Sail number removal question..... #276508
12/03/14 06:37 AM
12/03/14 06:37 AM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
Mylar sail with "stick-on" numbers.....
any tips / tricks for the removal of the numbers from this type of sail would be appreciated (before I stuff it up ) wink
cheers
Kingy
& now Mosquitos #1182 & #1740
Re: Sail number removal question..... [Re: Pirate] #276509
12/03/14 07:37 AM
12/03/14 07:37 AM
No real tips - they should come off pretty easy. Once you get an edge, though, go sloooowwww. It will make you pay a penalty if you get anxious and the second you try to go for speed, the number will tear and explode into tiny strips. If you are patient and go slow, it should come up in big pieces. Also go super slow at the very last bit or it leaves a tiny tip.
Once removed, if you have any adhesive left behind on the sail, use goo-gone or denatured alcohol to remove the remaining tacky spots.
Re: Sail number removal question..... [Re: Pirate] #276510
12/03/14 08:49 AM
12/03/14 08:49 AM
brucat Offline
brucat  Offline
Does heat help, or just for hulls?
Re: Sail number removal question..... [Re: brucat] #276513
12/03/14 11:55 AM
12/03/14 11:55 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
I'd be afraid to delam the sail, but never tried.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Sail number removal question..... [Re: Pirate] #276514
12/03/14 12:20 PM
12/03/14 12:20 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
It certainly helps to leave it out in the sun for a while and do it.
Re: Sail number removal question..... [Re: bacho] #276515
12/03/14 12:44 PM
12/03/14 12:44 PM
Yes...a little heat won't hurt you but I wouldn't put much more heat on it than a hair drier can supply (I wouldn't use a heat gun). Sunlight is a good option.
Re: Sail number removal question..... [Re: Pirate] #276520
12/03/14 03:11 PM
12/03/14 03:11 PM
Scarecrow
Scarecrow
I took some numbers of a second hand sail with a sailmaker last week and he advised the exact opposite. Keep it out of the sun get a corner then rip it of fast like a bandaide. Worked a treat
Re: Sail number removal question..... [Re: Pirate] #276521
12/03/14 03:15 PM
12/03/14 03:15 PM
brucat Offline
brucat  Offline
Interesting. Maybe depends on the age of the materials? Do they become brittle (likely to shred) with age and/or UV exposure?
Re: Sail number removal question..... [Re: Pirate] #276526
12/03/14 05:23 PM
12/03/14 05:23 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
I was thinking about vinyl numbers when I wrote my post.
I guess the cold technique may be better for Dacron numbers.
Re: Sail number removal question..... [Re: Pirate] #276528
12/03/14 05:39 PM
12/03/14 05:39 PM
Scarecrow
Scarecrow
I've never had vinyl numbers on any of my sails. I'm talking standard dacron numbers on mylar.
Re: Sail number removal question..... [Re: bacho] #276529
12/03/14 05:39 PM
12/03/14 05:39 PM
I admit I've never tried to rip them off with speed but I've removed a fair share of them. Every time I've done it, it's been room temp and I removed them slowly in order to get them to come off in one relatively large piece at a time.
Re: Sail number removal question..... [Re: Pirate] #276530
12/03/14 07:38 PM
12/03/14 07:38 PM
Hillsborough, NC USA
I
Isotope235 Offline
Isotope235  Offline
I
For PSA Dacron insignia cloth, I'd put some Goo-Gone on them first to soften the adhesive. They should peel off pretty easily. I have a friend who swears by lighter fluid (cigarette lighter, not charcoal lighter), but I prefer the odor of citrus solvent.
Eric
Re: Sail number removal question..... [Re: Pirate] #276534
12/04/14 08:42 AM
12/04/14 08:42 AM
On the Water
P.M. Offline
P.M.  Offline
On the Water
+1 on the lighter fluid. I've been using it for decades and it works better than most products on the market. Great for tar removal also.
Philip
USA #1006
Re: Sail number removal question..... [Re: P.M.] #276544
12/04/14 01:11 PM
12/04/14 01:11 PM
M
MN3
MN3
M
we used gas as tar remover when i worked at the local car wash in the 70's. that worked great too
was probably terrible for the car's paint/finish
Re: Sail number removal question..... [Re: ] #276545
12/04/14 01:15 PM
12/04/14 01:15 PM
Re: Sail number removal question..... [Re: Pirate] #276552
12/04/14 02:41 PM
12/04/14 02:41 PM
maui
jollyrodgers Offline
maui
If you have good gloves and respirator, the chemicals that work well to dissolve the glue are xylene for the ripstop numbers, and goof-off for the vinyl glue. Maybe one or both of those works for everything. Goof-off takes of the glue from foot pads better than most other products, and xylene removes sharpie from mylar as well.
Re: Sail number removal question..... [Re: Pirate] #276553
12/04/14 02:48 PM
12/04/14 02:48 PM
mikekrantz Offline
mikekrantz  Offline
sunblock does a great job of removing permanent sharpie
makes me wonder what it's doing for my skin...
Re: Sail number removal question..... [Re: mikekrantz] #276577
12/04/14 09:29 PM
12/04/14 09:29 PM
That is certainly something I wouldn't have tried.
Re: Sail number removal question..... [Re: waterbug_wpb] #276581
12/05/14 08:03 AM
12/05/14 08:03 AM
M
MN3
MN3
M
Jay it was much more like this (i was the short white guy in the back)
Re: Sail number removal question..... [Re: Pirate] #276610
12/08/14 02:13 PM
12/08/14 02:13 PM
V
Ventucky Red Offline
V
Mine pretty much pulled off, but there was a few spots that didn't...
Wife's hair dryer took care of it...
0 registered members (), 402 guests, and 35 spiders.
