| Re: Need a source for trailer double roller
[Re: ]
#277672 02/20/15 12:50 PM 02/20/15 12:50 PM |
Posts: 12,310 South Carolina | Those lesser expensive cradles won't fit boats with wider hull shapes...like F18, N20, etc. You would have to go with the $150 versions for those boats.
Jake Kohl | | | Re: Need a source for trailer double roller
[Re: waterbug_wpb]
#277673 02/20/15 12:51 PM 02/20/15 12:51 PM | MN3
| MN3
Unregistered | PM sent I've still got a pair of unused cradles that fit the N20 hulls. No swivel on the bottom, but still in the box. | | | Re: Need a source for trailer double roller
#277674 02/20/15 12:53 PM 02/20/15 12:53 PM | MN3
| MN3
Unregistered | do you mean these? - http://www.murrays.com/13-1412.html or other ? Those lesser expensive cradles won't fit boats with wider hull shapes...like F18, N20, etc. You would have to go with the $150 versions for those boats. | | | Re: Need a source for trailer double roller
[Re: ]
#277675 02/20/15 02:07 PM 02/20/15 02:07 PM |
Posts: 12,310 South Carolina | Yes. However, I think your Mystere will work with these lesser expensive ones, though. I had these under my 6.0 but when I switched to a Nacra 20 they would not fit and I had to replace them. http://www.murrays.com/13-7010.html
[Re: ]
#277718 02/25/15 12:45 PM 02/25/15 12:45 PM |
Posts: 2,844 42.904444 N; 88.008586 W | i am pretty sure some welding (or securing some other way) would be needed to prevent the rollers from twisting and flopping around notice the weld in the center of the unit Go to west marine and purchase a pair of rollers that match the ones you have currently, with axles. Then go to Home D and buy a piece of aluminum flate stock, make some measurements, cut it and drill for both rollers, let the hinge point be the existing bracket. Use a couple 1/2" bolts on each side to put it all together and profit?
I like the rollers that were added to Macs trailer, makes it way easier. These work well, they came on the back of my F18 trailer I got used. They do leave black marks on the hulls, so I try and put a piece of carpet (no extra cradles currently) over them when trailering.
F-18 Infusion #626- SOLD it!
[Re: ]
#277719 02/25/15 12:51 PM 02/25/15 12:51 PM |
Posts: 2,844 42.904444 N; 88.008586 W | For my 6.0, (thinner hull profile), I made my own by finding 12"ID PVC pipe scraps at construction sites, cut them using jig saw, and contact cement glued carpet to them. I would use the flatter 'stove' bolts to secure to my trailer or my cat wheels. (under the carpet, bolt, then carpet) Worked like a charm- bascially free, or low cost (carpet scraps and gule for free also- friends)
[Re: ]
#277722 02/25/15 12:57 PM 02/25/15 12:57 PM |
Posts: 4,119 Northfield Mn | The polymer rollers aren't that much more expensive are they? Todd, I'd put a cradle under the hull if I were you. Bouncing down the road is putting a fair amount of stress on a pretty small contact patch. My trailer, I've got a single roller mounted at the back, and a cradle forward of it. The hull only touches the roller when it is being slid on the trailer. You can kinda see it here. [img] http://scontent.xx.fbcdn.net/hphoto...d048fb3fe4b9639a22678dbc&oe=558481B0[/img] Image tags not working?
[Re: Karl_Brogger]
#277724 02/25/15 01:36 PM 02/25/15 01:36 PM | MN3
| MN3
Unregistered | The guy who makes the double rollers (brett the owner of the nacra dealership icarussportsusa.com) never got me a price on the polymer rollers but he has been very cool to work with (even though i haven't purchased anything yet) Your trailer set up looks great. 2 sets of cradles and rollers attached to the back.. how do you get the bows on without them hitting the deck? The polymer rollers aren't that much more expensive are they? Todd, I'd put a cradle under the hull if I were you. Bouncing down the road is putting a fair amount of stress on a pretty small contact patch. My trailer, I've got a single roller mounted at the back, and a cradle forward of it. The hull only touches the roller when it is being slid on the trailer. You can kinda see it here. [img] http://scontent.xx.fbcdn.net/hphoto...d048fb3fe4b9639a22678dbc&oe=558481B0[/img] Image tags not working? | | | Re: Need a source for trailer double roller
[Re: ]
#277725 02/25/15 02:45 PM 02/25/15 02:45 PM |
Joined: Oct 2013 Posts: 38 Lugoff, South Carolina Mac McCallum
Posts: 38 Lugoff, South Carolina | I had him, Brett, add the clear/amber rollers to mine, they weren't much more. I don't remember how much more, but think it was less than $20. They are expensive but really nice, I'm very happy with them.
'09 Viper F16 USA102 A Cat USA 366
[Re: ]
#277728 02/25/15 05:47 PM 02/25/15 05:47 PM |
Posts: 4,119 Northfield Mn | how do you get the bows on without them hitting the deck? They hang past the back of the trailer just a bit. Cattrax a bit aft of the balance point, I push it around by the rear beam and just set the tips of the bow on the rollers. Then pick up the back of the boat by the rear beam and push it on.
[Re: ]
#277731 02/26/15 08:43 AM 02/26/15 08:43 AM | MN3
| MN3
Unregistered | gotcha - sounds a bit lighter than my tank f16 right? | | | Re: Need a source for trailer double roller
[Re: brucat]
#277771 03/03/15 02:28 PM 03/03/15 02:28 PM |
Posts: 4,119 Northfield Mn | Great setup, Karl. What kind of trailer is that?
Mike It's a Triton four place snowmobile trailer. I picked it up from a local motorcycle/atv/snowmobile dealership for $1500 + tax/title. It was sold to me as new because the dealership that had it, used it for their own stuff, but it had never been registered. I think the double stack rack, and the rear mast stand cost me about $2500 to have custom built. I've got another few hundred in material for the sail box, and a zillion hours to build it. I don't think I'd do it any other way, other than a dedicated enclosed trailer, which I don't have the funds for. It tracks stupid straight, rides nicely, and the boat is protected from anything the truck will kick up. Protecting the boat is the most important thing to me. It'll haul three complete boats pretty easily too. http://scontent.xx.fbcdn.net/hphoto...a6e8d0d2558ca9448dca426e&oe=557E91CBhttp://fbcdn-sphotos-h-a.akamaihd.n...4072570_8d16e2d3454fdfee01054dd14a83151dI don't know why image tags aren't working from Facebook anymore.
[Re: Karl_Brogger]
#277773 03/03/15 04:21 PM 03/03/15 04:21 PM |
Joined: Jun 2009 Posts: 524 Petten Netherlands northsea junkie
Posts: 524 Petten Netherlands | With 4 fixed wheels underneath (and also not very close of each other), I can understand that it tracks firmly like a rock. But how in heavens name can it turn??????????
ronald RAIDER-15 (homebuilt)
4,285
guests, and 650
