo-gone or denatured alcohol to remove the remaining tacky spots.
Jake Kohl | | | Re: Sail number removal question.....
[Re: brucat]
#276513 12/03/14 11:55 AM 12/03/14 11:55 AM |
Posts: 382 SE MI / NE IN | Does heat help, or just for hulls?
Mike I'd be afraid to delam the sail, but never tried. | | | Re: Sail number removal question.....
[Re: bacho]
#276515 12/03/14 12:44 PM 12/03/14 12:44 PM |
Posts: 12,310 South Carolina | It certainly helps to leave it out in the sun for a while and do it. Yes...a little heat won't hurt you but I wouldn't put much more heat on it than a hair drier can supply (I wouldn't use a heat gun). Sunlight is a good option.
[Re: Pirate]
#276520 12/03/14 03:11 PM 12/03/14 03:11 PM | Scarecrow
| Scarecrow
Unregistered | I took some numbers of a second hand sail with a sailmaker last week and he advised the exact opposite. Keep it out of the sun get a corner then rip it of fast like a bandaide. Worked a treat
[Re: Pirate]
#276528 12/03/14 05:39 PM 12/03/14 05:39 PM | Scarecrow
| Scarecrow
Unregistered | I've never had vinyl numbers on any of my sails. I'm talking standard dacron numbers on mylar. | | | Re: Sail number removal question.....
[Re: bacho]
#276529 12/03/14 05:39 PM 12/03/14 05:39 PM |
Posts: 12,310 South Carolina | I was thinking about vinyl numbers when I wrote my post.
I guess the cold technique may be better for Dacron numbers. I admit I've never tried to rip them off with speed but I've removed a fair share of them. Every time I've done it, it's been room temp and I removed them slowly in order to get them to come off in one relatively large piece at a time.
[Re: Pirate]
#276534 12/04/14 08:42 AM 12/04/14 08:42 AM |
Posts: 2,490 On the Water | +1 on the lighter fluid. I've been using it for decades and it works better than most products on the market. Great for tar removal also.
Philip USA #1006 | | | Re: Sail number removal question.....
[Re: P.M.]
#276544 12/04/14 01:11 PM 12/04/14 01:11 PM | MN3
| MN3
Unregistered | we used gas as tar remover when i worked at the local car wash in the 70's. that worked great too was probably terrible for the car's paint/finish +1 on the lighter fluid. I've been using it for decades and it works better than most products on the market. Great for tar removal also.
[Re: mikekrantz]
#276577 12/04/14 09:29 PM 12/04/14 09:29 PM |
Posts: 4,119 Northfield Mn | sunblock does a great job of removing permanent sharpie
makes me wonder what it's doing for my skin... That is certainly something I wouldn't have tried.
[Re: waterbug_wpb]
#276581 12/05/14 08:03 AM 12/05/14 08:03 AM | MN3
| MN3
Unregistered | Jay it was much more like this (i was the short white guy in the back) | | |
626
guests, and 34
