Page 2 of 3 1 2 3
Re: Need a source for trailer double roller [Re: ] #277672
02/20/15 12:50 PM
02/20/15 12:50 PM
Originally Posted by MN3
Originally Posted by Jake
how much for cradles?
Murray's has a bunch of different cradles for about $55 each
http://www.murrays.com/C-TP.html
Those lesser expensive cradles won't fit boats with wider hull shapes...like F18, N20, etc. You would have to go with the $150 versions for those boats.
Re: Need a source for trailer double roller [Re: waterbug_wpb] #277673
02/20/15 12:51 PM
02/20/15 12:51 PM
M
MN3
MN3
M
PM sent
I've still got a pair of unused cradles that fit the N20 hulls. No swivel on the bottom, but still in the box.
Re: Need a source for trailer double roller [Re: Jake] #277674
02/20/15 12:53 PM
02/20/15 12:53 PM
M
MN3
MN3
M
do you mean these? - http://www.murrays.com/13-1412.html
or other ?
Re: Need a source for trailer double roller [Re: ] #277675
02/20/15 02:07 PM
02/20/15 02:07 PM
Yes. However, I think your Mystere will work with these lesser expensive ones, though. I had these under my 6.0 but when I switched to a Nacra 20 they would not fit and I had to replace them.
http://www.murrays.com/13-7010.html
Re: Need a source for trailer double roller [Re: ] #277707
02/23/15 10:10 AM
02/23/15 10:10 AM
Ocean Springs, MS
kmboudreaux Offline
kmboudreaux  Offline
Ocean Springs, MS
Kenny Boudreaux
C2 F18
Goodall Designs/Southern Area Rep
www.sailboxes.com
Re: Need a source for trailer double roller [Re: ] #277710
02/23/15 08:38 PM
02/23/15 08:38 PM
Ocean Springs, MS
kmboudreaux Offline
kmboudreaux  Offline
Ocean Springs, MS
Kenny Boudreaux
C2 F18
www.sailboxes.com
Re: Need a source for trailer double roller [Re: kmboudreaux] #277711
02/23/15 09:10 PM
02/23/15 09:10 PM
Panama City, Florida
Redtwin Offline
Redtwin  Offline
Rob V. Nacra 5.2 Panama City
Re: Need a source for trailer double roller [Re: ] #277718
02/25/15 12:45 PM
02/25/15 12:45 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
i am pretty sure some welding (or securing some other way) would be needed to prevent the rollers from twisting and flopping around
notice the weld in the center of the unit
Originally Posted by bacho
Go to west marine and purchase a pair of rollers that match the ones you have currently, with axles. Then go to Home D and buy a piece of aluminum flate stock, make some measurements, cut it and drill for both rollers, let the hinge point be the existing bracket. Use a couple 1/2" bolts on each side to put it all together and profit?
I like the rollers that were added to Macs trailer, makes it way easier.
These work well, they came on the back of my F18 trailer I got used.
They do leave black marks on the hulls, so I try and put a piece of carpet (no extra cradles currently) over them when trailering.
F-18 Infusion
#626- SOLD it!
Re: Need a source for trailer double roller [Re: ] #277719
02/25/15 12:51 PM
02/25/15 12:51 PM
Todd_Sails Offline
Todd_Sails  Offline
For my 6.0, (thinner hull profile), I made my own by
finding 12"ID PVC pipe scraps at construction sites,
cut them using jig saw,
and contact cement glued carpet to them.
I would use the flatter 'stove' bolts to secure to my trailer or my cat wheels. (under the carpet, bolt, then carpet)
Worked like a charm- bascially free, or low cost (carpet scraps and gule for free also- friends)
F-18 Infusion
#626- SOLD it!
Re: Need a source for trailer double roller [Re: ] #277722
02/25/15 12:57 PM
02/25/15 12:57 PM
The polymer rollers aren't that much more expensive are they?
Todd, I'd put a cradle under the hull if I were you. Bouncing down the road is putting a fair amount of stress on a pretty small contact patch.
My trailer, I've got a single roller mounted at the back, and a cradle forward of it. The hull only touches the roller when it is being slid on the trailer. You can kinda see it here.
[img]http://scontent.xx.fbcdn.net/hphoto...d048fb3fe4b9639a22678dbc&oe=558481B0[/img]
Image tags not working?
Re: Need a source for trailer double roller [Re: Karl_Brogger] #277724
02/25/15 01:36 PM
02/25/15 01:36 PM
M
MN3
MN3
M
The guy who makes the double rollers (brett the owner of the nacra dealership icarussportsusa.com) never got me a price on the polymer rollers but he has been very cool to work with (even though i haven't purchased anything yet)
Your trailer set up looks great. 2 sets of cradles and rollers attached to the back.. how do you get the bows on without them hitting the deck?
Re: Need a source for trailer double roller [Re: ] #277725
02/25/15 02:45 PM
02/25/15 02:45 PM
Lugoff, South Carolina
Mac McCallum Offline
I had him, Brett, add the clear/amber rollers to mine, they weren't much more. I don't remember how much more, but think it was less than $20. They are expensive but really nice, I'm very happy with them.
'09 Viper F16 USA102
A Cat USA 366
Re: Need a source for trailer double roller [Re: ] #277727
02/25/15 03:58 PM
02/25/15 03:58 PM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Need a source for trailer double roller [Re: ] #277728
02/25/15 05:47 PM
02/25/15 05:47 PM
They hang past the back of the trailer just a bit. Cattrax a bit aft of the balance point, I push it around by the rear beam and just set the tips of the bow on the rollers. Then pick up the back of the boat by the rear beam and push it on.
Re: Need a source for trailer double roller [Re: ] #277731
02/26/15 08:43 AM
02/26/15 08:43 AM
M
MN3
MN3
M
gotcha - sounds a bit lighter than my tank
f16 right?
Re: Need a source for trailer double roller [Re: ] #277734
02/26/15 12:46 PM
02/26/15 12:46 PM
f16 right?
correct
Re: Need a source for trailer double roller [Re: ] #277768
03/03/15 09:48 AM
03/03/15 09:48 AM
brucat Offline
brucat  Offline
Great setup, Karl. What kind of trailer is that?
Re: Need a source for trailer double roller [Re: brucat] #277771
03/03/15 02:28 PM
03/03/15 02:28 PM
It's a Triton four place snowmobile trailer. I picked it up from a local motorcycle/atv/snowmobile dealership for $1500 + tax/title. It was sold to me as new because the dealership that had it, used it for their own stuff, but it had never been registered. I think the double stack rack, and the rear mast stand cost me about $2500 to have custom built. I've got another few hundred in material for the sail box, and a zillion hours to build it.
I don't think I'd do it any other way, other than a dedicated enclosed trailer, which I don't have the funds for. It tracks stupid straight, rides nicely, and the boat is protected from anything the truck will kick up. Protecting the boat is the most important thing to me. It'll haul three complete boats pretty easily too.
http://scontent.xx.fbcdn.net/hphoto...a6e8d0d2558ca9448dca426e&oe=557E91CB
http://fbcdn-sphotos-h-a.akamaihd.n...4072570_8d16e2d3454fdfee01054dd14a83151d
I don't know why image tags aren't working from Facebook anymore.
Re: Need a source for trailer double roller [Re: Karl_Brogger] #277773
03/03/15 04:21 PM
03/03/15 04:21 PM
Petten Netherlands
N
northsea junkie Offline
N
Petten Netherlands
With 4 fixed wheels underneath (and also not very close of each other), I can understand that it tracks firmly like a rock.
But how in heavens name can it turn??????????
ronald
RAIDER-15 (homebuilt)
Re: Need a source for trailer double roller [Re: ] #277775
03/03/15 06:37 PM
03/03/15 06:37 PM
brucat Offline
brucat  Offline
Karl, you're not saying that you paid $2500 on top of the $1500 for the mods, are you?
Ronald, Karl doesn't have time to slow down enough to make turns...
Page 2 of 3 1 2 3
0 registered members (), 19,533 guests, and 887 spiders.
Most Online21,917
51 minutes ago
